Anyone tried and tested octprint with the Creality CR-200B printer and what settings?
Hi, so it seems I am alone ...
connected octoprint and it seems to work although it is very unstabel... I end up with the usual suspect topics about usb stability etc.
I have tried both links from:
but keep getting:
But printing does seem to work...
Well somebody has to be the first user
edit: didn't see your last sentence.
If you think everything is working and want to disable the warning - you can do it here
or disable the whole plugin here
If the plugin is reporting an issue, then there is definitely still something wrong. I wouldn't disable it. Can you enable serial.log, reproduce the issue and then upload the systeminfo bundle?
