Cannot update Octoprint
Hello! I'm trying to update Octoprint from 1.6.1 to the latest built but it keeps failing! I'm a total noob when understanding error logs but here is the software update console log:
2022-02-12 20:17:11,019 > Installing build dependencies: started
2022-02-12 20:17:11,020 > Installing build dependencies: finished with status 'error'
2022-02-12 20:17:11,026 ! ERROR: Command errored out with exit status 1:
2022-02-12 20:17:11,027 ! command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-boLi_q/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython
2022-02-12 20:17:11,028 ! cwd: None
2022-02-12 20:17:11,029 ! Complete output (24 lines):
2022-02-12 20:17:11,029 ! Traceback (most recent call last):
2022-02-12 20:17:11,030 ! File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
2022-02-12 20:17:11,030 ! "__main__", fname, loader, pkg_name)
2022-02-12 20:17:11,030 ! File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
2022-02-12 20:17:11,031 ! exec code in run_globals
2022-02-12 20:17:11,031 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/__main__.py", line 16, in <module>
2022-02-12 20:17:11,031 ! from pip._internal.main import main as _main  # isort:skip # noqa
2022-02-12 20:17:11,032 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/main.py", line 13, in <module>
2022-02-12 20:17:11,032 ! from pip._internal.cli.autocompletion import autocomplete
2022-02-12 20:17:11,033 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/autocompletion.py", line 11, in <module>
2022-02-12 20:17:11,033 ! from pip._internal.cli.main_parser import create_main_parser
2022-02-12 20:17:11,033 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
2022-02-12 20:17:11,034 ! from pip._internal.cli import cmdoptions
2022-02-12 20:17:11,034 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/cmdoptions.py", line 25, in <module>
2022-02-12 20:17:11,034 ! from pip._internal.locations import USER_CACHE_DIR, get_src_prefix
2022-02-12 20:17:11,034 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/locations.py", line 18, in <module>
2022-02-12 20:17:11,035 ! from pip._internal.utils import appdirs
2022-02-12 20:17:11,035 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/appdirs.py", line 16, in <module>
2022-02-12 20:17:11,035 ! from pip._internal.utils.compat import WINDOWS, expanduser
2022-02-12 20:17:11,036 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/compat.py", line 17, in <module>
2022-02-12 20:17:11,036 ! from pip._vendor.urllib3.util import IS_PYOPENSSL
2022-02-12 20:17:11,036 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_vendor/urllib3/__init__.py", line 21, in <module>
2022-02-12 20:17:11,037 ! from logging import NullHandler
2022-02-12 20:17:11,037 ! ImportError: cannot import name NullHandler
2022-02-12 20:17:11,038 ! ----------------------------------------
2022-02-12 20:17:11,038 ! ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-boLi_q/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython Check the logs for full command output.
Run in safe mode
Yes
This post should help you :slight_smile:
Hi, I uninstalled the module and used the clean up module but I unfortunately still cannot update.
