When I try to update, I get the following error message:
The update did not finish successfully. Please consult octoprint.log and plugin_softwareupdate_console.log` for details.
and the follwing red text in the dialogue:
Exception:
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
status = self.run(options, args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
session=session, autobuilding=True
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 886, in build
assert have_directory_for_build
AssertionError
The printer then restarts, and all works well, but updating always fails
However, you are still running Python 2 for your install. You won't have seen the warnings introduced by 1.7.x, but OctoPrint 1.8.0 will drop support for Python 2 and you need to update it. So you could ignore fixing the update issue, because it will be included in upgrading your install.
And yes, this seems to be it... But as I'm not very versed, what do you mean by:
"So you could ignore fixing the update issue, because it will be included in upgrading your install."?
Should I just "live with it" until the next update hits (so it will "resolve itself") or will I need to do a fresh install/update it some how later on?
