I had a break in printing for a while now (3 month). Now i started again and want to move my printer in my "lab" and build an enclosure. Three month ago printer worked well. Now after moving it (and changing one buck converter) for the raspi, octopi does not recoginze the printer.
Checked cable stuff twice
replaced the new buck converter with a 5.x volt adapter -> no change
Updated OctoPi to 1.3.11 (had some assumption about corrupt setting- but was not)
Tested in safe mode
searched different forums and found stuff, but did not really help (e.g. https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=110164 whre i was not sure about how to detect a hardware issue). Tried to set serial port manualy (change baud rate, can´t change port. There is only "auto available). Topic Failed to detect serial port seems identical, but no solution/answer there)
Changed USB Port for the connector cable to printer
Tried with printer off/on to see if different error messages occur (found no diff). So assumption is, it is something around the raspi and not the printer.
Played with voltage regulation 5.1/5.4V - no change
Changed connector cable...no change..
now writing this entry in hope for some tipps what i can look into...
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Serial.log
Serial port list: []
Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
Closing serial port due to emergency stop M112.
octoprint log
2019-09-14 21:16:16,466 - octoprint.startup - INFO - ******************************************************************************
2019-09-14 21:16:16,469 - octoprint.startup - INFO - Starting OctoPrint 1.3.11
2019-09-14 21:16:16,469 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2019-09-14 21:16:16,470 - octoprint.startup - INFO - Reason for safe mode: problem during last startup
2019-09-14 21:16:16,472 - octoprint.startup - INFO - ******************************************************************************
2019-09-15 21:00:14,752 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 3 Model B Plus Rev 1.3
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
er - INFO - Loaded notice data from disk, was still valid
2019-09-16 11:17:30,923 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-16 11:21:35,539 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-16 11:21:35,540 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-16 11:21:35,787 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-09-16 11:27:41,921 - octoprint.startup - INFO - Starting OctoPrint 1.3.12rc1
2019-09-16 11:27:41,921 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2019-09-16 11:27:41,921 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2019-09-16 11:27:41,922 - octoprint.startup - INFO - ******************************************************************************
packages/octoprint/plugins/pluginmanager
| !Themeify (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2019-09-16 11:27:49,729 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-09-16 11:27:49,741 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-09-16 11:27:49,763 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-09-16 11:27:50,644 - octoprint.server - INFO - Shutting down intermediary server...
2019-09-16 11:27:51,116 - octoprint.server - INFO - Intermediary server shut down
2019-09-16 11:27:51,119 - octoprint.events - INFO - Processing startup event, this is our first event
2019-09-16 11:27:51,120 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2019-09-16 11:27:51,124 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-09-16 11:27:51,131 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-09-16 11:27:51,196 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-16 11:27:51,574 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-16 11:27:51,984 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-09-16 11:27:51,990 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-09-16 11:27:51,993 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-09-16 11:27:52,008 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-09-16 11:27:52,013 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-09-16 11:27:52,018 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2019-09-16 11:27:52,020 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-09-16 11:27:52,040 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-09-16 11:27:52,053 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-16 11:27:52,055 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2019-09-16 11:27:52,637 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-16 11:27:53,092 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-16 11:27:53,857 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.110
2019-09-16 11:27:54,031 - octoprint.server.util.flask - INFO - Passively logging in user TomPI from ::ffff:192.168.2.110
2019-09-16 11:27:54,049 - octoprint.server.util.sockjs - INFO - User TomPI logged in on the socket from client ::ffff:192.168.2.110
2019-09-16 11:27:54,298 - tornado.access - WARNING - 404 GET /api/plugin/excluderegion (::ffff:192.168.2.110) 14.76ms
2019-09-16 11:27:54,344 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-16 11:27:54,346 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-16 11:27:54,347 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-16 11:27:54,740 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://192.168.2.109/'}
2019-09-16 11:28:06,296 - octoprint.server.preemptive_cache - INFO - ... done in 11.56s
2019-09-16 11:28:36,783 - octoprint.server.util.flask - INFO - Passively logging in user TomPI from ::ffff:192.168.2.110
2019-09-16 11:28:36,924 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.110
2019-09-16 11:28:37,796 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.110
2019-09-16 11:28:37,976 - octoprint.server.util.flask - INFO - Passively logging in user TomPI from ::ffff:192.168.2.110
2019-09-16 11:28:39,559 - octoprint.server.util.sockjs - INFO - User TomPI logged in on the socket from client ::ffff:192.168.2.110
2019-09-16 11:29:27,787 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-09-16 11:29:27,813 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-09-16 11:29:27,815 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2019-09-16 11:29:42,281 - octoprint.server.api.system - INFO - Performing command for core:restart: sudo service octoprint restart
2019-09-16 11:29:42,429 - octoprint.server - INFO - Shutting down...
