This is certainly a problem with my printer, not OctoPrint. I think my printer is missing some functionality.
However, I'd be very grateful for any advice with this - has anyone managed to get a CTC A13 printer working with OctoPrint? If this isn't appropriate for your forum, my apologies, please delete me
I've successfully set up OctoPi on a Raspberry Pi B v1. It's slow, but the webcam bit is working and it attempts to connect to my printer. It figures out the port, baud rate, and asks the printer for some information. I can see the printer replying with lots of configuration data.
Then, OctoPrint sends an M105 command, which I believe is requesting temperature data. This command always times out.
Increased comms timeout, no change.
Connected to the printer from a Win10 PC using Powershell, opening the comms port directly. This also behaved in exactly the same manner as OctoPrint - everything worked until the M105 command. This is why I think it's a problem with the printer and not OctoPrint.
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0xb00400d0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Send: N0 M110 N0*125
Recv: Test my message
Recv: echo: External Reset
Recv: 1.0.0
Recv: echo:(none, default config)
Recv: Dec 27 2018
Recv: echo:10075echo:Hardcoded Default Settings Loaded
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E93.00echo:Maximum feedrates (mm/s):
Recv: echo: M203 X500.00 Y500.00 Z5.00 E25.00echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X500 Y500 Z100 E5000echo:Acceleration: S=acceleration, T=retract acceleration
Recv: echo: M204 S500.00 T500.00echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00echo:PID settings:
Recv: echo: M301 P21.73 I1.54 D76.55echo:SD card ok
Recv: ok
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:http://www.mendel-parts.com PROTOCOL_VERSION:1.0 MACHINE_TYPE:CTC 3D EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: ok
Send: M20
Recv: Begin file list
Recv: End file list
Recv: ok
Send: M105
Send: M105
at this point, OctoPrint reports that the connection has failed
OctoPi version 0.17.0
CTC A13 printer, firmware:Marlin V1; Sprinter/grbl mashup for gen6 (that's what the printer claims during the connnection attempt)
Firefox and Chrome used.
Also tried direct serial connection from Win10PC, same result.
