Arducam Raspberry Pi Noir Camera Module, 8MP IMX219 (https://smile.amazon.com/gp/product/B085HLP8FN/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
Webcamd doesn't appear to start / crashes.
Enabled camera in /boot/octopi.txt
/var/log/webcamd.log contents
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: raspi
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
Scan again in two minutes
/root/bin/webcamd: line 103: kill: (432) - No such process
Goodbye...
(This repeats again and again)
grep -i webcam /var/log/syslog
Jun 10 16:04:50 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jun 10 16:06:20 octopi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Jun 10 16:06:20 octopi systemd[1]: webcamd.service: Failed with result 'timeout'.
Jun 10 16:06:20 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
Jun 10 16:06:21 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Jun 10 16:06:21 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 724.
Jun 10 16:06:21 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Jun 10 16:06:21 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jun 10 16:07:51 octopi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Jun 10 16:07:51 octopi systemd[1]: webcamd.service: Failed with result 'timeout'.
Jun 10 16:07:51 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
Jun 10 16:07:53 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Jun 10 16:07:53 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 725.
Jun 10 16:07:53 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Jun 10 16:07:53 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jun 10 15:52:14 octopi systemd[1]: Condition check resulted in FFMPEG HLS webcam streaming service being skipped.
Jun 10 15:52:14 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Jun 10 15:52:31 octopi octoprint[322]: | Sidebar Webcam (0.1.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_webcamSB
Jun 10 15:52:38 octopi octoprint[322]: 2021-06-10 15:52:38,071 - octoprint.plugins.webcamSB - INFO - Sidebar Webcam LOADED
Jun 10 15:52:39 octopi octoprint[322]: 2021-06-10 15:52:39,001 - octoprint.plugins.thespaghettidetective - INFO - Starting webcam streamer
Jun 10 15:52:42 octopi systemd[1]: webcamd.service: Succeeded.
Jun 10 15:52:42 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
Jun 10 15:52:43 octopi octoprint[322]: 2021-06-10 15:52:43,063 - octoprint.plugins.thespaghettidetective - WARNING - No camera detected. Skipping webcam streaming
DMESG output
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.79-v7+ (dom@buildbot) (gcc version 8.4.0 (Ubuntu/Linaro 8.4.0-3ubuntu1)) #1373 SMP Mon Nov 23 13:22:33 GMT 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x34000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 229376
[ 0.000000] Normal zone: 2016 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 229376 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49740 r8192 d23988 u81920
[ 0.000000] pcpu-alloc: s49740 r8192 d23988 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=47ecb017-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 827696K/917504K available (9216K kernel code, 698K rwdata, 2608K rodata, 1024K init, 827K bss, 24272K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 29201 entries in 58 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x324/0x4f8 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000289] Console: colour dummy device 80x30
[ 0.000882] printk: console [tty1] enabled
[ 0.000946] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000994] pid_max: default: 32768 minimum: 301
[ 0.001201] LSM: Security Framework initializing
[ 0.001436] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001483] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002948] Disabling memory control group subsystem
[ 0.003089] CPU: Testing write buffer coherency: ok
[ 0.003673] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004633] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004849] rcu: Hierarchical SRCU implementation.
[ 0.005554] smp: Bringing up secondary CPUs ...
[ 0.006695] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007969] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009135] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009288] smp: Brought up 1 node, 4 CPUs
[ 0.009377] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009406] CPU: All CPU(s) started in HYP mode.
[ 0.009431] CPU: Virtualization extensions available.
[ 0.010519] devtmpfs: initialized
[ 0.026643] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.026955] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027012] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.030350] pinctrl core: initialized pinctrl subsystem
[ 0.031476] NET: Registered protocol family 16
[ 0.035683] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.040533] audit: initializing netlink subsys (disabled)
[ 0.040831] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.042178] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.042217] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.042450] Serial: AMBA PL011 UART driver
[ 0.044427] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.070102] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-11-25 17:13, variant start_x
[ 0.080116] raspberrypi-firmware soc:firmware: Firmware hash is 2e6292a5304b95ecfd700fc5ab2b793402056332
[ 0.131579] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.133773] SCSI subsystem initialized
[ 0.134047] usbcore: registered new interface driver usbfs
[ 0.134130] usbcore: registered new interface driver hub
[ 0.134275] usbcore: registered new device driver usb
[ 0.136147] clocksource: Switched to clocksource arch_sys_counter
[ 1.396894] VFS: Disk quotas dquot_6.6.0
[ 1.397032] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.397247] FS-Cache: Loaded
[ 1.397536] CacheFiles: Loaded
[ 1.408840] thermal_sys: Registered thermal governor 'step_wise'
[ 1.409226] NET: Registered protocol family 2
[ 1.410247] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.410321] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.410464] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.410674] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.410859] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.410933] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.411244] NET: Registered protocol family 1
[ 1.412043] RPC: Registered named UNIX socket transport module.
