Cam detected but not working
OV5647 (RPI CAM NOIR MF: Raspberry Pi - Kamera, 5MP, 75°, IR-LEDs bei reichelt elektronik)
Octoprint is detecting my Camera but not working.
  • sudo apt-get update
  • sudo apt-get upgrade --with-new-pkgsList
  • I2C enabeled
yes
no
octoprint-systeminfo-20230722232941.zip (22.4 KB)
additional info
felix@CR10MAX:~ $ libcamera-hello --list-cameras
Available cameras
0 : ov5647 [2592x1944] (/base/soc/i2c0mux/i2c@1/ov5647@36)
    Modes: 'SGBRG10_CSI2P' : 640x480 [30.00 fps - (0, 0)/0x0 crop]
                             1296x972 [30.00 fps - (0, 0)/0x0 crop]
                             1920x1080 [30.00 fps - (0, 0)/0x0 crop]
                             2592x1944 [30.00 fps - (0, 0)/0x0 crop]
felix@CR10MAX:~ $ vcgencmd get_camera
supported=1 detected=0, libcamera interfaces=1
felix@CR10MAX:~ $ libcamera-hello -v3
Options:
    verbose: 3
    info_text:#%frame (%fps fps) exp %exp ag %ag dg %dg
    timeout: 5000
    width: 0
    height: 0
    output:
    post_process_file:
    rawfull: 0
    preview: default
    qt-preview: 0
    transform: identity
    roi: all
    metering: centre
    exposure: normal
    ev: 0
    awb: auto
    flush: false
    wrap: 0
    brightness: 0
    contrast: 1
    saturation: 1
    sharpness: 1
    framerate: 30
    denoise: auto
    viewfinder-width: 0
    viewfinder-height: 0
    tuning-file: (libcamera)
    lores-width: 0
    lores-height: 0
    autofocus-range: normal
    autofocus-speed: normal
    autofocus-window: all
    mode: unspecified
    viewfinder-mode: unspecified
    metadata:
    metadata-format: json
No connector ID specified.  Choosing default from list:
Connector 32 (crtc 0): type 11, 0x0
Connector 42 (crtc 0): type 11, 0x0
Preview window unavailable
Running without preview window
Opening camera...
[0:02:14.931499846] [1005]  INFO Camera camera_manager.cpp:297 libcamera v0.0.5+82-2783c8d8
[0:02:14.970485905] [1006]  INFO RPI vc4.cpp:437 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media1 and ISP device /dev/media0
[0:02:14.970571404] [1006]  INFO RPI pipeline_base.cpp:1101 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:02:14.970981012] [1005]  INFO Camera camera.cpp:840 Pipeline handler in use by another process
Closing Libcamera application(frames displayed 0, dropped 0)
Camera stopped!
Tearing down requests, buffers and configuration
Camera closed
ERROR: *** failed to acquire camera /base/soc/i2c0mux/i2c@1/ov5647@36 ***
arm_64bit=0
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Disable compensation for displays with overscan
disable_overscan=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[all]
[pi4]
# Run as fast as firmware / board allows
arm_boost=1
[all]
# enable raspicam
start_x=1
gpu_mem=128
octopi.txt
### IMPORTANT: Looking for the camera settings? Those are now located
### in the camera-streamer directory! libcamera.conf to configure the Raspberry Pi
### camera and usb-default.conf to configure USB cameras. Read more about it here:
### https://faq.octoprint.org/camera-streamer-config
### Windows users: To edit this file use Notepad++, VSCode or SublimeText.
### Do not use Notepad or WordPad.
### MacOSX users: If you use Textedit to edit this file make sure to use
### "plain text format" and "disable smart quotes" in "Textedit > Preferences"
# Configuration of network monitoring
# This enables network monitoring for wifi connections with a simple ping test.
# If connection terminates by variable reasons system tries to restart the wifi connection to reestablish a connection.
# The connection test is done every minute.
# By default it is disabled (0 = off / 1 = on)
# destination_host can be an ip address or a hostname (for hostname ensure dns resosultion is working correctly)
enable_network_monitor=0
# Be sure to change this to match your network!
destination_host=192.168.1.1
### EXPERIMENTAL
# Support for different streamer types.
# Available options:
#   mjpeg [default] - camera-streamer
#   hls - FFMPEG HLS streamer
#camera_streamer=mjpeg
libcamera.config
### Options for libcamera based cameras (PiCam, Arducam, ...)
# The port on which the webcam server for the camera should listen on. If you have only
# one camera, leave at 8080. If you have more, change to 8081, 8082, etc. The primary
# camera will be considered the one with 8080.
PORT=8080
# The resolution to request on the camera sensor. Defaults to 1280x720.
WIDTH=1920
HEIGHT=1080
# The height to use for the video stream. Defaults to 720.
VIDEO_HEIGHT=720
# The height to use for the snapshots. Defaults to 1080.
SNAPSHOT_HEIGHT=1080
# The framerate to set on the camera. Defaults to 15fps.
FRAMERATE=15
# Additional options. By default enables continuous auto focus (if possible).
OPTIONS='--camera-options="AfMode=2" --camera-options="AfRange=2"'
Please share a systeminfo bundle
Hi so sorry, forgott..
i updated it in the first post and also some additional steps i did so far. And all files updated too.
Some more maybe "usefull" information:
