Octoprint disconnects itself from the printer randomly. It is not a problem to restart the Raspberry because the uptime doesn't return to zero after the communication is cut.
When an Octoprint serial break does not pause.
In my case the printer is just waiting for further instructions, in the logs I can see that the connection comes back but octoprint doesn't do anything anymore.
Full reinstallation of Octoprint
Try it with several USB cables
Removal of plugins
Testing of different communication speeds
Trying version 1.5RC, the bug is less present than with version 14, but it still occurs a few times.
Testing of linux update (apt update/upgrade)
Option "Request exclusive access to the serial port" unselected
Increase option "Max. consecutive timeouts during long running commands"
Unresolved Issue
Complete Logs
Octoprint.log
2020-11-20 15:59:33,258 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: nichoir_oiseau/RIGHT_WALL.aw.gcode, owner: gaetan, user: gaetan
2020-11-20 15:59:33,281 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-11-20 15:59:33,282 - octoprint.plugins.DisplayLayerProgress - INFO - File '/home/pi/.octoprint/uploads/nichoir_oiseau/RIGHT_WALL.aw.gcode' selected. Determining number of layers.
2020-11-20 15:59:33,289 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: nichoir_oiseau/RIGHT_WALL.aw.gcode, owner: gaetan, user: gaetan
2020-11-20 15:59:33,317 - octoprint.plugins.DisplayLayerProgress - INFO - Read total height from MetaFile
2020-11-20 15:59:33,384 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-11-20 15:59:33,417 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-11-20 15:59:33,955 - octoprint.plugins.DisplayLayerProgress - INFO - Store layer count in MetaFile
2020-11-20 15:59:33,971 - octoprint.plugins.DisplayLayerProgress - INFO - File select-event processing done!'
2020-11-20 15:59:34,021 - octoprint.plugins.DisplayLayerProgress - INFO - Printing started. Detailed progress started.{u'origin': u'local', u'name': u'RIGHT_WALL.aw.gcode', u'user': 'gaetan', u'owner': 'gaetan', u'path': u'nichoir_oiseau/RIGHT_WALL.aw.gcode', u'size': 2926977L}
2020-11-20 15:59:34,221 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {u'origin': u'local', u'file': '760ec7c1b683aa4bf610d1f5cbe3679c3a77cb39'}
2020-11-20 15:59:35,546 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2020-11-20 16:01:22,667 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 4s
2020-11-20 16:11:44,670 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-20 16:11:52,030 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 907}
2020-11-20 16:26:44,671 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-20 16:26:52,028 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1807}
2020-11-20 16:41:44,673 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-20 16:41:52,065 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 2707}
2020-11-20 16:56:44,675 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-20 16:56:52,040 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 3607}
2020-11-20 17:11:44,678 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-11-20 17:11:52,438 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 4507}
2020-11-20 17:16:12,730 - octoprint.util.comm - INFO - , trying to trigger response from printer.
2020-11-20 17:16:17,748 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:22,766 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:27,779 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:32,796 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:37,817 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:42,834 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:47,850 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:52,869 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:16:57,884 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:02,903 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:07,921 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:12,938 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:17,959 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:22,973 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:27,992 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:33,010 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:38,027 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:41,423 - octoprint.util.comm - INFO - Pausing/resuming job on behalf of user gaetan
2020-11-20 17:17:41,427 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2020-11-20 17:17:43,044 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2020-11-20 17:17:48,060 - octoprint.util.comm - INFO - No response from printer after 6 consecutive communication timeouts, considering it dead.
