Octopi doesnt connect
Downloaded new version, and flashed new version. Then formated SD card and flashed new version again. Also tried different cables. Searched every thread with this issue i could find.
Complete Logs
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0xabe853f0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
No answer from the printer within the connection timeout, trying another hello
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
octoprint.log (26.3 KB)
OctoPrint version: 1.3.12, OctoPi version: 0.17.0, printer: Ender 3 Pro, firmware: Marlin 1.19, browser: chrome, operating system: Win10, Octoprint is running off a RPi 4 that is connected via USB to my printer>
If I attempt to connect using AUTO Serial Port and Baudrate, this is the log I get:
Serial port list: ['/dev/ttyUSB0']
Changing monitoring state from "Detecting serial port" to "Opening serial port"
Connected to: Serial<id=0xabf7c730, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Changing monitoring state from "Opening serial port" to "Detecting baudrate"
Trying baudrate: 115200
Baudrate test retry #1
Baudrate test retry #2
Baudrate test retry #3
Baudrate test retry #4
Trying baudrate: 250000
Trying baudrate: 230400
Trying baudrate: 57600
Trying baudrate: 38400
Trying baudrate: 19200
Trying baudrate: 9600
Changing monitoring state from "Detecting baudrate" to "Error: No more baudrates to test, and no suitable baudrate found."
Changing monitoring state from "Error: No more baudrates to test, and no suitable baudrate found." to "Offline (Error: No more baudrates to test, and no suitable baudrate found.)"
I'm at the end of my tether with this. I had a perfectly working Octoprint running, then I attempted to edit my firmware to install my BLTouch and I've had problem after problem. This is one I simply cannot figure out. I feel like I've tried everything except reach out with my logs. Please end my suffering
I have installed Marlin before without it though, i do remember it being quite the task but I believe I can do it again. I will run through the guide you posted and see if I can get it running again.
