aztrip
August 31, 2020, 2:48pm
1
After a print is completed, OctoPrint and Octopod are not reporting current temperatures for nozzle and bed.
Verified Ender-3 v2 is sending temps to OctoPrint.
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum , browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
serial-2.log (131.3 KB)
OctoPrint 1.4.2
Python 2.7.16
OctoPi 0.17.0
Creality Ender-3 V2
FW: 1.02
Browser: Safari
MacOS: 10.15.6
It does report:
2020-08-31 15:33:22,160 - Changing monitoring state from "Finishing" to "Operational"
2020-08-31 15:33:22,389 - Recv: TT::196.99196.99 //0.000.00 BB::49.0549.05 //0.000.00 @@::00 BB@@::00
2020-08-31 15:33:22,390 - Recv:
2020-08-31 15:33:24,389 - Recv: TT::194.40194.40 //0.000.00 BB::48.9548.95 //0.000.00 @@::00 BB@@::00
2020-08-31 15:33:24,391 - Recv:
2020-08-31 15:33:26,388 - Recv: TT::191.65191.65 //0.000.00 BB::48.9548.95 //0.000.00 @@::00 BB@@::00
2020-08-31 15:33:26,399 - Recv:
2020-08-31 15:33:28,389 - Recv: TT::188.62188.62 //0.000.00 BB::48.8848.88 //0.000.00 @@::00 BB@@::00
but it's the ender firmware issue that inhibits OctoPrint to read a value.
You may have a look on this thread:
Hello,
Installed and connected octoprint to my new ender 3 V2. everything smooth, great !
There is just a small problem, the temperature reported by the printer doesn't show on the display.
[image]
It looks like the terminal codes reports are not standard.
2020-06-14 09:04:21,533 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2020-06-14 09:14:53,639 - Enabling serial logging
2020-06-14 09:14:54,667 - Recv: TT::2β¦
and onto the fix in post 7:
As for not owning an Arduino, see https://www.th3dstudio.com/product/arduino-uno-bootloader-flashing-kit/ .
I missed your post about it working once the gcode is launched. I wrote a plugin to fix the (now idle only) reports which I'll include here just because it is ready for testing. It goes in the ~/.octoprint/plugins directory and its output will appear in octoprint.log if you enable debug logging (see the Setup, Logging tab in OctoPrint). Ender3V2TempFix.zip (915 Bytes)
Feel free to ignore β¦
aztrip
September 2, 2020, 12:19am
3
Thanks, I'll try that tonight.
