If I click on refresh button and select the port manualy, it connects. My printer is ENDER-3,
Here is the serial log
2020-03-17 18:17:50,843 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-17 18:17:50,874 - Serial port list: [u'/dev/ttyACM0', u'/dev/ttyS0']
2020-03-17 18:17:50,875 - Trying /dev/ttyACM0
2020-03-17 18:17:56,186 - Could not connect to or enter programming mode on /dev/ttyACM0, might not be a printer or just not allow programming mode
2020-03-17 18:17:56,207 - Trying /dev/ttyS0
2020-03-17 18:18:01,540 - Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
2020-03-17 18:18:01,560 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-17 18:18:01,594 - Failed to autodetect serial port, please set it manually.
2020-03-17 18:18:18,810 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-17 18:18:18,871 - Serial port list: [u'/dev/ttyACM0', u'/dev/ttyS0']
2020-03-17 18:18:18,872 - Trying /dev/ttyACM0
2020-03-17 18:18:24,209 - Could not connect to or enter programming mode on /dev/ttyACM0, might not be a printer or just not allow programming mode
2020-03-17 18:18:24,228 - Trying /dev/ttyS0
2020-03-17 18:18:29,560 - Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
2020-03-17 18:18:29,581 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-17 18:18:29,592 - Failed to autodetect serial port, please set it manually.
2020-03-17 18:18:33,372 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-17 18:18:33,490 - Serial port list: [u'/dev/ttyACM0', u'/dev/ttyS0']
2020-03-17 18:18:33,491 - Trying /dev/ttyACM0
2020-03-17 18:18:38,810 - Could not connect to or enter programming mode on /dev/ttyACM0, might not be a printer or just not allow programming mode
2020-03-17 18:18:38,829 - Trying /dev/ttyS0
2020-03-17 18:18:44,170 - Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
2020-03-17 18:18:44,191 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-17 18:18:44,201 - Failed to autodetect serial port, please set it manually.
2020-03-17 18:18:54,191 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-17 18:18:54,305 - Serial port list: [u'/dev/ttyACM0', u'/dev/ttyS0']
2020-03-17 18:18:54,308 - Trying /dev/ttyACM0
2020-03-17 18:18:59,661 - Could not connect to or enter programming mode on /dev/ttyACM0, might not be a printer or just not allow programming mode
2020-03-17 18:18:59,667 - Trying /dev/ttyS0
2020-03-17 18:19:05,011 - Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
2020-03-17 18:19:05,029 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-17 18:19:05,044 - Failed to autodetect serial port, please set it manually.
2020-03-17 18:19:10,731 - Connecting to: /dev/ttyACM0
2020-03-17 18:19:10,752 - Changing monitoring state from "Offline" to "Opening serial port"
2020-03-17 18:19:10,759 - Connected to: Serial<id=0x704a9490, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-03-17 18:19:10,760 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-03-17 18:19:10,772 - Send: N0 M110 N0*125
2020-03-17 18:19:10,782 - Send: N0 M110 N0*125
2020-03-17 18:19:10,785 - Recv: echo:Unknown command: "e"
2020-03-17 18:19:10,797 - Recv: ok
2020-03-17 18:19:10,807 - Changing monitoring state from "Connecting" to "Operational"
2020-03-17 18:19:10,823 - Send: N0 M110 N0*125
2020-03-17 18:19:10,830 - Recv: ok
2020-03-17 18:19:10,836 - Send: N1 M115*39
2020-03-17 18:19:10,837 - Recv: ok
2020-03-17 18:19:10,841 - Recv: FIRMWARE_NAME:Marlin bugfix-2.0.x (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-03-17 18:19:10,848 - Recv: Cap:SERIAL_XON_XOFF:0