 13:18:40,585 > Collecting OctoPrint-FirmwareCheck>=2021.10.11
2022-03-04 13:18:40,587 > Downloading https://www.piwheels.org/simple/octoprint-firmwarecheck/OctoPrint_FirmwareCheck-2021.10.11-py2.py3-none-any.whl
2022-03-04 13:18:40,588 > Requirement already satisfied: OctoPrint-PiSupport>=2021.10.28 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (2022.3.1)
2022-03-04 13:18:40,588 > Requirement already satisfied: markupsafe<2.0,>=1.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.1.1)
2022-03-04 13:18:40,589 > Requirement already satisfied: markdown<3.2,>=3.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (3.1.1)
2022-03-04 13:18:40,589 > Requirement already satisfied: wrapt<1.13,>=1.12.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.12.1)
2022-03-04 13:18:40,590 > Collecting flask<2,>=1.1.4
2022-03-04 13:18:40,591 > Downloading https://files.pythonhosted.org/packages/e8/6d/994208daa354f68fd89a34a8bafbeaab26fda84e7af1e35bdaed02b667e6/Flask-1.1.4-py2.py3-none-any.whl (94kB)
2022-03-04 13:18:40,591 > Collecting Jinja2<3,>=2.11.3
2022-03-04 13:18:40,592 > Downloading https://files.pythonhosted.org/packages/7e/c2/1eece8c95ddbc9b1aeb64f5783a9e07a286de42191b7204d67b7496ddf35/Jinja2-2.11.3-py2.py3-none-any.whl (125kB)
2022-03-04 13:18:40,592 > Requirement already satisfied: Flask-Login<0.6,>=0.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (0.5.0)
2022-03-04 13:18:40,593 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.0.0)
2022-03-04 13:18:40,593 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (2.0)
2022-03-04 13:18:40,594 > Requirement already satisfied: werkzeug<2,>=1.0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.0.1)
2022-03-04 13:18:40,595 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (1.1.0)
2022-03-04 13:18:40,595 > Requirement already satisfied: cachelib<0.2,>=0.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.7.3) (0.1)
2022-03-04 13:18:41,599 > Collecting PyYAML<6,>=5.4.1
2022-03-04 13:18:41,601 > Downloading https://files.pythonhosted.org/packages/a0/a4/d63f2d7597e1a4b55aa3b4d6c5b029991d3b824b5bd331af8d4ab1ed687d/PyYAML-5.4.1.tar.gz (175kB)
2022-03-04 13:18:42,670 > Installing build dependencies: started
2022-03-04 13:18:42,674 > Installing build dependencies: finished with status 'error'
2022-03-04 13:18:42,686 ! ERROR: Command errored out with exit status 1:
2022-03-04 13:18:42,690 ! command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-Uibc2O/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython
2022-03-04 13:18:42,691 ! cwd: None
2022-03-04 13:18:42,693 ! Complete output (24 lines):
2022-03-04 13:18:42,694 ! Traceback (most recent call last):
2022-03-04 13:18:42,696 ! File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
2022-03-04 13:18:42,697 ! "__main__", fname, loader, pkg_name)
2022-03-04 13:18:42,699 ! File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
2022-03-04 13:18:42,700 ! exec code in run_globals
2022-03-04 13:18:42,701 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/__main__.py", line 16, in <module>
2022-03-04 13:18:42,702 ! from pip._internal.main import main as _main  # isort:skip # noqa
2022-03-04 13:18:42,704 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/main.py", line 13, in <module>
2022-03-04 13:18:42,705 ! from pip._internal.cli.autocompletion import autocomplete
2022-03-04 13:18:42,707 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/autocompletion.py", line 11, in <module>
2022-03-04 13:18:42,708 ! from pip._internal.cli.main_parser import create_main_parser
2022-03-04 13:18:42,709 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
2022-03-04 13:18:42,710 ! from pip._internal.cli import cmdoptions
2022-03-04 13:18:42,712 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/cmdoptions.py", line 25, in <module>
2022-03-04 13:18:42,713 ! from pip._internal.locations import USER_CACHE_DIR, get_src_prefix
2022-03-04 13:18:42,714 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/locations.py", line 18, in <module>
2022-03-04 13:18:42,716 ! from pip._internal.utils import appdirs
2022-03-04 13:18:42,717 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/appdirs.py", line 16, in <module>
2022-03-04 13:18:42,719 ! from pip._internal.utils.compat import WINDOWS, expanduser
2022-03-04 13:18:42,720 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/compat.py", line 17, in <module>
2022-03-04 13:18:42,721 ! from pip._vendor.urllib3.util import IS_PYOPENSSL
2022-03-04 13:18:42,722 ! File "/home/pi/oprint/lib/python2.7/site-packages/pip/_vendor/urllib3/__init__.py", line 21, in <module>
2022-03-04 13:18:42,724 ! from logging import NullHandler
2022-03-04 13:18:42,725 ! ImportError: cannot import name NullHandler
2022-03-04 13:18:42,726 ! ----------------------------------------
2022-03-04 13:18:42,728 ! ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-Uibc2O/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython Check the logs for full command output.
