Crazy printer with OctoPrint
My printer is doing all kinds of crazy stuff. A lot of extra moves at the start of a run, then after each layer it is going back to the center, then back to where the print starts. When it runs the starting test on the left edge, it even prints it in the air.
I have narrowed my problem down to OctoPrint. I took the same g-code file and connected my laptop to the printer, and printed from Pronterface. It came out perfect and zero issues. So I know it is something that OctoPrint s doing, I just dont know why or how to fix it.
Creality CR-10 Max, with new MicroSwiss Hot end and direct extruder.
Whatever the current version of octoprint is. It updates automatically.
I have been using Prusa for my slicer
I think you forgot this part :wink:
Complete Logs
Without logs we can't really tell what's going on
Also try it in safe mode to rule out plugin related problems.
Ok. I’ll try to do that Wednesday when I get home.
Sounds like some timelapse activity, is that enabled?
maybe Octolapse - timelapse doesn't do that.
Update:
So it did look like timelapse was on. And I was getting duplicate startup codes. 1st set was being output from my slicer and another by OctoPrint. I deleted the start and end codes in OctoPrint and disabled Timelapse. Worked perfect.
Thanks for the help everybody
