Arducam B0392 imx219 camera not working
Arducam B0392
"Arducam 8MP IMX219 175 Degree Ultra Wide Angle Raspberry Pi Camera Module"
webcam stream fails to load
edit /boot/config.txt
camera_auto_detect=0
dtoverlay=imx219
reboot
(as instructed to in the amazon listing)
Logs (/var/log/webcamd.log, syslog, dmesg, ... no logs, no support)
octoprint-systeminfo-20220821151334.zip (214.5 KB)
octoprint Version 1.8.2
Raspberry Pi 3B+
Try it with the guides from Arducam
You might find some usable information in this thread.
I am following this guide
on step 4 I get this error
pi@octopi:~/mjpg-streamer-libcamera/mjpg-streamer-experimental $ make
[ -d _build ] || mkdir _build
[ -f _build/Makefile ] || (cd _build && cmake  -DCMAKE_BUILD_TYPE=Release ..)
make -C _build
make[1]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[2]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[3]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[3]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
[ 58%] Built target mjpg_streamer
[ 58%] Built target input_file
[ 58%] Built target input_http
[ 58%] Built target input_raspicam
[ 58%] Built target input_uvc
[ 58%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp: In function ‘int input_cmd(int, unsigned int, unsigned int, int)’:
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:480:31: error: ‘AfTrigger’ is not a member of ‘libcamera::controls’
       controls_.set(controls::AfTrigger, 0);
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:480:31: note: suggested alternative:
In file included from /home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.h:21,
                 from /home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:31:
/usr/include/libcamera/libcamera/control_ids.h:140:31: note:   ‘libcamera::controls::draft::AfTrigger’
 extern const Control<int32_t> AfTrigger;
make[3]: *** [plugins/input_libcamera/CMakeFiles/input_libcamera.dir/build.make:63: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:483: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/all] Error 2
make[2]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[1]: *** [Makefile:130: all] Error 2
make[1]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make: *** [Makefile:19: all] Error 2
I just tested it on the latest OctoPi nightly
Bildschirmfoto vom 2022-08-23 06-39-20
try to install those packages
sudo apt -y install cmake libjpeg9-dev
delete the mjpeg streamer folder with
cd
rm -rf mjpg-streamer-libcamera
and repeat step 4 of the guide
pi@octopi:~ $ rm -rf mjpg-streamer-libcamera/
pi@octopi:~ $ git clone https://github.com/ArduCAM/mjpg-streamer.git mjpg-streamer-libcamera
cd mjpg-streamer-libcamera/mjpg-streamer-experimental
make
Cloning into 'mjpg-streamer-libcamera'...
remote: Enumerating objects: 3034, done.
remote: Counting objects: 100% (70/70), done.
remote: Compressing objects: 100% (37/37), done.
remote: Total 3034 (delta 39), reused 51 (delta 33), pack-reused 2964
Receiving objects: 100% (3034/3034), 3.52 MiB | 4.09 MiB/s, done.
Resolving deltas: 100% (1924/1924), done.
-- The C compiler identification is GNU 10.2.1
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
CMAKE_BUILD_TYPE = Release
-- Looking for include file sys/inotify.h
-- Looking for include file sys/inotify.h - found
CMake Warning at plugins/input_opencv/CMakeLists.txt:4 (find_package):
  By not providing "FindOpenCV.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "OpenCV", but
  CMake did not find one.
  Could not find a package configuration file provided by "OpenCV" with any
  of the following names:
    OpenCVConfig.cmake
    opencv-config.cmake
  Add the installation prefix of "OpenCV" to CMAKE_PREFIX_PATH or set
  "OpenCV_DIR" to a directory containing one of the above files.  If "OpenCV"
  provides a separate development package or SDK, be sure it has been
  installed.
CMake Warning (dev) at /usr/share/cmake-3.18/Modules/FindPackageHandleStandardArgs.cmake:273 (message):
  The package name passed to `find_package_handle_standard_args` (PkgConfig)
  does not match the name of the calling package (Gphoto2).  This can lead to
  problems in calling code that expects `find_package` result variables
  (e.g., `_FOUND`) to follow a certain pattern.