2020-11-20 17:17:48,120 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2020-11-20 17:17:48,158 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-11-20 17:17:48,356 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_timeout, payload: {u'commerror_text': u'Too many consecutive timeouts, printer still connected and alive?'}
2020-11-20 17:18:00,257 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-11-20 17:18:00,264 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-11-20 17:18:00,302 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-11-20 17:18:02,081 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-11-20 17:18:03,989 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-11-20 17:18:04,007 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-11-20 17:18:04,028 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2020-11-20 17:18:04,034 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2020-11-20 17:18:04,111 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.7.1 (Nov 3 2020"
2020-11-20 17:18:04,133 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-11-20 17:18:04,291 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 115200, u'printer_port': u'/dev/ttyUSB0', u'firmware_name': u'Marlin 2.0.7.1 (Nov 3 2020'}
Serial.log (End of log only)
2020-11-20 17:16:04,687 - Send: N41406 G1 X117.123 Y144.879 E4.9576*92
2020-11-20 17:16:04,816 - Recv: ok
2020-11-20 17:16:04,821 - Send: N41407 G1 X121.079 Y140.924 E5.1502*81
2020-11-20 17:16:04,851 - Recv: ok
2020-11-20 17:16:04,856 - Send: N41408 G1 X120.459 Y140.907 E5.1715*92
2020-11-20 17:16:04,947 - Recv: ok
2020-11-20 17:16:04,952 - Send: N41409 G1 X116.481 Y144.885 E5.3652*82
2020-11-20 17:16:04,978 - Recv: ok
2020-11-20 17:16:04,982 - Send: N41410 G1 X115.838 Y144.891 E5.3873*95
2020-11-20 17:16:05,107 - Recv: ok
2020-11-20 17:16:05,112 - Send: N41411 M117 66% L=20/33*92
2020-11-20 17:16:05,119 - Recv: ok
2020-11-20 17:16:05,122 - Send: N41412 G1 X119.839 Y140.891 E5.5821*85
2020-11-20 17:16:05,141 - Recv: ok
2020-11-20 17:16:05,145 - Send: N41413 G1 X119.219 Y140.874 E5.6034*88
2020-11-20 17:16:05,245 - Recv: ok
2020-11-20 17:16:05,249 - Send: N41414 G1 X115.199 Y144.894 E5.7991*85
2020-11-20 17:16:05,275 - Recv: ok
2020-11-20 17:16:05,279 - Send: N41415 G1 X114.560 Y144.897 E5.8211*88
2020-11-20 17:16:05,406 - Recv: ok
2020-11-20 17:16:05,411 - Send: N41416 G1 X118.599 Y140.858 E6.0178*81
2020-11-20 17:16:05,416 - Recv: T:189.79 /190.00 B:49.97 /50.00 @:60 B@:31
2020-11-20 17:16:05,440 - Recv: ok
2020-11-20 17:16:05,444 - Send: N41417 G1 X117.979 Y140.841 E6.0391*80
2020-11-20 17:16:05,544 - Recv: ok
2020-11-20 17:16:05,548 - Send: N41418 G1 X113.921 Y144.900 E6.2367*93
2020-11-20 17:16:05,575 - Recv: ok
