@b-morgan Alright. Also the cable is Data compatible because while I was trying to install firmware Arduino IDE was able to restart the printer it just wasn't able to write to it
And here is the logs
[   67.905565] usb 1-1.1: USB disconnect, device number 9
[   67.905970] Indeed it is in host mode hprt0 = 00001101
[   68.119925] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[   68.120043] Indeed it is in host mode hprt0 = 00001101
[   68.709954] usb 1-1.1: new high-speed USB device number 10 using dwc_otg
[   68.850164] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[   68.850189] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   68.851295] usb 1-1.1: can't set config #1, error -71
[   79.371590] usb 1-1.1: USB disconnect, device number 10
[   79.372071] Indeed it is in host mode hprt0 = 00001101
[   79.589519] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[   79.589648] Indeed it is in host mode hprt0 = 00001101
[   80.169463] usb 1-1.1: new high-speed USB device number 11 using dwc_otg
[   80.299599] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[   80.299623] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   80.300552] usb 1-1.1: can't set config #1, error -71
[   93.903098] usb 1-1.1: USB disconnect, device number 11
[   93.903591] Indeed it is in host mode hprt0 = 00001101
[   94.108822] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[   94.108936] Indeed it is in host mode hprt0 = 00001101
[   94.688833] usb 1-1.1: new high-speed USB device number 12 using dwc_otg
[   94.818997] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[   94.819022] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[   94.820577] usb 1-1.1: can't set config #1, error -71
[  102.278469] usb 1-1.1: USB disconnect, device number 12
[  102.279170] Indeed it is in host mode hprt0 = 00001101
[  102.498643] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[  102.498757] Indeed it is in host mode hprt0 = 00001101
[  103.098649] usb 1-1.1: new high-speed USB device number 13 using dwc_otg
[  103.228836] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[  103.228861] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  103.229767] usb 1-1.1: can't set config #1, error -71
[  110.688294] usb 1-1.1: USB disconnect, device number 13
[  110.688845] Indeed it is in host mode hprt0 = 00001101
[  110.918576] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[  110.918686] Indeed it is in host mode hprt0 = 00001101
[  111.538546] usb 1-1.1: new high-speed USB device number 14 using dwc_otg
[  111.668754] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[  111.668782] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  111.669770] usb 1-1.1: can't set config #1, error -71
[  111.670039] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  111.670147] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  119.118218] usb 1-1.1: USB disconnect, device number 14
[  119.118718] Indeed it is in host mode hprt0 = 00001101
[  119.328456] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[  119.328558] Indeed it is in host mode hprt0 = 00001101
[  119.928470] usb 1-1.1: new high-speed USB device number 15 using dwc_otg
[  120.058715] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[  120.058742] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  120.059563] usb 1-1.1: can't set config #1, error -71
[  120.059812] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  120.059910] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  127.507982] usb 1-1.1: USB disconnect, device number 15
[  127.508462] Indeed it is in host mode hprt0 = 00001101
[  127.718461] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[  127.718592] Indeed it is in host mode hprt0 = 00001101
[  128.318465] usb 1-1.1: new high-speed USB device number 16 using dwc_otg
[  128.448641] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[  128.448666] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  128.449521] usb 1-1.1: can't set config #1, error -71
[  128.449819] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  128.449907] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  135.898157] usb 1-1.1: USB disconnect, device number 16
[  135.898825] Indeed it is in host mode hprt0 = 00001101
[  136.108426] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[  136.108536] Indeed it is in host mode hprt0 = 00001101
[  136.698396] usb 1-1.1: new high-speed USB device number 17 using dwc_otg
[  136.838696] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[  136.838730] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  136.839832] usb 1-1.1: can't set config #1, error -71
[  136.840282] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  136.840477] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  144.288000] usb 1-1.1: USB disconnect, device number 17
[  144.288574] Indeed it is in host mode hprt0 = 00001101
[  144.508141] usb 1-1: reset high-speed USB device number 2 using dwc_otg
[  144.508307] Indeed it is in host mode hprt0 = 00001101
[  145.088111] usb 1-1.1: new high-speed USB device number 18 using dwc_otg
[  145.218294] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[  145.218318] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[  145.219169] usb 1-1.1: can't set config #1, error -71
[  145.219475] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
[  145.219580] hub 1-1:1.0: hub_ext_port_status failed (err = -71)
pi@octopi:~ $
