Can't get Arduino IDE working on Octoprint image
Arduino IDE (both from the distribution and the Arduino ARM file) doesn't launch
I've tried installing as root and manually creating the directories it can't find.
Octopi-strech-lite-0.16.0 Pi image and IDE from distro plus 1.8.8 and 1.8.9 form the Arduino site.
I just need to know if I have to troubleshoot from the octoprint image side or the Arduino IDE side. Anyone else have this issue?
Thanks,
Steve Hurd
Floyds Knobs, IN
Since stretch lite doesn't have a dashboard and I beleive the IDE a dashboard tool you are going to have to eithor
  1. install the full version of stretch or
  2. try the arduino CLI - google 'arduino cli'
I loaded the GUI desktop using sudo /home/pi/scripts/install-desktop.
Steve Hurd
Why would you want to do Arduino development on your OctoPrint installation? Why not instead install it on your MacBook or you PC laptop?
Yes, you can install the PIXEL/Desktop but this robs processing power from OctoPrint and the printing functions.
I do have it on my pc. Until I can figure out Python and can drive WS2812b LEDs from the Pi natively I have an Uno connected to the pi to drive the LEDs that light the bed. If I want to change the color of the leds I need to move the usb cable back to my laptop to change the program. I'm still in the beginning stages of this and so far I haven't had an issue with the desktop running on the Pi with octoprint. I haven't found RGB plugins that fit my needs yet and I already know how to use the IDE.
Thanks for your help!
Steve Hurd
I did some work with the Neopixel style of LEDs, noting that they seem to like a 5V logic level rather than the 3.3V of the Raspi. I'm reasonably certain that the WS2812B are the heart of those Neopixels, for what it's worth.
That said, it's reasonably easy to get the Arduino (5V logic) to drive them. Getting the Raspi to drive them (3.3V logic) is problematic. You may need a logic level converter from 3.3V to 5V for this project. You might want to read within the tutorial space on Adafruit for this one.
Hi. I already have a buck converter that I'm presently using to drive the Pi from the printer's power supply. Once I get some more components from TH3D (including a usb hub) I'm going to use that converter to feed 5V to the NeoPixels. Then I'll only need to send data from the Pi.
Steve Hurd
A cheap 7400 chip can be used as a logic level converter (times two).
You'd connect pins 1 & 2 to the output of the Raspi, then pin 3 goes to 4 & 5. Pin 14 goes to the Raspi's 5V and Pin 7 goes to the Raspi's ground. Pin 6 then is a 5V-oriented conversion of the 3.3V logical level presented on pins 1 & 2. So, one half of that chip can be used to convert 3.3V to 5V output. The other half of the chip then can be another converter. The cost of these is around a dollar, versus the cost of higher-priced level converters.
Very cool! I've got an LM2596 converter from Amazon. It was only $4 delivered.
Steve Hurd
I think I understand what you mean now. The LOGIC signal needs to be 5V/0V, not just the power rails. Totally missed that! I thought since I was providing 5V through the converter that the data signal level didn't matter. Duh! Long day.
Steve Hurd
Also, keep in mind that lots of LEDs are too hungry for the Raspi. For the 60-LED big ring that Adafruit sells, I had to dedicate a 10A 5V switching power supply for that.
