A short while ago, trying to connect to the printer "restarts" it. By that, I mean that, as soon as I hit the "Connect" button in Octopi, the screen on the 3D printer cycles as if it completely restarts. While this happens, Octopi displays " State: Connecting", then after a while, ends with " State: Offline". The power cycle takes a few seconds, but that is enough for Octopi to think it is offline.
Full power cycle video here:
I attempted of course to simply reboot the PI; change the USB plug it was connected to, change the USB cable, power cycle the 3D printer, upgrade Octopi, change various settings that could be remotely related to usb connection (especially "Intervals & timeouts" and "Firmware & protocol"), tried forcing the serial or AUTO; I'm fresh out of ideas!
Complete Logs
Serial.log
2020-09-17 03:08:29,083 - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 03:08:29,283 - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 03:08:29,365 - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 03:08:29,439 - Connected to: Serial<id=0xa8d027d0, open=True>(port='/dev/ttyUSB0', baudrate=57600, bytesize=8, parity='N', stopbits=1, timeout=20.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-09-17 03:08:29,530 - Send: N0 M11035
2020-09-17 03:09:09,559 - No answer from the printer within the connection timeout, trying another hello
2020-09-17 03:09:09,611 - Send: N0 M11035
2020-09-17 03:09:29,612 - There was a timeout while trying to connect to the printer
2020-09-17 03:09:29,653 - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 03:09:29,749 - Connection closed, closing down monitor
octoprint.log (partial as it complains my post is too big and contains too many links...)
2020-09-17 02:22:04,622 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 388038656
| os:
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi Model B Rev 2
| octopi_version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
| virtualenv: /home/pi/oprint
2020-09-17 02:22:20,623 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 02:22:20,814 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 02:22:21,026 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 02:22:21,134 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2020-09-17 02:22:21,492 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2020-09-17 02:22:21,597 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2020-09-17 02:22:21,700 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-09-17 02:23:20,873 - octoprint.access.users - INFO - Logged in user: mario
2020-09-17 02:51:17,984 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-09-17 02:53:20,558 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1933}
2020-09-17 02:59:15,532 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 02:59:15,638 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 02:59:15,742 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 02:59:55,935 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 02:59:56,040 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-09-17 03:02:38,683 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 03:02:38,801 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 03:02:38,914 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 03:03:19,131 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 03:03:19,246 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-09-17 03:03:57,353 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 03:03:57,465 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 03:03:57,583 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 03:04:37,832 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 03:04:37,932 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-09-17 03:05:26,053 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 03:05:26,167 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 03:05:26,275 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 03:05:26,374 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-17 03:05:47,638 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 03:05:47,742 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-09-17 03:05:54,512 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 03:05:54,617 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 03:05:54,731 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 03:05:54,884 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-17 03:06:07,133 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 03:06:07,236 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-09-17 03:06:17,995 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-09-17 03:08:20,979 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 2833}
2020-09-17 03:08:29,093 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-09-17 03:08:29,252 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 57600
2020-09-17 03:08:29,376 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-09-17 03:08:29,492 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-17 03:09:09,588 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-09-17 03:09:29,679 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2020-09-17 03:09:29,802 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
Octoprint Version 1.4.2
Octopi 0.15.1
Running on: Raspberry Pi Model B Rev 2
3D Printer: Anet A8 Compatible
Firmware: OMNI_V1.4 M-505
Google Chrome Version 85.0.4183.102 (Official Build) (64-bit)
Windows 10 64-bits
