Can't update from Octoprint 14
I can't update my Octoprint 14 to anything newer.
Have tried numerous times to update, but won't work
Yes
Version 1.4.0 does not offer this Systeminfo Bundle, above says 1.6.0 and above do.
Octoprint version 1.4.0, Octopi 3b+, Printer is Prusa MK3s, browser is Chrome, and Windows 10
The following is what shows up a being failed at the end of trying to update. Everything else seems to load fine.
Downloading https://files.pythonhosted.org/packages/96/0a/67556e9b7782df7118c1f49bdc494da5e5e429c93aa77965f33e81287c8c/zipp-1.2.0-py2.py3-none-any.whl
Exception:
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
status = self.run(options, args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
session=session, autobuilding=True
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 886, in build
assert have_directory_for_build
AssertionError
The update did not finish successfully. Please consult <code>octoprint.log</code> and <code>plugin_softwareupdate_console.log</code> for details.
Heyho :slight_smile:
Try this
