Using nginx as a reverse proxy, when reverse proxying HTTPS on a non-standard port, there is no way to get Octoprint to respond with the appropriate CSRF port.
The main problem seems to be that X-Forwarded-Port is not respected, and when X-Forwarded-Proto is used it overwrites the ports used for CSRF.
I've done some pretty extensive research into CSRF and nginx, and followed ideas from Reverse proxy configuration examples
Configurations I have attempted include almost every combination of commenting and uncommenting the below proxy_set_header lines. The below configuration results in the attached screenshot (edited domain).
server {
listen 12345 ssl;
server_name octoprint.domain.com;
gzip off;
ssl_certificate /letsencrypt/live/domain.com/fullchain.pem;
ssl_certificate_key /letsencrypt/live/domain.com/privkey.pem;
ssl_session_cache shared:SSL:10m;
ssl_protocols TLSv1.2;
ssl_ciphers HIGH:!aNULL:!MD5;
modsecurity on;
modsecurity_rules_file /etc/nginx/conf/modsec.conf;
add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
proxy_buffering off;
client_max_body_size 10G;
location / {
proxy_pass http://192.168.0.21/;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
#proxy_set_header X-Scheme $scheme;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Scheme $scheme;
#proxy_set_header X-Forwaded-Host "octoprint.domain.com";
#proxy_set_header X-Forwaded-Host "octoprint.domain.com:12345";
proxy_set_header X-Forwaded-Host $host;
#proxy_set_header X-Forwarded-Port 12345;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $http_connection;
#proxy_set_header Authorization $http_authorization;
#proxy_set_header X-Forwarded-Ssl on;
#proxy_pass_header X-CSRFToken;