2020-03-17 18:19:10,850 - Send: M21
2020-03-17 18:19:10,852 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-03-17 18:19:10,861 - Recv: Cap:EEPROM:1
2020-03-17 18:19:10,865 - Recv: Cap:VOLUMETRIC:1
2020-03-17 18:19:10,874 - Recv: Cap:AUTOREPORT_TEMP:1
2020-03-17 18:19:10,883 - Recv: Cap:PROGRESS:0
2020-03-17 18:19:10,885 - Recv: Cap:PRINT_JOB:1
2020-03-17 18:19:10,888 - Recv: Cap:AUTOLEVEL:1
2020-03-17 18:19:10,890 - Recv: Cap:Z_PROBE:1
2020-03-17 18:19:10,894 - Recv: Cap:LEVELING_DATA:1
2020-03-17 18:19:10,896 - Recv: Cap:BUILD_PERCENT:0
2020-03-17 18:19:10,898 - Recv: Cap:SOFTWARE_POWER:0
2020-03-17 18:19:10,900 - Recv: Cap:TOGGLE_LIGHTS:0
2020-03-17 18:19:10,903 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-03-17 18:19:10,905 - Recv: Cap:EMERGENCY_PARSER:0
2020-03-17 18:19:10,908 - Recv: Cap:PROMPT_SUPPORT:0
2020-03-17 18:19:10,911 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-03-17 18:19:10,915 - Recv: Cap:THERMAL_PROTECTION:1
2020-03-17 18:19:10,918 - Recv: Cap:MOTION_MODES:0
2020-03-17 18:19:10,920 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-03-17 18:19:10,923 - Recv: ok
2020-03-17 18:19:10,925 - Recv: echo:SD card ok
2020-03-17 18:19:10,929 - Recv: ok
2020-03-17 18:19:10,933 - Send: M117 IP 192.168.1.112
2020-03-17 18:19:10,936 - Recv: ok
2020-03-17 18:19:10,940 - Send: M155 S2
2020-03-17 18:19:10,943 - Recv: ok
2020-03-17 18:19:10,947 - Send: M20
2020-03-17 18:19:10,949 - Recv: Begin file list
2020-03-17 18:19:10,952 - Recv: End file list
2020-03-17 18:19:10,956 - Recv: ok
2020-03-17 18:19:12,913 - Send: M115
2020-03-17 18:19:12,920 - Recv: FIRMWARE_NAME:Marlin bugfix-2.0.x (GitHub) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-03-17 18:19:12,925 - Recv: Cap:SERIAL_XON_XOFF:0
2020-03-17 18:19:12,934 - Recv: Cap:BINARY_FILE_TRANSFER:0
2020-03-17 18:19:12,940 - Recv: Cap:RCENT:0
2020-03-17 18:19:12,957 - Recv: Cap:SOFTWARE_POWER:0
2020-03-17 18:19:12,966 - Recv: Cap:TOGGLE_LIGHTS:0
2020-03-17 18:19:12,984 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-03-17 18:19:12,987 - Recv: Cap:EMERGENCY_PARSER:0
2020-03-17 18:19:12,990 - Recv: Cap:PROMPT_SUPPORT:0
2020-03-17 18:19:12,995 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2020-03-17 18:19:12,999 - Recv: Cap:THERMAL_PROTECTION:1
2020-03-17 18:19:13,003 - Recv: Cap:MOTION_MODES:0
2020-03-17 18:19:13,007 - Recv: Cap:CHAMBER_TEMPERATURE:0
2020-03-17 18:19:13,010 - Recv: ok
2020-03-17 18:19:13,013 - Recv: T:20.62 /0.00 B:20.62 /0.00 @:0 B@:0
2020-03-17 18:19:13,014 - Send: M504
2020-03-17 18:19:13,022 - Recv: echo:EEPROM OK
2020-03-17 18:19:13,025 - Recv: ok
2020-03-17 18:26:26,788 - Connection closed, closing down monitor
2020-03-17 18:26:26,816 - Changing monitoring state from "Operational" to "Offline"
2020-03-18 07:35:57,379 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-18 07:35:57,412 - Serial port list: [u'/dev/ttyACM0', u'/dev/ttyS0']
2020-03-18 07:35:57,413 - Trying /dev/ttyACM0
2020-03-18 07:36:02,724 - Could not connect to or enter programming mode on /dev/ttyACM0, might not be a printer or just not allow programming mode
2020-03-18 07:36:02,744 - Trying /dev/ttyS0
2020-03-18 07:36:08,080 - Could not connect to or enter programming mode on /dev/ttyS0, might not be a printer or just not allow programming mode
2020-03-18 07:36:08,095 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-18 07:36:08,110 - Failed to autodetect serial port, please set it manually.