[ 1.412076] RPC: Registered udp transport module.
[ 1.412102] RPC: Registered tcp transport module.
[ 1.412129] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.413789] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.417197] Initialise system trusted keyrings
[ 1.417487] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.429087] FS-Cache: Netfs 'nfs' registered for caching
[ 1.429948] NFS: Registering the id_resolver key type
[ 1.430004] Key type id_resolver registered
[ 1.430031] Key type id_legacy registered
[ 1.430067] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.431371] Key type asymmetric registered
[ 1.431401] Asymmetric key parser 'x509' registered
[ 1.431481] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.431519] io scheduler mq-deadline registered
[ 1.431546] io scheduler kyber registered
[ 1.435010] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.447727] Console: switching to colour frame buffer device 82x26
[ 1.454835] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.464758] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.467855] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.473577] vc-sm: Videocore shared memory driver
[ 1.476636] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.494446] brd: module loaded
[ 1.509399] loop: module loaded
[ 1.513288] Loading iSCSI transport class v2.0-870.
[ 1.516922] libphy: Fixed MDIO Bus: probed
[ 1.519595] usbcore: registered new interface driver lan78xx
[ 1.522234] usbcore: registered new interface driver smsc95xx
[ 1.524775] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.255626] Core Release: 2.80a
[ 2.258075] Setting default values for core params
[ 2.260523] Finished setting default values for core params
[ 2.463402] Using Buffer DMA mode
[ 2.465868] Periodic Transfer Interrupt Enhancement - disabled
[ 2.468404] Multiprocessor Interrupt Enhancement - disabled
[ 2.470890] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.473307] Dedicated Tx FIFOs mode
[ 2.476284] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = b4114000 dma = 0xf4114000 len=9024
[ 2.481044] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.492222] dwc_otg: Microframe scheduler enabled
[ 2.492293] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.494555] WARN::hcd_init_fiq:458: FIQ ASM at 8070b948 length 36
[ 2.496823] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 2.499061] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.501382] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.503765] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 2.506094] Init: Port Power? op_state=1
[ 2.508391] Init: Power Port (0)
[ 2.510947] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 2.515493] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.517952] usb usb1: Product: DWC OTG Controller
[ 2.520339] usb usb1: Manufacturer: Linux 5.4.79-v7+ dwc_otg_hcd
[ 2.522780] usb usb1: SerialNumber: 3f980000.usb
[ 2.525857] hub 1-0:1.0: USB hub found
[ 2.528207] hub 1-0:1.0: 1 port detected
[ 2.531136] dwc_otg: FIQ enabled
[ 2.531146] dwc_otg: NAK holdoff enabled
[ 2.531155] dwc_otg: FIQ split-transaction FSM enabled
[ 2.531170] Module dwc_common_port init
[ 2.531508] usbcore: registered new interface driver usb-storage
[ 2.534014] mousedev: PS/2 mouse device common for all mice
[ 2.537542] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.542879] sdhci: Secure Digital Host Controller Interface driver
[ 2.545320] sdhci: Copyright(c) Pierre Ossman
[ 2.548313] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.551475] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.554273] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.558696] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.561655] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.564424] usbcore: registered new interface driver usbhid
[ 2.567058] usbhid: USB HID core driver
[ 2.570637] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.574982] [vc_sm_connected_init]: start
[ 2.583777] [vc_sm_connected_init]: end - returning 0
[ 2.588180] Initializing XFRM netlink socket
[ 2.590572] NET: Registered protocol family 17
[ 2.593055] Key type dns_resolver registered
[ 2.595990] Registering SWP/SWPB emulation handler
[ 2.598723] registered taskstats version 1
[ 2.601105] Loading compiled-in X.509 certificates
[ 2.603975] Key type ._fscrypt registered
[ 2.606332] Key type .fscrypt registered
[ 2.619407] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.621834] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.628415] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.632315] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.634714] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.663627] sdhost: log_buf @ (ptrval) (f4113000)
[ 2.703154] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.707127] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.711001] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.715563] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.720329] of_cfs_init
[ 2.722714] of_cfs_init: OK
[ 2.725765] Waiting for root device PARTUUID=47ecb017-02...
