Communication timeout on Labists ET4
My Octoprint sometimes pauses the print on random layers/locations. It stays at the position for some seconds and then resumes the print.
My problem is that at the "pause position" the filament leaks a bit and i get a spot with too much filament.
I changed the PSU, because the first one had only 2A.
Didn't try it.
Complete Logs
2021-04-22 17:25:06,569 - Send: N6520 G1 X133.19 Y114.303 E276.75306106
2021-04-22 17:25:06,601 - Recv: ok
2021-04-22 17:25:06,604 - Send: N6521 G1 X133.274 Y115.382 E276.80705
87
2021-04-22 17:25:36,681 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-22 17:25:36,692 - Send: N6522 M10520
2021-04-22 17:25:36,700 - Recv: 807ok T:220 /220 B:70 /70
2021-04-22 17:26:06,754 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-22 17:26:06,757 - Send: N6523 M105
21
2021-04-22 17:26:06,779 - Recv: ok T:222 /220 B:69 /70
2021-04-22 17:26:06,785 - Send: N6524 M10518
2021-04-22 17:26:06,793 - Recv: ok T:222 /220 B:69 /70
2021-04-22 17:26:06,799 - Send: N6525 G1 X133.239 Y116.325 E276.85413
85
2021-04-22 17:26:06,806 - Recv: ok
2021-04-22 17:26:06,809 - Send: N6526 G1 X133.102 Y117.254 E276.90098*88
2021-04-22 17:26:06,818 - Recv: ok
  • Labists ET4 (Printer)
  • Raspberry Pi 3B
  • OctoPrint 1.5.3
  • Python 3.7.3
  • OctoPi 0.18.0
2022-03-16 21:38:11,286 - octoprint.filemanager.analysis - INFO - Analysis of entry local:AET4_bedcable1-54hr.gcode finished, needed 7.55s
2022-03-16 21:38:15,174 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: AET4_bedcable1-54hr.gcode, owner: root, user: root
2022-03-16 21:38:15,189 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2022-03-16 21:38:15,189 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: AET4_bedcable1-54hr.gcode, owner: root, user: root
2022-03-16 21:38:15,205 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-03-16 21:38:15,221 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2022-03-16 21:38:45,336 - octoprint.util.comm - INFO - Timeout while in an active heatup, considering heatup to be over.
2022-03-16 21:38:55,371 - octoprint.util.comm - INFO - No response from printer after 6 consecutive communication timeouts, considering it dead.
2022-03-16 21:38:55,386 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline after error"
2022-03-16 21:38:55,386 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2022-03-16 21:39:10,038 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2022-03-16 21:39:10,038 - octoprint.util.comm - INFO - Connecting to port COM6, baudrate 115200
Just posting a few log lines is not enough to help you :smiley:
I guess you got a similar problem?
Please activate serial logging, try it again and upload the systeminfo bundle afterwards.
