All attempts to update from 1.6.1 to 1.7.2 Fail
Attempting to update from 1.6.1 to 1.7.2 fails.
Log check, forum search
N/A
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 918192128
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.octopi_version: 0.15.1
env.python.pip: 19.0.1
env.python.version: 2.7.13
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
printer.firmware: Marlin 2.0.5.4 (GitHub)
OctoPrint 1.6.1, Ender 3, iMakr STARTT, win10
Here are my softwareupdater.logs
2021-12-18 08:58:13,784   /home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip --no-cache-dir
2021-12-18 08:58:17,192 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2021-12-18 08:58:17,196 > Collecting https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip
2021-12-18 08:58:17,197 > Downloading https://github.com/OctoPrint/OctoPrint/archive/1.7.2.zip (6.6MB)
2021-12-18 08:58:23,426 > Requirement already satisfied: OctoPrint-FileCheck>=2021.2.23 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2021.2.23)
2021-12-18 08:58:23,429 > Collecting OctoPrint-FirmwareCheck>=2021.10.11 (from OctoPrint==1.7.2)
2021-12-18 08:58:26,721 > Downloading https://files.pythonhosted.org/packages/53/1a/6b0aa071e4c36478008041bb5ef071b1d3299c98379d51e0f323da9a374e/OctoPrint_FirmwareCheck-2021.10.11-py2.py3-none-any.whl
2021-12-18 08:58:26,722 > Requirement already satisfied: OctoPrint-PiSupport>=2021.10.28 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2021.10.28)
2021-12-18 08:58:26,723 > Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.1.1)
2021-12-18 08:58:26,724 > Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (3.1.1)
2021-12-18 08:58:26,725 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2018.2.21)
2021-12-18 08:58:26,726 > Requirement already satisfied: wrapt<1.13,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.12.1)
2021-12-18 08:58:26,726 > Collecting flask<2,>=1.1.4 (from OctoPrint==1.7.2)
2021-12-18 08:58:26,727 > Downloading https://files.pythonhosted.org/packages/e8/6d/994208daa354f68fd89a34a8bafbeaab26fda84e7af1e35bdaed02b667e6/Flask-1.1.4-py2.py3-none-any.whl (94kB)
2021-12-18 08:58:26,728 > Collecting Jinja2<3,>=2.11.3 (from OctoPrint==1.7.2)
2021-12-18 08:58:26,729 > Downloading https://files.pythonhosted.org/packages/7e/c2/1eece8c95ddbc9b1aeb64f5783a9e07a286de42191b7204d67b7496ddf35/Jinja2-2.11.3-py2.py3-none-any.whl (125kB)
2021-12-18 08:58:26,733 > Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (0.5.0)
2021-12-18 08:58:26,734 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.0.0)
2021-12-18 08:58:26,735 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (2.0)
2021-12-18 08:58:26,736 > Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.0.1)
2021-12-18 08:58:26,737 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (1.1.0)
2021-12-18 08:58:26,738 > Requirement already satisfied: cachelib<0.2,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.2) (0.1)
2021-12-18 08:58:26,738 > Collecting PyYAML<6,>=5.4.1 (from OctoPrint==1.7.2)
2021-12-18 08:58:27,907 > Downloading https://files.pythonhosted.org/packages/a0/a4/d63f2d7597e1a4b55aa3b4d6c5b029991d3b824b5bd331af8d4ab1ed687d/PyYAML-5.4.1.tar.gz (175kB)
2021-12-18 08:58:28,914 > Installing build dependencies: started
2021-12-18 08:58:51,944 > Installing build dependencies: finished with status 'done'
2021-12-18 08:58:51,948 > Getting requirements to build wheel: started
2021-12-18 08:59:15,972 > Getting requirements to build wheel: finished with status 'done'
2021-12-18 08:59:15,973 > Preparing wheel metadata: started
2021-12-18 08:59:17,978 > Preparing wheel metadata: finished with status 'error'
2021-12-18 08:59:17,978 > Complete output from command /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmphMVwZg:
2021-12-18 08:59:17,981 > running dist_info
2021-12-18 08:59:17,984 > error: 'egg_base' must be a directory name (got `/tmp/pip-install-Hlig7b/PyYAML/pip-wheel-metadata`)
2021-12-18 08:59:17,985 >
2021-12-18 08:59:17,986 > ----------------------------------------
2021-12-18 08:59:17,990 ! Command "/home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py prepare_metadata_for_build_wheel /tmp/tmphMVwZg" failed with error code 1 in /tmp/pip-install-Hlig7b/PyYAML
Hmm, that's a new one I think. Maybe try updating pip to the latest to make sure it is not a pip bug?
You can run ~/oprint/bin/pip install --upgrade pip from SSH, or enable pip update checks in the software update settings and update it from there.
As a side note, unrelated to this issue (hopefully) you should upgrade your install to use Python 3, since Python 2 is end of life and will soon be unsupported by OctoPrint. More details below.
Ahh, crap. Looks like I'm going to have to re-flash anyways. I'm on one of those versions that doesn't have a viable 3.6+ without a manual install, which I'm not doing.