2019-09-16 11:29:43,229 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-09-16 11:29:43,234 - octoprint.events - INFO - Event loop shut down
2019-09-16 11:29:43,255 - octoprint.server - INFO - Goodbye!
2019-09-16 11:29:47,081 - octoprint.startup - INFO - ******************************************************************************
2019-09-16 11:29:47,084 - octoprint.startup - INFO - Starting OctoPrint 1.3.12rc1
2019-09-16 11:29:47,084 - octoprint.startup - INFO - ******************************************************************************
2019-09-16 11:29:47,169 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-09-16 11:29:47,173 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2019-09-16 11:29:47,292 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-16 11:29:48,154 - octoprint.plugin.core - INFO - Plugin Anonymous Usage Tracking is disabled.
2019-09-16 11:29:49,576 - octoprint.plugins.errortracking - INFO - Initialized error tracking
2019-09-16 11:29:49,587 - octoprint.plugin.core - INFO - Found 36 plugin(s) providing 35 mixin implementations, 52 hook handlers
2019-09-16 11:29:50,046 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-09-16 11:29:50,073 - octoprint.server - INFO - Intermediary server started
2019-09-16 11:29:50,075 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-16 11:29:50,801 - octoprint.plugin.core - INFO - Found 36 plugin(s) providing 35 mixin implementations, 52 hook handlers
2019-09-16 11:29:50,842 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-09-16 11:29:51,361 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-09-16 11:29:51,832 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-09-16 11:29:51,851 - octoprint.plugins.excluderegion - INFO - Logging mode set to 'octoprint'
2019-09-16 11:29:51,852 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=False, mayShrinkRegionsWhilePrinting=False, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "type": "ExcludedGcode", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding"}, 'M205': {"gcode": "M205", "type": "ExcludedGcode", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area"}, 'M204': {"gcode": "M204", "type": "ExcludedGcode", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area"}}, atCommandActions={'ExcludeRegion': [{"action": "enable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\s*(enable|on)(\s|)", "description": "Default action to enable exclusion"}, {"action": "disable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|)", "description": "Default action to disable exclusion"}]}
2019-09-16 11:29:53,414 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-16 11:29:54,995 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-09-16 11:29:54,996 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-16 11:29:54,997 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-16 11:29:55,004 - octoprint.plugin.core - INFO - Initialized 35 plugin implementation(s)
2019-09-16 11:29:55,033 - octoprint.plugin.core - INFO - 36 plugin(s) registered with the system:
| ABL Expert Plugin (0.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ABL_Expert
| Active Filters (0.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_active_filters
| Active Filters Extended (0.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_active_filters_extended
| !Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
| Autoscroll (0.0.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_autoscroll
| Bed Leveling Wizard (0.2.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelingwizard
| Bed Visualizer (0.1.10) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| BLTouch Plugin (0.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_BLTouch
| Change Filament Plugin (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_Change_Filament
| Cost Estimation (2.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_costestimation
| DeleteAfterPrint Plugin (1.5.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DeleteAfterPrint
| DisplayProgress (0.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_displayprogress
| EEPROM Marlin Editor Plugin (1.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eeprom_marlin
| Exclude Region (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_excluderegion
| Fan Speed Control (0.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fanspeedslider
| FineTuneRptr (1.3.6.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_finetunerptr
| Firmware Updater (1.6.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| HeaterTimeout (0.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_HeaterTimeout
| LayerDisplay (0.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/layerdisplay
| M73-Progress-Plugin (0.1.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_m73progress
| Navbar Temperature Plugin (0.11) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_navbartemp
2019-09-16 11:29:55,052 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1400.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| python:
| pip: 19.0.1
| version: 2.7.13
2019-09-16 11:29:55,063 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-09-16 11:29:55,080 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-09-16 11:29:56,247 - octoprint.server - INFO - Shutting down intermediary server...
2019-09-16 11:29:56,416 - octoprint.server - INFO - Intermediary server shut down
2019-09-16 11:29:56,419 - octoprint.events - INFO - Processing startup event, this is our first event
2019-09-16 11:29:56,420 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2019-09-16 11:29:56,424 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-09-16 11:29:56,433 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-09-16 11:29:56,471 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-16 11:29:56,815 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-16 11:29:57,308 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-09-16 11:29:57,316 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-09-16 11:29:57,325 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-09-16 11:29:57,333 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-09-16 11:29:57,346 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-09-16 11:29:57,352 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-09-16 11:29:57,371 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-09-16 11:29:57,375 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2019-09-16 11:29:57,379 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error
2019-09-16 11:29:57,393 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-16 11:29:57,463 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-09-16 11:29:58,174 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-09-16 11:29:58,513 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.110
2019-09-16 11:29:58,702 - octoprint.server.util.flask - INFO - Passively logging in user TomPI from ::ffff:192.168.2.110
2019-09-16 11:29:58,724 - octoprint.server.util.sockjs - INFO - User TomPI logged in on the socket from client ::ffff:192.168.2.110
2019-09-16 11:29:59,363 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-16 11:29:59,364 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-16 11:29:59,366 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-16 11:29:59,580 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-16 11:30:04,011 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-16 11:30:04,013 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-16 11:30:04,247 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-09-16 11:30:04,249 - octoprint.plugins.HeaterTimeout - INFO - Starting up...