[ 2.738288] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.746315] Indeed it is in host mode hprt0 = 00021501
[ 2.820065] random: fast init done
[ 2.867859] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.878908] mmc0: new high speed SDHC card at address aaaa
[ 2.881829] mmc1: new high speed SDIO card at address 0001
[ 2.885154] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
[ 2.891180] mmcblk0: p1 p2
[ 2.916693] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 2.918955] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 2.956200] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.958595] Indeed it is in host mode hprt0 = 00001101
[ 3.196516] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.201139] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.204535] hub 1-1:1.0: USB hub found
[ 3.207287] hub 1-1:1.0: 4 ports detected
[ 3.356409] EXT4-fs (mmcblk0p2): recovery complete
[ 3.364384] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.369710] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.381466] devtmpfs: mounted
[ 3.390736] Freeing unused kernel memory: 1024K
[ 3.393847] Run /sbin/init as init process
[ 3.526200] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.656599] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.662034] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.665687] hub 1-1.1:1.0: USB hub found
[ 3.668668] hub 1-1.1:1.0: 3 ports detected
[ 3.986210] usb 1-1.1.3: new full-speed USB device number 4 using dwc_otg
[ 4.021660] systemd[1]: System time before build time, advancing clock.
[ 4.119271] usb 1-1.1.3: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
[ 4.124752] usb 1-1.1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 4.130293] usb 1-1.1.3: Product: USB Serial
[ 4.179164] NET: Registered protocol family 10
[ 4.183520] Segment Routing with IPv6
[ 4.228585] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 4.250459] systemd[1]: Detected architecture arm.
[ 4.328821] systemd[1]: Set hostname to <octopi>.
[ 4.456298] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[ 4.586876] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 4.592503] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.873160] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 4.880272] libphy: lan78xx-mdiobus: probed
[ 4.923166] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.269162] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.286478] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.290793] systemd[1]: Listening on Journal Socket.
[ 5.297741] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.303926] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 5.311361] systemd[1]: Listening on udev Control Socket.
[ 5.318700] systemd[1]: Listening on Syslog Socket.
[ 5.326751] systemd[1]: Created slice system-getty.slice.
[ 5.333366] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 5.339917] systemd[1]: Listening on udev Kernel Socket.
[ 5.504694] i2c /dev entries driver
[ 6.140574] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 6.280048] systemd-journald[124]: Received request to flush runtime journal from PID 1
[ 6.833974] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.837359] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.837383] [vc_sm_connected_init]: start
[ 6.852317] [vc_sm_connected_init]: installed successfully
[ 6.868995] mc: Linux media interface: v0.10
[ 6.911344] videodev: Linux video capture interface: v2.00
[ 6.995567] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.995572] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.998166] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.008721] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.015958] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 7.022482] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.025860] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.031449] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.274953] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.404756] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.463736] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.478605] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.479078] usbcore: registered new interface driver brcmfmac
[ 7.524088] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.txt failed with error -2
[ 7.635941] usbcore: registered new interface driver usbserial_generic
[ 7.642199] usbserial: USB Serial support registered for generic
[ 7.645906] usbcore: registered new interface driver ch341
[ 7.645989] usbserial: USB Serial support registered for ch341-uart
[ 7.646118] ch341 1-1.1.3:1.0: ch341-uart converter detected
[ 7.651097] usb 1-1.1.3: ch341-uart converter now attached to ttyUSB0
[ 7.662584] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.663272] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.664176] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.664238] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.674449] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.674500] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.677354] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.677954] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.677997] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.678021] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.678039] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.678070] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.681652] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.681710] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.682407] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.815218] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.832872] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Mar 23 2020 02:19:54 version 7.45.206 (r725000 CY) FWID 01-88ee44ea
[ 9.679669] uart-pl011 3f201000.serial: no DMA platform data
[ 9.928298] random: crng init done
[ 9.928321] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.176208] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 10.219387] 8021q: 802.1Q VLAN Support v1.8
[ 10.512151] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.819601] 8021q: adding VLAN 0 to HW filter on device eth0
[ 12.870724] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.039085] Bluetooth: Core ver 2.22
[ 17.039171] NET: Registered protocol family 31
[ 17.039179] Bluetooth: HCI device and connection manager initialized
[ 17.039472] Bluetooth: HCI socket layer initialized
[ 17.039487] Bluetooth: L2CAP socket layer initialized
[ 17.039512] Bluetooth: SCO socket layer initialized
[ 17.058894] Bluetooth: HCI UART driver ver 2.3
[ 17.058908] Bluetooth: HCI UART protocol H4 registered
[ 17.058977] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 17.059199] Bluetooth: HCI UART protocol Broadcom registered
[ 17.318229] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.318240] Bluetooth: BNEP filters: protocol multicast
[ 17.318260] Bluetooth: BNEP socket layer initialized
Contents of /boot/octopi.txt (commented lines removed)
camera="raspi"
camera_raspi_options="-fps 10"
System Information
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/14.1.1 Safari/605.1.15
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1400
env.hardware.ram: 915718144
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.throttle_state: 0x80000
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
printer.firmware: Marlin Ver 1.0.2
output of systemctl stats webcamd
β webcamd.service - the OctoPi webcam daemon with the user specified config
Active: inactive (dead) since Thu 2021-06-10 15:52:42 BST; 54min ago
Process: 412 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
