pi@octopi:~ $ rm -rf mjpg-streamer-libcamera/
pi@octopi:~ $ git clone https://github.com/ArduCAM/mjpg-streamer.git mjpg-streamer-libcamera
cd mjpg-streamer-libcamera/mjpg-streamer-experimental
make
Cloning into 'mjpg-streamer-libcamera'...
remote: Enumerating objects: 3034, done.
remote: Counting objects: 100% (70/70), done.
remote: Compressing objects: 100% (37/37), done.
remote: Total 3034 (delta 39), reused 51 (delta 33), pack-reused 2964
Receiving objects: 100% (3034/3034), 3.52 MiB | 4.09 MiB/s, done.
Resolving deltas: 100% (1924/1924), done.
[ -d _build ] || mkdir _build
[ -f _build/Makefile ] || (cd _build && cmake -DCMAKE_BUILD_TYPE=Release ..)
-- The C compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
CMAKE_BUILD_TYPE = Release
-- Looking for include file sys/inotify.h
-- Looking for include file sys/inotify.h - found
CMake Warning at plugins/input_opencv/CMakeLists.txt:4 (find_package):
By not providing "FindOpenCV.cmake" in CMAKE_MODULE_PATH this project has
asked CMake to find a package configuration file provided by "OpenCV", but
CMake did not find one.
Could not find a package configuration file provided by "OpenCV" with any
of the following names:
OpenCVConfig.cmake
opencv-config.cmake
Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
"OpenCV_DIR" to a directory containing one of the above files. If "OpenCV"
provides a separate development package or SDK, be sure it has been
installed.
CMake Warning (dev) at /usr/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.cmake:273 (message):
The package name passed to `find_package_handle_standard_args` (PkgConfig)
does not match the name of the calling package (Gphoto2). This can lead to
problems in calling code that expects `find_package` result variables
(e.g., `_FOUND`) to follow a certain pattern.
Call Stack (most recent call first):
/usr/share/cmake-3.18/Modules/FindPkgConfig.cmake:59 (find_package_handle_standard_args)
cmake/FindGphoto2.cmake:21 (include)
plugins/input_ptp2/CMakeLists.txt:2 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'libgphoto2'
-- No package 'libgphoto2' found
The package name passed to `find_package_handle_standard_args` (GPHOTO2)
cmake/FindGphoto2.cmake:44 (find_package_handle_standard_args)
-- Could NOT find GPHOTO2 (missing: GPHOTO2_LIBRARY GPHOTO2_INCLUDE_DIR)
-- Looking for include file linux/videodev2.h
-- Looking for include file linux/videodev2.h - found
-- Checking for module 'libcamera'
-- Found libcamera, version 0.0.0
PLUGIN_INPUT_LIBCAMERA
-- The CXX compiler identification is GNU 10.2.1
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Could NOT find SDL (missing: SDL_LIBRARY SDL_INCLUDE_DIR)
-- Could NOT find protobuf-c (missing: PROTOBUF_C_LIBRARY PROTOBUF_C_INCLUDE_DIR)
-- The following features have been enabled:
* PLUGIN_INPUT_FILE, File input plugin
* PLUGIN_INPUT_HTTP, HTTP input proxy plugin
* PLUGIN_INPUT_UVC, Video 4 Linux input plugin
* PLUGIN_INPUT_LIBCAMERA, Libcamera input plugin
* PLUGIN_OUTPUT_FILE, File output plugin
* PLUGIN_OUTPUT_HTTP, HTTP server output plugin
* PLUGIN_OUTPUT_RTSP, RTSP output plugin
* PLUGIN_OUTPUT_UDP, UDP output stream plugin
-- The following OPTIONAL packages have been found:
* Threads
-- The following REQUIRED packages have been found:
* PkgConfig
-- The following features have been disabled:
* WXP_COMPAT, Enable compatibility with WebcamXP
* PLUGIN_INPUT_OPENCV, OpenCV input plugin (unmet dependencies)
* PLUGIN_INPUT_RASPICAM, Raspberry Pi input camera plugin (unmet dependencies)
* PLUGIN_INPUT_PTP2, PTP2 input plugin (unmet dependencies)
* ENABLE_HTTP_MANAGEMENT, Enable experimental HTTP management option
* PLUGIN_OUTPUT_VIEWER, SDL output viewer plugin (unmet dependencies)
* PLUGIN_OUTPUT_ZMQSERVER, ZMQ Server output plugin (unmet dependencies)
-- The following OPTIONAL packages have not been found:
* OpenCV
* Gphoto2
* SDL
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build
make -C _build
make[1]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[2]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[3]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
Scanning dependencies of target mjpg_streamer
make[3]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
[ 3%] Building C object CMakeFiles/mjpg_streamer.dir/mjpg_streamer.c.o
[ 7%] Building C object CMakeFiles/mjpg_streamer.dir/utils.c.o
[ 11%] Linking C executable mjpg_streamer
[ 11%] Built target mjpg_streamer
Scanning dependencies of target input_file
[ 14%] Building C object plugins/input_file/CMakeFiles/input_file.dir/input_file.c.o
[ 18%] Linking C shared library input_file.so
[ 18%] Built target input_file
Scanning dependencies of target input_http
[ 22%] Building C object plugins/input_http/CMakeFiles/input_http.dir/input_http.c.o
[ 25%] Building C object plugins/input_http/CMakeFiles/input_http.dir/misc.c.o
[ 29%] Building C object plugins/input_http/CMakeFiles/input_http.dir/mjpg-proxy.c.o
[ 33%] Linking C shared library input_http.so
[ 33%] Built target input_http
Scanning dependencies of target input_uvc
[ 37%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/dynctrl.c.o
[ 40%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/input_uvc.c.o
[ 44%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/jpeg_utils.c.o
[ 48%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/v4l2uvc.c.o
[ 51%] Linking C shared library input_uvc.so
[ 51%] Built target input_uvc
Scanning dependencies of target input_libcamera
[ 55%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o
[ 59%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/LibCamera.cpp.o
[ 62%] Building C object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/jpeg_utils.c.o
[ 66%] Linking CXX shared library input_libcamera.so
[ 66%] Built target input_libcamera
Scanning dependencies of target output_file
[ 70%] Building C object plugins/output_file/CMakeFiles/output_file.dir/output_file.c.o
[ 74%] Linking C shared library output_file.so
[ 74%] Built target output_file
Scanning dependencies of target output_http
[ 77%] Building C object plugins/output_http/CMakeFiles/output_http.dir/httpd.c.o
[ 81%] Building C object plugins/output_http/CMakeFiles/output_http.dir/output_http.c.o
[ 85%] Linking C shared library output_http.so
[ 85%] Built target output_http
Scanning dependencies of target output_rtsp
[ 88%] Building C object plugins/output_rtsp/CMakeFiles/output_rtsp.dir/output_rtsp.c.o
[ 92%] Linking C shared library output_rtsp.so
[ 92%] Built target output_rtsp
Scanning dependencies of target output_udp
[ 96%] Building C object plugins/output_udp/CMakeFiles/output_udp.dir/output_udp.c.o
[100%] Linking C shared library output_udp.so
[100%] Built target output_udp
make[2]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[1]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