2020-11-20 17:16:05,579 - Send: N41419 G1 X113.282 Y144.902 E6.2587*84
2020-11-20 17:16:05,705 - Recv: ok
2020-11-20 17:16:05,709 - Send: N41420 G1 X117.359 Y140.825 E6.4572*81
2020-11-20 17:16:05,739 - Recv: ok
2020-11-20 17:16:05,743 - Send: N41421 G2 X116.736 Y140.811 I-0.906 J26.433 E6.47869*121
2020-11-20 17:16:06,349 - Recv: ok
2020-11-20 17:16:06,354 - Send: N41422 G1 X112.642 Y144.905 E6.6780*83
2020-11-20 17:16:06,456 - Recv: ok
2020-11-20 17:16:06,460 - Send: N41423 G1 X112.003 Y144.908 E6.7000*82
2020-11-20 17:16:06,484 - Recv: ok
2020-11-20 17:16:06,488 - Send: N41424 G1 X116.113 Y140.798 E6.9001*93
2020-11-20 17:16:06,619 - Recv: ok
2020-11-20 17:16:06,622 - Send: N41425 G1 X115.490 Y140.785 E6.9215*90
2020-11-20 17:16:06,653 - Recv: ok
2020-11-20 17:16:06,657 - Send: N41426 G1 X111.364 Y144.910 E7.1224*92
2020-11-20 17:16:06,761 - Recv: ok
2020-11-20 17:16:06,764 - Send: N41427 G1 X110.725 Y144.913 E7.1444*94
2020-11-20 17:16:06,791 - Recv: ok
2020-11-20 17:16:06,795 - Send: N41428 G1 X114.866 Y140.772 E7.3460*84
2020-11-20 17:16:06,935 - Recv: ok
2020-11-20 17:16:06,940 - Send: N41429 G1 X114.243 Y140.759 E7.3674*86
2020-11-20 17:16:06,954 - Recv: ok
2020-11-20 17:16:06,958 - Send: N41430 G1 X110.086 Y144.916 E7.5698*84
2020-11-20 17:16:06,969 - Recv: ok
2020-11-20 17:16:06,974 - Send: N41431 G1 X109.447 Y144.918 E7.5918*93
2020-11-20 17:16:06,985 - Recv: ok
2020-11-20 17:16:06,990 - Send: N41432 G1 X113.619 Y140.746 E7.7949*91
2020-11-20 17:16:07,001 - Recv: ok
2020-11-20 17:16:07,008 - Send: N41433 G1 X112.996 Y140.733 E7.8164*89
2020-11-20 17:16:07,019 - Recv: ok
2020-11-20 17:16:07,024 - Send: N41434 G1 X108.808 Y144.921 E8.0202*94
2020-11-20 17:16:07,035 - Recv: ok
2020-11-20 17:16:07,038 - Send: N41435 G1 X108.169 Y144.924 E8.0422*80
2020-11-20 17:16:07,049 - Recv: ok
2020-11-20 17:16:07,053 - Send: N41436 G1 X112.372 Y140.720 E8.2469*83
2020-11-20 17:16:07,064 - Recv: ok
2020-11-20 17:16:07,067 - Send: N41437 G1 X111.749 Y140.707 E8.2684*89
2020-11-20 17:16:07,082 - Recv: ok
2020-11-20 17:16:07,088 - Send: N41438 G1 X107.530 Y144.926 E8.4737*91
2020-11-20 17:16:07,102 - Recv: ok
2020-11-20 17:16:07,105 - Send: N41439 G1 X106.891 Y144.929 E8.4957*90
2020-11-20 17:16:07,237 - Recv: ok
2020-11-20 17:16:07,242 - Send: N41440 G1 X111.125 Y140.694 E8.7019*89
2020-11-20 17:16:07,272 - Recv: ok
2020-11-20 17:16:07,276 - Send: N41441 G1 X110.502 Y140.681 E8.7234*81
2020-11-20 17:16:07,382 - Recv: ok
2020-11-20 17:16:07,386 - Send: N41442 G1 X106.252 Y144.932 E8.9303*95
2020-11-20 17:16:07,415 - Recv: T:189.69 /190.00 B:50.03 /50.00 @:61 B@:22
2020-11-20 17:16:07,420 - Recv: ok
2020-11-20 17:16:07,425 - Send: N41443 G1 X105.613 Y144.934 E8.9523*94
