Creality Ender 5 Plus using OctoPrint Filament Runout detection FAILS
Tried OctoPrint Plugins ALL
Complete Logs
`2019-09-26 01:25:09,369 - octoprint.startup - INFO - ******************************************************************************
2019-09-26 01:25:09,373 - octoprint.startup - INFO - Starting OctoPrint 1.3.12
2019-09-26 01:25:09,375 - octoprint.startup - INFO - ******************************************************************************
2019-09-26 01:25:09,561 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-26 01:25:13,684 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 23 hook handlers
2019-09-26 01:25:13,994 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-09-26 01:25:14,143 - octoprint.server - INFO - Intermediary server started
2019-09-26 01:25:14,145 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-09-26 01:25:14,395 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 23 hook handlers
2019-09-26 01:25:14,399 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
2019-09-26 01:25:14,676 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-09-26 01:25:14,679 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-09-26 01:25:17,192 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-26 01:25:19,254 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2019-09-26 01:25:19,257 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-26 01:25:19,259 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-09-26 01:25:19,267 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-09-26 01:25:19,510 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
**Not enough space to post it all**
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
2019-09-26 01:24:48,293 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-26 01:24:48,367 - octoprint.plugins.pluginmanager - ERROR - Could not fetch plugins from repository at https://plugins.octoprint.org/plugins.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x720596b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 823, in _fetch_repository_from_url
r = requests.get(repository_url, timeout=30)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url,
packages/octoprint/plugins/announcements/__init__.py", line 355, in _get_channel_data_from_network
r = requests.get(url, timeout=30)
return session.request(method=method, url=url, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/important.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x72059970>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2019-09-26 01:24:48,409 - octoprint.plugins.announcements - ERROR - Could not fetch channel _releases from https://octoprint.org/feeds/releases.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/releases.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x72074ef0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements/__init__.py", line 355, in _get_channel_data_from_network
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/releases.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x72074ef0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2019-09-26 01:24:48,448 - octoprint.plugins.announcements - ERROR - Could not fetch channel _blog from https://octoprint.org/feeds/octoblog.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x72059bf0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
ConnectionError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x72059bf0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
2019-09-26 01:24:48,449 - octoprint.plugins.pluginmanager - ERROR - Could not fetch notices from https://plugins.octoprint.org/notices.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /notices.json (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x720596b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',))
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/__init__.py", line 891, in _fetch_notices_from_url
r = requests.get(notices_url, timeout=30)
2019-09-26 01:24:46,908 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917016576
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2019-09-26 01:24:46,924 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-09-26 01:24:46,927 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-09-26 01:24:48,583 - octoprint.server - INFO - Shutting down intermediary server...
2019-09-26 01:24:49,085 - octoprint.server - INFO - Intermediary server shut down
2019-09-26 01:24:49,090 - octoprint.events - INFO - Processing startup event, this is our first event
2019-09-26 01:24:49,092 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-09-26 01:24:49,097 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-09-26 01:24:49,103 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2019-09-26 01:24:49,105 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-09-26 01:24:49,112 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2019-09-26 01:24:49,137 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-09-26 01:24:49,307 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-09-26 01:24:49,317 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-09-26 01:24:49,380 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
2019-09-26 01:24:49,400 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-09-26 01:24:50,030 - octoprint.plugins.announcements - ERROR - Could not fetch channel _important from https://octoprint.org/feeds/important.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/important.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests/adapters.py", line 514, in send
raise SSLError(e, request=request)
SSLError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/important.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:50,119 - octoprint.plugins.pluginmanager - ERROR - Could not fetch plugins from repository at https://plugins.octoprint.org/plugins.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
SSLError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /plugins.json (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:50,300 - octoprint.plugins.announcements - ERROR - Could not fetch channel _releases from https://octoprint.org/feeds/releases.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/releases.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
SSLError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/releases.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:50,382 - octoprint.plugins.pluginmanager - ERROR - Could not fetch notices from https://plugins.octoprint.org/notices.json: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /notices.json (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
SSLError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /notices.json (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:50,549 - octoprint.plugins.announcements - ERROR - Could not fetch channel _blog from https://octoprint.org/feeds/octoblog.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
SSLError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octoblog.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:50,793 - octoprint.plugins.announcements - ERROR - Could not fetch channel _plugins from https://plugins.octoprint.org/feed.xml: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /feed.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
SSLError: HTTPSConnectionPool(host='plugins.octoprint.org', port=443): Max retries exceeded with url: /feed.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:51,047 - octoprint.plugins.announcements - ERROR - Could not fetch channel _octopi from https://octoprint.org/feeds/octopi.xml: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octopi.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
SSLError: HTTPSConnectionPool(host='octoprint.org', port=443): Max retries exceeded with url: /feeds/octopi.xml (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:727)'),))
2019-09-26 01:24:51,840 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-09-26 01:24:51,843 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-09-26 01:24:51,845 - octoprint.util.pip - INFO - ==> pip ok -> yes
OctoPrint version, OctoPi version, printer,OctoPrint
The snappy web interface for your 3D printer
Version 1.4.2
Chrome latest**
