I'm trying to change the wifi settings on my Pi Zero W running OctoPrint 1.9.3.
Doing a search and asking AI says there should be a networking section in the UI of OctoPrint. I don't see one. I've also tried modifying the system config files on the SD card by editing on my windows laptop. I uncomment the lines, make the changes, but it doesn't take effect when restarting the Pi.
didn't try
There is no UI section in OctoPrint for setting the WiFi parameters.
Reason: OctoPrint is platform independent. On a system that can run Python, you can install OctoPrint.
You can access an OctoPi setup either via SSH or by connecting a keyboard and Monitor/TV to the Pi and run raspi-config. Here you can change your WiFi credentials.