Call Stack (most recent call first):
  /usr/share/cmake-3.18/Modules/FindPkgConfig.cmake:59 (find_package_handle_standard_args)
  cmake/FindGphoto2.cmake:21 (include)
  plugins/input_ptp2/CMakeLists.txt:2 (find_package)
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.29.2")
-- Checking for module 'libgphoto2'
--   No package 'libgphoto2' found
  The package name passed to `find_package_handle_standard_args` (GPHOTO2)
  cmake/FindGphoto2.cmake:44 (find_package_handle_standard_args)
-- Could NOT find GPHOTO2 (missing: GPHOTO2_LIBRARY GPHOTO2_INCLUDE_DIR)
-- Looking for include file linux/videodev2.h
-- Looking for include file linux/videodev2.h - found
-- Checking for module 'libcamera'
--   Found libcamera, version 0.0.0
PLUGIN_INPUT_LIBCAMERA
-- The CXX compiler identification is GNU 10.2.1
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Failed
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Could NOT find SDL (missing: SDL_LIBRARY SDL_INCLUDE_DIR)
-- Could NOT find protobuf-c (missing: PROTOBUF_C_LIBRARY PROTOBUF_C_INCLUDE_DIR)
-- The following features have been enabled:
 * PLUGIN_INPUT_FILE, File input plugin
 * PLUGIN_INPUT_HTTP, HTTP input proxy plugin
 * PLUGIN_INPUT_UVC, Video 4 Linux input plugin
 * PLUGIN_INPUT_LIBCAMERA, Libcamera input plugin
 * PLUGIN_OUTPUT_FILE, File output plugin
 * PLUGIN_OUTPUT_HTTP, HTTP server output plugin
 * PLUGIN_OUTPUT_RTSP, RTSP output plugin
 * PLUGIN_OUTPUT_UDP, UDP output stream plugin
-- The following OPTIONAL packages have been found:
 * Threads
-- The following REQUIRED packages have been found:
 * PkgConfig
-- The following features have been disabled:
 * WXP_COMPAT, Enable compatibility with WebcamXP
 * PLUGIN_INPUT_OPENCV, OpenCV input plugin (unmet dependencies)
 * PLUGIN_INPUT_RASPICAM, Raspberry Pi input camera plugin (unmet dependencies)
 * PLUGIN_INPUT_PTP2, PTP2 input plugin (unmet dependencies)
 * ENABLE_HTTP_MANAGEMENT, Enable experimental HTTP management option
 * PLUGIN_OUTPUT_VIEWER, SDL output viewer plugin (unmet dependencies)
 * PLUGIN_OUTPUT_ZMQSERVER, ZMQ Server output plugin (unmet dependencies)
-- The following OPTIONAL packages have not been found:
 * OpenCV
 * Gphoto2
 * SDL
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build
make -C _build
Scanning dependencies of target mjpg_streamer
[  3%] Building C object CMakeFiles/mjpg_streamer.dir/mjpg_streamer.c.o
[  7%] Building C object CMakeFiles/mjpg_streamer.dir/utils.c.o
[ 11%] Linking C executable mjpg_streamer
[ 11%] Built target mjpg_streamer
Scanning dependencies of target input_file
[ 14%] Building C object plugins/input_file/CMakeFiles/input_file.dir/input_file.c.o
[ 18%] Linking C shared library input_file.so
[ 18%] Built target input_file
Scanning dependencies of target input_http
[ 22%] Building C object plugins/input_http/CMakeFiles/input_http.dir/input_http.c.o
[ 25%] Building C object plugins/input_http/CMakeFiles/input_http.dir/misc.c.o
[ 29%] Building C object plugins/input_http/CMakeFiles/input_http.dir/mjpg-proxy.c.o
[ 33%] Linking C shared library input_http.so
[ 33%] Built target input_http
Scanning dependencies of target input_uvc
[ 37%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/dynctrl.c.o
[ 40%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/input_uvc.c.o
[ 44%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/jpeg_utils.c.o
[ 48%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/v4l2uvc.c.o
[ 51%] Linking C shared library input_uvc.so
[ 51%] Built target input_uvc
Scanning dependencies of target input_libcamera
[ 55%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o
[ 59%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/LibCamera.cpp.o
[ 62%] Building C object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/jpeg_utils.c.o
[ 66%] Linking CXX shared library input_libcamera.so
[ 66%] Built target input_libcamera
Scanning dependencies of target output_file
[ 70%] Building C object plugins/output_file/CMakeFiles/output_file.dir/output_file.c.o
[ 74%] Linking C shared library output_file.so
[ 74%] Built target output_file
Scanning dependencies of target output_http
