I recently purchased an Ender 3 Pro and love it. I decided to connect it to OctoPrint. I used the website instructions to get it all up and running. I’m using a raspberry pi 3B+. Here is my issue:
- I’ve been getting failed prints while using OctoPrint. I designed sometime or downloaded something to print. From Cura I uploaded the gcode file up to OctoPrint and kicked off the print. I walked away for some time and when I checked on it I noticed the camera feed was stopped and it was no longer connected. When I made it to the printer I was able to pull of the log which essentially simply stated that there was an error that disconnected OctoPrint from the printer. I tried multiple prints, multiple days with no luck. I have already rebuilt the OctoPrint OS and still get the same error.
I’ve tried almost everything for troubleshooting the rpi so I decided to run OctoPrint from my windows 10 machine and so far I have printed successfully twice!
Checked USB, ran OctoPrint from windows instead of raspberry pi, multiple prints, different days. See description of issues and logs section.
Logs (octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!)
So I finally had time to sit through a print and watch closely. Here's what I did:
- SSH'd to my pi and ran uptime (it said it had been running for about 13 hours which is correct)
- Ran top to make sure the pi was not running out of resources (as some of you suggested)
- from my machine i ran a continuous ping to the pi
- loaded a small 40 minute print to octoprint and ran it.
Keep in mind I'm using the exact same cable that I used to run octoprint from my windows machine (2 prints totaling 8 hours went flawless). During the print I wiggled the usb (as some of you suggested) from the pi and the printer side and the print continued as normal.Unfortunately the print went flawless however once the print was done (a few minutes afterwards). I went to load up a different print, perhaps a longer one to see if I could recreate the issue. From Cura to octorpint was sucessfull so when I launched the octoprint ui I noticed this error under state: Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793).
When I looked through the octoprint.log, this is what I found:
2019-10-30 09:51:58,364 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2019-10-30 09:51:58,382 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: CE3_tmpna6cdjxtCr-10_Extruder_knob_V2.gcode, owner: lal309
2019-10-30 09:51:58,414 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2019-10-30 09:55:35,765 - octoprint.plugins.anywhere - ERROR - [Errno 32] Broken pipe
2019-10-30 09:57:36,343 - octoprint.plugins.anywhere - ERROR - [Errno 32] Broken pipe
2019-10-30 10:03:25,239 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2793, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4932, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2019-10-30 10:03:25,276 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2019-10-30 10:03:25,296 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
2019-10-30 10:03:26,229 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.5) 18.89ms
2019-10-30 10:03:36,248 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.5) 18.87ms
2019-10-30 10:03:46,244 - tornado.access - WARNING - 409 GET /api/printer (::ffff:192.168.0.5) 19.21ms
When I looked through the serial log, this is what I found:
2019-10-30 10:03:05,472 - Recv: T:26.53 /0.00 B:36.33 /0.00 @:0 B@:0
2019-10-30 10:03:07,474 - Recv: T:26.53 /0.00 B:36.33 /0.00 @:0 B@:0
2019-10-30 10:03:09,474 - Recv: T:26.53 /0.00 B:36.33 /0.00 @:0 B@:0
2019-10-30 10:03:11,474 - Recv: T:26.51 /0.00 B:36.23 /0.00 @:0 B@:0
2019-10-30 10:03:13,474 - Recv: T:26.48 /0.00 B:36.08 /0.00 @:0 B@:0
2019-10-30 10:03:15,473 - Recv: T:26.56 /0.00 B:36.15 /0.00 @:0 B@:0
2019-10-30 10:03:17,474 - Recv: T:26.45 /0.00 B:36.02 /0.00 @:0 B@:0
2019-10-30 10:03:19,475 - Recv: T:26.42 /0.00 B:36.00 /0.00 @:0 B@:0
2019-10-30 10:03:21,474 - Recv: T:26.36 /0.00 B:36.00 /0.00 @:0 B@:0
2019-10-30 10:03:23,474 - Recv: T:26.36 /0.00 B:36.00 /0.00 @:0 B@:0
2019-10-30 10:03:25,275 - Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793
2019-10-30 10:03:25,287 - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2019-10-30 10:03:25,295 - Changing monitoring state from "Operational" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
2019-10-30 10:03:25,322 - Connection closed, closing down monitor
After looking at the logs I ran "uptime" again to ensure the pi was not rebooted and the command showed 14 hours. So no reboot. I reviewed my continuous ping to ensure it had not drop it's internet connection and the ping showed no breaks.
Latest version of octopi and OctoPrint. Ender 3 Pro. Rpi 3B+.
I also ran an 8 hour print and at the 7.5 hour mark this happened again. The logs showed exact same messages from web us, OctoPrint.log and serial.log