2019-09-16 11:30:04,254 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2019-09-16 11:30:04,261 - octoprint.plugins.navbartemp - INFO - Broadcom detected
2019-09-16 11:30:04,265 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:30:04,671 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://192.168.2.109/'}
2019-09-16 11:30:20,991 - octoprint.server.preemptive_cache - INFO - ... done in 16.32s
2019-09-16 11:30:34,349 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:31:04,399 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:31:34,448 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:32:04,497 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:32:34,546 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:33:04,595 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:33:27,118 - octoprint.server.util.flask - INFO - Passively logging in user TomPI from ::ffff:192.168.2.110
2019-09-16 11:33:27,266 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.2.110
2019-09-16 11:33:28,502 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.2.110
2019-09-16 11:33:28,726 - octoprint.server.util.flask - INFO - Passively logging in user TomPI from ::ffff:192.168.2.110
2019-09-16 11:33:30,676 - octoprint.server.util.sockjs - INFO - User TomPI logged in on the socket from client ::ffff:192.168.2.110
2019-09-16 11:33:30,793 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=False, mayShrinkRegionsWhilePrinting=False, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "type": "ExcludedGcode", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding"}, 'M205': {"gcode": "M205", "type": "ExcludedGcode", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area"}, 'M204': {"gcode": "M204", "type": "ExcludedGcode", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area"}}, atCommandActions={'ExcludeRegion': [{"action": "enable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\s*(enable|on)(\s|)", "description": "Default action to enable exclusion"}, {"action": "disable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|)", "description": "Default action to disable exclusion"}]}
2019-09-16 11:33:30,838 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=False, mayShrinkRegionsWhilePrinting=False, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "type": "ExcludedGcode", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding"}, 'M205': {"gcode": "M205", "type": "ExcludedGcode", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area"}, 'M204': {"gcode": "M204", "type": "ExcludedGcode", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area"}}, atCommandActions={'ExcludeRegion': [{"action": "enable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\s*(enable|on)(\s|)", "description": "Default action to enable exclusion"}, {"action": "disable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|)", "description": "Default action to disable exclusion"}]}
2019-09-16 11:33:30,869 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=False, mayShrinkRegionsWhilePrinting=False, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "type": "ExcludedGcode", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding"}, 'M205': {"gcode": "M205", "type": "ExcludedGcode", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area"}, 'M204': {"gcode": "M204", "type": "ExcludedGcode", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area"}}, atCommandActions={'ExcludeRegion': [{"action": "enable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\s*(enable|on)(\s|)", "description": "Default action to enable exclusion"}, {"action": "disable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|)", "description": "Default action to disable exclusion"}]}
2019-09-16 11:33:30,901 - octoprint.plugins.excluderegion - INFO - Setting update detected: g90InfluencesExtruder=False, clearRegionsAfterPrintFinishes=False, mayShrinkRegionsWhilePrinting=False, loggingMode=octoprint, enteringExcludedRegionGcode=None, exitingExcludedRegionGcode=None, extendedExcludeGcodes={'G4': {"gcode": "G4", "type": "ExcludedGcode", "mode": "exclude", "description": "Ignore all dwell commands in an excluded area to reduce delays while excluding"}, 'M205': {"gcode": "M205", "type": "ExcludedGcode", "mode": "merge", "description": "Record advanced setting changes while excluding and apply the most recent values in a single command after exiting the excluded area"}, 'M204': {"gcode": "M204", "type": "ExcludedGcode", "mode": "merge", "description": "Record default acceleration changes while excluding and apply the most recent values in a single command after exiting the excluded area"}}, atCommandActions={'ExcludeRegion': [{"action": "enable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\s*(enable|on)(\s|)", "description": "Default action to enable exclusion"}, {"action": "disable_exclusion", "type": "AtCommandAction", "command": "ExcludeRegion", "parameterPattern": "^\\s*(disable|off)(\\s|)", "description": "Default action to disable exclusion"}]}
2019-09-16 11:33:34,644 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:34:04,694 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:34:34,744 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
2019-09-16 11:35:04,793 - octoprint.plugins.navbartemp - INFO - Checking SoC internal temperature
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
Printer is an ender pro 3 with THD firmware. Raspi is V 3.b