2020-11-20 17:16:07,549 - Recv: ok
2020-11-20 17:16:07,553 - Send: N41444 G1 X109.878 Y140.669 E9.1600*94
2020-11-20 17:16:07,583 - Recv: ok
2020-11-20 17:16:07,598 - Send: N41445 G1 X109.255 Y140.656 E9.1814*93
2020-11-20 17:16:07,694 - Recv: ok
2020-11-20 17:16:07,698 - Send: N41446 G1 X104.974 Y144.937 E9.3899*80
2020-11-20 17:16:07,724 - Recv: ok
2020-11-20 17:16:07,728 - Send: N41447 G1 X104.334 Y144.940 E9.4119*89
2020-11-20 17:16:12,731 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:12,744 - Send: N41448 M105*42
2020-11-20 17:16:17,750 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:17,762 - Send: N41449 M105*43
2020-11-20 17:16:22,767 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:22,779 - Send: N41450 M105*35
2020-11-20 17:16:27,784 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:27,793 - Send: N41451 M105*34
2020-11-20 17:16:32,799 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:32,812 - Send: N41452 M105*33
2020-11-20 17:16:37,819 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:37,828 - Send: N41453 M105*32
2020-11-20 17:16:42,836 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:42,848 - Send: N41454 M105*39
2020-11-20 17:16:47,852 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:47,864 - Send: N41455 M105*38
2020-11-20 17:16:52,873 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:52,888 - Send: N41456 M105*37
2020-11-20 17:16:57,886 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:16:57,899 - Send: N41457 M105*36
2020-11-20 17:17:02,905 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:02,918 - Send: N41458 M105*43
2020-11-20 17:17:07,923 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:07,935 - Send: N41459 M105*42
2020-11-20 17:17:12,940 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:12,950 - Send: N41460 M105*32
2020-11-20 17:17:17,960 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:17,971 - Send: N41461 M105*33
2020-11-20 17:17:22,975 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:22,987 - Send: N41462 M105*34
2020-11-20 17:17:27,995 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:28,007 - Send: N41463 M105*35
2020-11-20 17:17:33,012 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:33,024 - Send: N41464 M105*36
2020-11-20 17:17:38,035 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:38,041 - Send: N41465 M105*37
2020-11-20 17:17:41,425 - Changing monitoring state from "Printing" to "Pausing"
2020-11-20 17:17:43,045 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:43,057 - Send: N41466 M400*38
2020-11-20 17:17:48,062 - No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-11-20 17:17:48,116 - Changing monitoring state from "Pausing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2020-11-20 17:17:48,133 - Connection closed, closing down monitor