[ 77%] Building C object plugins/output_http/CMakeFiles/output_http.dir/httpd.c.o
[ 81%] Building C object plugins/output_http/CMakeFiles/output_http.dir/output_http.c.o
[ 85%] Linking C shared library output_http.so
[ 85%] Built target output_http
Scanning dependencies of target output_rtsp
[ 88%] Building C object plugins/output_rtsp/CMakeFiles/output_rtsp.dir/output_rtsp.c.o
[ 92%] Linking C shared library output_rtsp.so
[ 92%] Built target output_rtsp
Scanning dependencies of target output_udp
[ 96%] Building C object plugins/output_udp/CMakeFiles/output_udp.dir/output_udp.c.o
[100%] Linking C shared library output_udp.so
[100%] Built target output_udp
after installing nightly octoprint onto a new sd card and following that guide I have the camera showing up.
/boot/octopi.txt
camera="libcamera"
camera_libcamera_options="-r 1280x720 -f 15"
the camera will show up for a few minutes and then it will say the webcam stream failed to load
if I run
sudo systemctl restart webcamd
the camera will come back up for a few minutes and then it will go away
if I do
sudo systemctl status webcamd
after the camera goes away. I see
pi@octopi:~ $ sudo systemctl status webcamd
● webcamd.service - the OctoPi webcam daemon with the user specified config
     Loaded: loaded (/etc/systemd/system/webcamd.service; enabled; vendor preset: enabled)
     Active: active (running) since Wed 2022-08-24 16:04:30 PDT; 14min ago
   Main PID: 20794 (webcamd)
      Tasks: 2 (limit: 1472)
        CPU: 5min 45.433s
     CGroup: /system.slice/webcamd.service
             ├─20794 /bin/bash /root/bin/webcamd
             └─21337 sleep 120
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: MJPG Streamer Version: git rev: d3bb80e4061d5d0b85170bb601074ed78b49516e
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: Desired Resolution: 1280 x 720
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: www-folder-path......: -n/
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: HTTP TCP port........: 8080
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: HTTP Listen Address..: (null)
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: username:password....: disabled
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: commands.............: enabled
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: starting input plugin input_libcamera.so
Aug 24 16:16:10 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: starting output plugin: output_http.so (ID: 00)
Aug 24 16:18:07 octopi mjpg_streamer[21242]: MJPG-streamer [21242]: switch_resolution(): Failed to switch camera resolution.
should I remove the resolution flag and let it automatically select?
I changed my config to look like this
#/boot/octopi.txt
camera="libcamera"
camera_libcamera_options=""
still getting this error
     Active: active (running) since Thu 2022-08-25 11:59:26 PDT; 6min ago
   Main PID: 1539 (webcamd)
        CPU: 2min 45.455s
             ├─1539 /bin/bash /root/bin/webcamd
             └─1800 sleep 120
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: MJPG Streamer Version: git rev: d3bb80e4061d5d0b85170bb601074ed78b49516e
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: Desired Resolution: 640 x 480
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: www-folder-path......: -n/
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: HTTP TCP port........: 8080
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: HTTP Listen Address..: (null)
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: username:password....: disabled
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: commands.............: enabled
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: starting input plugin input_libcamera.so
Aug 25 12:03:02 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: starting output plugin: output_http.so (ID: 00)
Aug 25 12:04:04 octopi mjpg_streamer[1715]: MJPG-streamer [1715]: switch_resolution(): Failed to switch camera resolution.
pi@octopi:~ $
here is a new system info bundle incase that is helpful
octoprint-systeminfo-20220825120804.zip (846.5 KB)
