Does any1 know when / if this will be released
@Da_Stu, I had to look at your post history to figure out what you are talking about. Next time, please use more words to explain what you are requesting, and preferably fill in the template.
I think you are asking about updates on being able to use the network connection of your printer instead of a direct serial port connection, as you asked about before here:
No, as far as I know there is no update on when/if this will be released.
And that's also impossible to answer since it's completely unclear if the printer in question even has an open API that could be used, where that is documented, and so on, so I cannot even tell if it would be possible to support that down the road, let alone when.