2020-11-20 17:17:58,061 - Did not receive parseable position data from printer within 15.0s, continuing without it
2020-11-20 17:18:00,256 - Changing monitoring state from "Offline" to "Opening serial connection"
2020-11-20 17:18:00,268 - Connecting to port /dev/ttyUSB0, baudrate 115200
2020-11-20 17:18:00,299 - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-11-20 17:18:00,316 - Connected to: Serial<id=0xab85aa30, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-11-20 17:18:02,067 - Recv: echo:start
2020-11-20 17:18:02,082 - Recv: Marlin 2.0.7.1
2020-11-20 17:18:02,088 - Recv:
2020-11-20 17:18:02,091 - Send: N0 M110 N0*125
2020-11-20 17:18:02,093 - Recv: echo: Last Updated: 2020-10-10 | Author: (thisiskeithb, Ender-5 Pro)
2020-11-20 17:18:02,098 - Recv: echo:Compiled: Nov 3 2020
2020-11-20 17:18:02,102 - Recv: echo: Free Memory: 12930 PlannerBufferBytes: 1200
2020-11-20 17:18:02,105 - Recv: echo:V81 stored settings retrieved (657 bytes; crc 55774)
2020-11-20 17:18:03,975 - Recv: ok
2020-11-20 17:18:03,988 - Changing monitoring state from "Connecting" to "Operational"
2020-11-20 17:18:04,024 - Send: N0 M110 N0*125
2020-11-20 17:18:04,074 - Recv: ok
2020-11-20 17:18:04,077 - Send: N1 M115*39
2020-11-20 17:18:04,109 - Recv: FIRMWARE_NAME:Marlin 2.0.7.1 (Nov 3 2020 23:41:23) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Marlin 2.0.7.1 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-11-20 17:18:04,117 - Recv: Cap:SERIAL_XON_XOFF:0
2020-11-20 17:18:04,122 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-11-20 17:18:04,126 - Recv: Cap:EEPROM:1
2020-11-20 17:18:04,128 - Recv: Cap:VOLUMETRIC:0
2020-11-20 17:18:04,132 - Recv: Cap:AUTOREPORT_TEMP:1
2020-11-20 17:18:04,139 - Recv: Cap:PROGRESS:0
2020-11-20 17:18:04,145 - Recv: Cap:PRINT_JOB:1
2020-11-20 17:18:04,146 - Recv: Cap:AUTOLEVEL:1
2020-11-20 17:18:04,148 - Recv: Cap:RUNOUT:0
2020-11-20 17:18:04,152 - Recv: Cap:Z_PROBE:1
2020-11-20 17:18:04,156 - Recv: Cap:LEVELING_DATA:1
2020-11-20 17:18:04,158 - Recv: Cap:BUILD_PERCENT:0
2020-11-20 17:18:04,160 - Recv: Cap:SOFTWARE_POWER:0
2020-11-20 17:18:04,164 - Recv: Cap:TOGGLE_LIGHTS:0
2020-11-20 17:18:04,165 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-11-20 17:18:04,168 - Recv: Cap:EMERGENCY_PARSER:0
2020-11-20 17:18:04,171 - Recv: Cap:PROMPT_SUPPORT:0
2020-11-20 17:18:04,174 - Recv: Cap:SDCARD:0
2020-11-20 17:18:04,175 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-11-20 17:18:04,180 - Recv: Cap:LONG_FILENAME:0
2020-11-20 17:18:04,185 - Recv: Cap:THERMAL_PROTECTION:1
2020-11-20 17:18:04,188 - Recv: Cap:MOTION_MODES:0
2020-11-20 17:18:04,190 - Recv: Cap:ARCS:1
