Can't detect camera in OctoPrint
Raspberry Pi Camera Rev V1.3 connected to Raspberry Pi 4 Model B.
The webcam stream is unable to load on octoprint.
I have tried everything here (OctoPrint-CameraSettings/docs/setup.md at c24b20961b4b2b78fc9e7e0fe0259dbdb9fcc2e7 路 The-EG/OctoPrint-CameraSettings 路 GitHub) as well as what octoprint has instructed me to do - add a "-y" behind the camera_usb_options="-r 640x480 -f 10 -y"
Previously, I am using the Raspberry Pi Model 3 I think. The Octoprint, python and OctoPi is an older version. The code previously and now are slightly different after plugging in the camera and powering on.
Hello @wong !
Where is the systeminfo bundle?
What OctoPrint/OctoPi version do you run?
What have you set at OctoPrint Settings -> Plugins -> Classic Webcam?
BTW:
Both stream aspect ratio of 16:9 and 4:3 - The test is unable to display a view.
Also, I know is 3 years ago as my current raspberry pi has been running this firmware for quite sometime. Just that I bought a new raspberry pi and couldn't get it to connect.
Old vs. New
Octoprint: 1.8.6 vs 1.10.3
Python: 3.7.3 vs 3.9.2
OctoPi: 0.18.0 vs 1.0.0
What are your settings at Stream URL and Snapshot URL?
this should not be necessary with a picam.
Stream aspect ratio is 4:3, Stream timeout is 5 sec with cache buster enabled.
Stream URL unable to display any images in test function.
Snapshot timeout is at 5 seconds with "Validate SSL on snapshot URL" tick box checked.
Snapshot URL couldn't retrieve snapshot URL.
I've tried both - including and not including "-y". Both didn't work.
What URL did you use?
I am not sure if this is it? Or am I supposed to check somewhere else?
SSH to the pi, run these commands, and report back what is returned.
vcgencmd get_camera
v4l2-ctl --list-formats-ext
also, open OctoPrint and in the very bottom of the page click the System link. Click the button to download a system info bundle, and upload it here using the upload button.
pi@Octopi:~ vcgencmd get_camera supported=1 detected=0, libcamera interfaces=0 pi@Octopi:~ v412-ctl --list-formats-ext
-bash: v412-ctl: command not found
These are the returns.
octoprint-systeminfo-20250326092622.zip (1.4 MB)
lowercase letter L not the number 1 in v412-ctl --list-formats-ext, but the fact that detected=0 makes me think your camera isn't connected right, or possibly the tiny ribbon cable between the camera sensor and it's board has come loose.
Hi, I have tested with my old raspberry pi. The current camera has light powered on and it is working on the old raspberry pi 3. So I am not sure if there's some modification to the code to enable it on raspberry pi 4B.
On the raspberry pi 4B, i also dont have the enable camera setting under the interface setting.
