Printer (Ender 3v2) disconnects at random times and seemingly no further detailed error messages in log (serilog nor octoprint)
I've tried various things. Multiple prints with different usb cables (I've added the black tape to the cable to block the power point) and using Octolapse's test mode (it fails in test mode as well) . Switched to safe mode and removed all other usb peripherals (webcam and a usb lamp) and the problem still happens.
So far I think through sheer luck I've been able to complete 1 print (a calibration cube and with peripherals attached and using Octolapse)
Octoprint Log Safemode
 2021-08-29 02:14:56,703 - octoprint.access.users - INFO - Logged in user: tnsai
 2021-08-29 02:14:56,862 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.8.0.2
 2021-08-29 02:14:57,330 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.8.0.2
 2021-08-29 02:14:57,398 - octoprint.server.util.flask - INFO - Passively logging in user tnsai from ::ffff:10.8.0.2
 2021-08-29 02:14:57,398 - octoprint.access.users - INFO - Logged in user: tnsai
 2021-08-29 02:14:57,962 - octoprint.server.util.sockjs - INFO - User tnsai logged in on the socket from client ::ffff:10.8.0.2
 2021-08-29 02:18:01,300 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.8.0.2
 2021-08-29 02:19:54,619 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.8.0.2
 2021-08-29 02:19:54,698 - octoprint.server.util.flask - INFO - Passively logging in user tnsai from ::ffff:10.8.0.2
 2021-08-29 02:19:54,699 - octoprint.access.users - INFO - Logged in user: tnsai
 2021-08-29 02:19:54,786 - octoprint.server.util.sockjs - INFO - User tnsai logged in on the socket from client ::ffff:10.8.0.2
 2021-08-29 02:20:08,275 - octoprint.server.heartbeat - INFO - Server heartbeat <3
 2021-08-29 02:23:34,559 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.8.0.2
 2021-08-29 02:27:32,783 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.8.0.2
 2021-08-29 02:27:32,864 - octoprint.server.util.flask - INFO - Passively logging in user tnsai from ::ffff:10.8.0.2
 2021-08-29 02:27:32,864 - octoprint.access.users - INFO - Logged in user: tnsai
 2021-08-29 02:27:32,949 - octoprint.server.util.sockjs - INFO - User tnsai logged in on the socket from client ::ffff:10.8.0.2
 2021-08-29 02:29:16,274 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.8.0.2
 2021-08-29 02:29:41,450 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.8.0.2
 2021-08-29 02:29:41,539 - octoprint.server.util.flask - INFO - Passively logging in user tnsai from ::ffff:10.8.0.2
 2021-08-29 02:29:41,540 - octoprint.access.users - INFO - Logged in user: tnsai
 2021-08-29 02:29:41,698 - octoprint.server.util.sockjs - INFO - User tnsai logged in on the socket from client ::ffff:10.8.0.2
 2021-08-29 02:30:37,299 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.8.0.2
 2021-08-29 02:35:08,275 - octoprint.server.heartbeat - INFO - Server heartbeat <3
 2021-08-29 02:48:41,373 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
   File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 3860, in _readline
     ret = self._serial.readline()
   File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/util/comm.py", line 6488, in readline
     c = self.read(1)
   File "/home/pi/oprint/lib/python3.7/site-packages/serial/serialposix.py", line 596, in read
     'device reports readiness to read but returned no data '
 serial.serialutil.SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
 2021-08-29 02:48:41,417 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
Serilog Safemode
serilog_safemode - Pastebin.com   (only the last few lines as it's large)
 2021-08-29 02:48:41,417 - Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3860
 2021-08-29 02:48:41,417 - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
 2021-08-29 02:48:41,436 - Changing monitoring state from "Printing" to "Offline after error"
 2021-08-29 02:48:41,443 - Connection closed, closing down monitor
Changed a couple of usb cables (sadly none have ferrite beads, ordered a few incoming), went into safe mode, removed all peripherals from Pi, added the black tape to block the power point on usb cable.
Yes
octoprint-systeminfo-20210829033754.zip (3.6 MB) (the serial and octoprint log in this zip is from after the issue occurred and i rebooted my pi back to normal mode)
These are the logs from when issue occurred :
serial_safe-mode_trimmed.log (1.5 KB)
octoprint_safe.log (49.7 KB)
OctoPrint version : 1.6.1
Printer : Ender 3 v2
Firmware: Jyers/Marlin 1.3.5 (also same issues on 1.3.4)
Printer has BLTouch installed.
Webcam: Logitech c920
RaspberryPi : Model 4B (powered via Official Pi power adapter)
Also: are there any recommended brands of powered usb hubs to get?