2020-11-20 17:18:04,192 - Recv: Cap:BABYSTEPPING:0
2020-11-20 17:18:04,194 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-11-20 17:18:04,197 - Recv: ok
2020-11-20 17:18:04,199 - Send: M155 S2
2020-11-20 17:18:04,202 - Recv: ok
2020-11-20 17:18:06,214 - Recv: T:177.19 /0.00 B:48.96 /0.00 @:0 B@:0
2020-11-20 17:18:08,214 - Recv: T:174.93 /0.00 B:48.85 /0.00 @:0 B@:0
2020-11-20 17:18:10,214 - Recv: T:172.69 /0.00 B:48.70 /0.00 @:0 B@:0
2020-11-20 17:18:12,213 - Recv: T:170.31 /0.00 B:48.67 /0.00 @:0 B@:0
2020-11-20 17:18:14,213 - Recv: T:168.35 /0.00 B:48.47 /0.00 @:0 B@:0
2020-11-20 17:18:16,213 - Recv: T:166.22 /0.00 B:48.42 /0.00 @:0 B@:0
2020-11-20 17:18:18,213 - Recv: T:164.14 /0.00 B:48.17 /0.00 @:0 B@:0
2020-11-20 17:18:20,213 - Recv: T:162.05 /0.00 B:48.16 /0.00 @:0 B@:0
2020-11-20 17:18:22,213 - Recv: T:159.97 /0.00 B:47.99 /0.00 @:0 B@:0
2020-11-20 17:18:24,214 - Recv: T:158.29 /0.00 B:47.89 /0.00 @:0 B@:0
2020-11-20 17:18:26,214 - Recv: T:156.45 /0.00 B:47.75 /0.00 @:0 B@:0
2020-11-20 17:18:28,213 - Recv: T:154.74 /0.00 B:47.63 /0.00 @:0 B@:0
2020-11-20 17:18:30,213 - Recv: T:153.03 /0.00 B:47.60 /0.00 @:0 B@:0
2020-11-20 17:18:32,219 - Recv: T:151.23 /0.00 B:47.43 /0.00 @:0 B@:0
2020-11-20 17:18:34,218 - Recv: T:149.52 /0.00 B:47.37 /0.00 @:0 B@:0
2020-11-20 17:18:36,218 - Recv: T:147.56 /0.00 B:47.27 /0.00 @:0 B@:0
2020-11-20 17:18:38,218 - Recv: T:145.75 /0.00 B:47.11 /0.00 @:0 B@:0
2020-11-20 17:18:40,218 - Recv: T:143.91 /0.00 B:47.11 /0.00 @:0 B@:0
2020-11-20 17:18:42,219 - Recv: T:142.09 /0.00 B:47.07 /0.00 @:0 B@:0
2020-11-20 17:18:44,222 - Recv: T:140.12 /0.00 B:46.89 /0.00 @:0 B@:0
2020-11-20 17:18:46,219 - Recv: T:138.71 /0.00 B:46.84 /0.00 @:0 B@:0
2020-11-20 17:18:48,218 - Recv: T:137.34 /0.00 B:46.76 /0.00 @:0 B@:0
2020-11-20 17:18:50,218 - Recv: T:135.91 /0.00 B:46.61 /0.00 @:0 B@:0
2020-11-20 17:18:52,218 - Recv: T:134.55 /0.00 B:46.58 /0.00 @:0 B@:0
2020-11-20 17:18:54,218 - Recv: T:133.04 /0.00 B:46.51 /0.00 @:0 B@:0
2020-11-20 17:18:56,218 - Recv: T:131.65 /0.00 B:46.38 /0.00 @:0 B@:0
2020-11-20 17:18:58,219 - Recv: T:130.22 /0.00 B:46.32 /0.00 @:0 B@:0
2020-11-20 17:19:00,220 - Recv: T:128.79 /0.00 B:46.23 /0.00 @:0 B@:0
2020-11-20 17:19:02,220 - Recv: T:127.38 /0.00 B:46.20 /0.00 @:0 B@:0
2020-11-20 17:19:04,220 - Recv: T:125.85 /0.00 B:46.05 /0.00 @:0 B@:0
2020-11-20 17:19:06,219 - Recv: T:124.44 /0.00 B:46.04 /0.00 @:0 B@:0
2020-11-20 17:19:08,224 - Recv: T:123.01 /0.00 B:45.95 /0.00 @:0 B@:0
2020-11-20 17:19:10,219 - Recv: T:121.59 /0.00 B:45.86 /0.00 @:0 B@:0
2020-11-20 17:19:12,219 - Recv: T:120.18 /0.00 B:45.79 /0.00 @:0 B@:0
2020-11-20 17:19:14,220 - Recv: T:118.82 /0.00 B:45.76 /0.00 @:0 B@:0
2020-11-20 17:19:16,220 - Recv: T:117.57 /0.00 B:45.69 /0.00 @:0 B@:0
