Camera model Raspberry Pi Cam
What is the problem? the only resolutions that work are 640x480 (no options specified in octopi.txt) and 1920x1080 (Very zoomed in)
If I set any other resolution, I get no picture at http://192.168.1.34/webcam/?action=stream
What did you already try to solve it? following the guide again very closely at V0.4 Configuring a Raspberry Pi Camera 路 FormerLurker/Octolapse Wiki 路 GitHub
Logs (/var/log/webcamd.log
, syslog, dmesg, ... no logs, no support)
cfg_file: /boot/octopi.txt
camera: raspi
usb options: -f 10
raspi options: -fps 10
http options: -w ./www
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
config file='/boot/octopi.txt':Start MJPG-streamer with video device: raspi
<13>Jan 30 13:46:32 root: Starting Raspberry Pi camera
Running ./mjpg_streamer -o output_http.so -w ./www -i input_raspicam.so -fps 10
i: fps.............: 10
i: resolution........: 640 x 480
i: camera parameters..............:
Sharpness 0, Contrast 0, Brightness 50
Saturation 0, ISO 0, Video Stabilisation No, Exposure compensation 0
Exposure Mode 'auto', AWB Mode 'auto', Image Effect 'none'
Metering Mode 'average', Colour Effect Enabled No with U = 128, V = 128
Rotation 0, hflip No, vflip No
ROI x 0.000000, y 0.000000, w 1.000000 h 1.000000
o: www-folder-path......: ./www/
o: HTTP Listen Address..: (null)
o: commands.............: enabled
i: Starting Camera
Encoder Buffer Size 81920
/root/bin/webcamd: line 154: 19265 Segmentation fault LD_LIBRARY_PATH=. ./mjpg_streamer -o "output_http.so -w $camera_ht
tp_webroot $camera_http_options" -i "$input"
Goodbye...
Starting up webcamDaemon...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:47:05 root: Starting Raspberry Pi camera
i: Starting Camera
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:50:33 root: Starting Raspberry Pi camera
i: Starting Camera
/root/bin/webcamd: line 287: 497 Segmentation fault LD_LIBRARY_PATH=. ./mjpg_streamer -o "output_http.so -w $camera_ht
tp_webroot $camera_http_options" -i "$input" (wd: /home/pi/mjpg-streamer)
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:51:21 root: Starting Raspberry Pi camera
i: Starting Camera
/root/bin/webcamd: line 287: 774 Segmentation fault LD_LIBRARY_PATH=. ./mjpg_streamer -o "output_http.so -w $camera_ht
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:51:53 root: Starting Raspberry Pi camera
i: Starting Camera
/root/bin/webcamd: line 287: 801 Segmentation fault LD_LIBRARY_PATH=. ./mjpg_streamer -o "output_http.so -w $camera_ht
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:52:25 root: Starting Raspberry Pi camera
i: Starting Camera
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:54:08 root: Starting Raspberry Pi camera
i: Starting Camera
/root/bin/webcamd: line 154: 926 Segmentation fault LD_LIBRARY_PATH=. ./mjpg_streamer -o "output_http.so -w $camera_ht
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:54:40 root: Starting Raspberry Pi camera
i: Starting Camera
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:57:02 root: Starting Raspberry Pi camera
i: Starting Camera
/root/bin/webcamd: line 154: 1015 Segmentation fault LD_LIBRARY_PATH=. ./mjpg_streamer -o "output_http.so -w $camera_ht
Goodbye...
camera: raspi
usb options: -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 13:57:34 root: Starting Raspberry Pi camera
i: Starting Camera
Goodbye...
camera: raspi
usb options: -r 640x480 -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Jan 30 14:31:01 root: Starting Raspberry Pi camera
i: Starting Camera
Goodbye...
camera: usb
usb options: -r 1920x1080 -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev
/video0
<13>Jan 30 14:34:06 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 1920x1080 -f 10 -d /dev/video0
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 10
i: Format............: JPEG
Goodbye...
camera: usb
usb options: -r 1640x1232 -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
/video0
<13>Jan 30 14:36:05 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 1640x1232 -f 10 -d /dev/video0
i: Desired Resolution: 1640 x 1232
Goodbye...
i: select() timeout
i: cleaning up resources allocated by input thread
camera: usb
usb options: -r 2592x1944 -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
/video0
<13>Jan 30 14:42:41 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 2592x1944 -f 10 -d /dev/video0
i: Desired Resolution: 2592 x 1944
Goodbye...
i: select() timeout
camera: usb
usb options: -r 3280x2464 -f 10
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
/video0
<13>Jan 30 14:45:52 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 3280x2464 -f 10 -d /dev/video0
i: Desired Resolution: 3280 x 2464
i: The specified resolution is unavailable, using: width 2592 height 1944 instead
Goodbye...
i: select() timeout
camera: usb
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
/video0
<13>Jan 30 14:48:02 root: Starting USB webcam
Goodbye...
i: select() timeout
OctoPrint version : 1.7.3
OctoPi version : 0.18.0
