Cannot upgrade from 1.6.1 to 1.7.3
Blockquote
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpDtHQZa
cwd: /tmp/pip-install-wRu6sX/psutil
Complete output (10 lines):
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 280, in
main()
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 263, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 108, in get_requires_for_build_wheel
backend = _build_backend()
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 99, in _build_backend
obj = getattr(obj, path_part)
AttributeError: 'module' object has no attribute 'legacy'
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpDtHQZa Check the logs for full command output.
Getting requirements to build wheel: finished with status 'error'
The update did not finish successfully. Please consult octoprint.log
and plugin_softwareupdate_console.log
for details.
Blockquote
tried to upgrade in safe mode
updated pip version
installed the cleanup_loggin plugin
Yes
added
octoprint.log (132.1 KB)
plugin_softwareupdate_console.log (449.3 KB)
OctoPrint 1.6.1
Python 2.7.13
OctoPi 0.16.0
Ender3
Marlin 2.0
Chrome
Win10Pro