2020-11-20 17:19:18,225 - Recv: T:116.33 /0.00 B:45.67 /0.00 @:0 B@:0
2020-11-20 17:19:20,220 - Recv: T:115.11 /0.00 B:45.53 /0.00 @:0 B@:0
2020-11-20 17:19:22,219 - Recv: T:113.88 /0.00 B:45.53 /0.00 @:0 B@:0
2020-11-20 17:19:24,219 - Recv: T:112.52 /0.00 B:45.49 /0.00 @:0 B@:0
2020-11-20 17:19:26,232 - Recv: T:111.34 /0.00 B:45.26 /0.00 @:0 B@:0
2020-11-20 17:19:28,232 - Recv: T:110.12 /0.00 B:45.26 /0.00 @:0 B@:0
2020-11-20 17:19:30,231 - Recv: T:108.89 /0.00 B:45.25 /0.00 @:0 B@:0
2020-11-20 17:19:32,231 - Recv: T:107.62 /0.00 B:45.16 /0.00 @:0 B@:0
2020-11-20 17:19:34,232 - Recv: T:106.46 /0.00 B:45.03 /0.00 @:0 B@:0
2020-11-20 17:19:36,232 - Recv: T:105.29 /0.00 B:45.00 /0.00 @:0 B@:0
2020-11-20 17:19:38,232 - Recv: T:104.14 /0.00 B:44.98 /0.00 @:0 B@:0
2020-11-20 17:19:40,232 - Recv: T:103.02 /0.00 B:44.94 /0.00 @:0 B@:0
2020-11-20 17:19:42,231 - Recv: T:101.80 /0.00 B:44.80 /0.00 @:0 B@:0
2020-11-20 17:19:44,231 - Recv: T:100.73 /0.00 B:44.71 /0.00 @:0 B@:0
2020-11-20 17:19:46,231 - Recv: T:99.64 /0.00 B:44.71 /0.00 @:0 B@:0
2020-11-20 17:19:48,231 - Recv: T:98.59 /0.00 B:44.71 /0.00 @:0 B@:0
2020-11-20 17:19:50,232 - Recv: T:97.60 /0.00 B:44.58 /0.00 @:0 B@:0
2020-11-20 17:19:52,232 - Recv: T:96.47 /0.00 B:44.47 /0.00 @:0 B@:0
2020-11-20 17:19:54,245 - Recv: T:95.46 /0.00 B:44.41 /0.00 @:0 B@:0
2020-11-20 17:19:56,246 - Recv: T:94.48 /0.00 B:44.41 /0.00 @:0 B@:0
2020-11-20 17:19:58,246 - Recv: T:93.48 /0.00 B:44.41 /0.00 @:0 B@:0
2020-11-20 17:20:00,246 - Recv: T:92.44 /0.00 B:44.34 /0.00 @:0 B@:0
2020-11-20 17:20:02,246 - Recv: T:91.49 /0.00 B:44.30 /0.00 @:0 B@:0
2020-11-20 17:20:04,245 - Recv: T:90.54 /0.00 B:44.12 /0.00 @:0 B@:0
2020-11-20 17:20:06,245 - Recv: T:89.61 /0.00 B:44.12 /0.00 @:0 B@:0
2020-11-20 17:20:08,245 - Recv: T:88.76 /0.00 B:44.10 /0.00 @:0 B@:0
2020-11-20 17:20:10,245 - Recv: T:87.80 /0.00 B:44.04 /0.00 @:0 B@:0
2020-11-20 17:20:12,246 - Recv: T:86.95 /0.00 B:44.06 /0.00 @:0 B@:0
2020-11-20 17:20:14,251 - Recv: T:86.08 /0.00 B:43.95 /0.00 @:0 B@:0
2020-11-20 17:20:16,246 - Recv: T:85.25 /0.00 B:43.84 /0.00 @:0 B@:0
2020-11-20 17:20:18,245 - Recv: T:84.45 /0.00 B:43.82 /0.00 @:0 B@:0
2020-11-20 17:20:20,245 - Recv: T:83.59 /0.00 B:43.81 /0.00 @:0 B@:0
2020-11-20 17:20:22,245 - Recv: T:82.83 /0.00 B:43.62 /0.00 @:0 B@:0
2020-11-20 17:20:24,245 - Recv: T:82.08 /0.00 B:43.55 /0.00 @:0 B@:0
2020-11-20 17:20:26,245 - Recv: T:81.32 /0.00 B:43.53 /0.00 @:0 B@:0
2020-11-20 17:20:28,246 - Recv: T:80.58 /0.00 B:43.51 /0.00 @:0 B@:0
2020-11-20 17:20:30,246 - Recv: T:79.81 /0.00 B:43.47 /0.00 @:0 B@:0
2020-11-20 17:20:32,246 - Recv: T:78.90 /0.00 B:43.27 /0.00 @:0 B@:0
2020-11-20 17:20:34,246 - Recv: T:78.05 /0.00 B:43.24 /0.00 @:0 B@:0
