Automatic boot doesn't work
I can run ~/OctoPrint/venv/bin/octoprint serve to start the octoprint UI, just can't make it start automatically on boot, it doesn't give an error, it says "Executing: /lib/systemd/systemd-sysv-install enable octoprint" but does nothing
Tried following this guide link
Yep
Nope
octoprint-systeminfo-20220121203711.zip (42.2 KB)
I'm running 1.7.3 (updated thanks to this community) on an Ubuntu desktop, couldn't find any RPis online under 100 bucks
Not sure how I missed the link Link
when and where does it say that?
It says it in the terminal when I run the command listed below
sudo systemctl enable octoprint.service
Nevermind, fixed it
And the issue was?
Not sure, I just ran the stuff from this guide, and it fixed my problem Setting up OctoPrint on Ubuntu 20.04 with Python 3 | Illuminated3D
Did you remove everything from the previous attempt?
Just randomly mixing guides and not knowing what your doing is a dangerous combination:
Might work but could also have unpredictable consequences.
And now I can’t automatically boot up mjpeg streamer, says it’s running but when i refresh octoprint UI, nothing, do I have to reboot for it to take effect?