2020-11-20 17:20:36,246 - Recv: T:77.25 /0.00 B:43.24 /0.00 @:0 B@:0
2020-11-20 17:20:38,245 - Recv: T:76.42 /0.00 B:43.24 /0.00 @:0 B@:0
2020-11-20 17:20:40,245 - Recv: T:75.56 /0.00 B:43.24 /0.00 @:0 B@:0
2020-11-20 17:20:42,245 - Recv: T:74.84 /0.00 B:43.16 /0.00 @:0 B@:0
2020-11-20 17:20:44,246 - Recv: T:74.07 /0.00 B:43.03 /0.00 @:0 B@:0
2020-11-20 17:20:46,246 - Recv: T:73.36 /0.00 B:42.94 /0.00 @:0 B@:0
2020-11-20 17:20:48,250 - Recv: T:72.63 /0.00 B:42.94 /0.00 @:0 B@:0
2020-11-20 17:20:50,249 - Recv: T:71.91 /0.00 B:42.94 /0.00 @:0 B@:0
2020-11-20 17:20:52,249 - Recv: T:71.24 /0.00 B:42.90 /0.00 @:0 B@:0
2020-11-20 17:20:54,249 - Recv: T:70.56 /0.00 B:42.81 /0.00 @:0 B@:0
2020-11-20 17:20:56,248 - Recv: T:69.91 /0.00 B:42.74 /0.00 @:0 B@:0
2020-11-20 17:20:58,248 - Recv: T:69.25 /0.00 B:42.65 /0.00 @:0 B@:0
2020-11-20 17:21:00,249 - Recv: T:68.59 /0.00 B:42.65 /0.00 @:0 B@:0
2020-11-20 17:21:02,250 - Recv: T:67.99 /0.00 B:42.63 /0.00 @:0 B@:0
2020-11-20 17:21:04,250 - Recv: T:67.41 /0.00 B:42.48 /0.00 @:0 B@:0
2020-11-20 17:21:06,250 - Recv: T:66.80 /0.00 B:42.39 /0.00 @:0 B@:0
2020-11-20 17:21:08,250 - Recv: T:66.23 /0.00 B:42.35 /0.00 @:0 B@:0
2020-11-20 17:21:10,249 - Recv: T:65.61 /0.00 B:42.35 /0.00 @:0 B@:0
2020-11-20 17:21:12,255 - Recv: T:65.10 /0.00 B:42.32 /0.00 @:0 B@:0
2020-11-20 17:21:14,249 - Recv: T:64.60 /0.00 B:42.24 /0.00 @:0 B@:0
2020-11-20 17:21:16,256 - Recv: T:64.11 /0.00 B:42.21 /0.00 @:0 B@:0
2020-11-20 17:21:18,255 - Recv: T:63.58 /0.00 B:42.15 /0.00 @:0 B@:0
2020-11-20 17:21:20,256 - Recv: T:63.06 /0.00 B:42.06 /0.00 @:0 B@:0
2020-11-20 17:21:22,256 - Recv: T:62.59 /0.00 B:42.06 /0.00 @:0 B@:0
2020-11-20 17:21:24,256 - Recv: T:62.10 /0.00 B:42.04 /0.00 @:0 B@:0
2020-11-20 17:21:26,256 - Recv: T:61.62 /0.00 B:42.00 /0.00 @:0 B@:0
2020-11-20 17:21:28,256 - Recv: T:61.13 /0.00 B:41.86 /0.00 @:0 B@:0
2020-11-20 17:21:30,255 - Recv: T:60.74 /0.00 B:41.80 /0.00 @:0 B@:0
2020-11-20 17:21:32,255 - Recv: T:60.29 /0.00 B:41.76 /0.00 @:0 B@:0
2020-11-20 17:21:34,255 - Recv: T:59.74 /0.00 B:41.76 /0.00 @:0 B@:0
2020-11-20 17:21:36,256 - Recv: T:59.19 /0.00 B:41.73 /0.00 @:0 B@:0
2020-11-20 17:21:38,256 - Recv: T:58.55 /0.00 B:41.60 /0.00 @:0 B@:0
2020-11-20 17:21:40,256 - Recv: T:57.98 /0.00 B:41.53 /0.00 @:0 B@:0
2020-11-20 17:21:42,256 - Recv: T:57.49 /0.00 B:41.47 /0.00 @:0 B@:0
2020-11-20 17:21:44,268 - Recv: T:56.90 /0.00 B:41.47 /0.00 @:0 B@:0
2020-11-20 17:21:46,268 - Recv: T:56.27 /0.00 B:41.43 /0.00 @:0 B@:0
2020-11-20 17:21:48,268 - Recv: T:55.78 /0.00 B:41.32 /0.00 @:0 B@:0
2020-11-20 17:21:50,267 - Recv: T:55.29 /0.00 B:41.19 /0.00 @:0 B@:0
OctoPrint Version 1.5.0rc3, Marlin 2.0.7.1, Raspberry PI4 4Gb, Ender 5 Pro with motherboard V 1.1.5
