I have successfully managed to install all of the first packages on my raspberry pi with the latest Raspbian update. But once I try to run the serve command the shell returns the following :
2019-03-07 20:30:30,355 - octoprint.startup - INFO - ******************************************************************************
2019-03-07 20:30:30,361 - octoprint.startup - INFO - Starting OctoPrint 0+unknown
2019-03-07 20:30:30,365 - octoprint.startup - INFO - ******************************************************************************
2019-03-07 20:30:30,648 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/Octoprint/venv/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-03-07 20:30:35,503 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2019-03-07 20:30:35,517 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-03-07 20:30:35,641 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-03-07 20:30:35,686 - octoprint.cli.server - ERROR - Uncaught exception
File "./venv/bin/octoprint", line 11, in <module>
load_entry_point('OctoPrint==0+unknown', 'console_scripts', 'octoprint')()
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/__init__.py", line 602, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/click-6.2-py2.7.egg/click/core.py", line 716, in __call__
return self.main(*args, **kwargs)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/click-6.2-py2.7.egg/click/core.py", line 696, in main
rv = self.invoke(ctx)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/click-6.2-py2.7.egg/click/core.py", line 1037, in invoke
return Command.invoke(self, ctx)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/click-6.2-py2.7.egg/click/core.py", line 889, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/click-6.2-py2.7.egg/click/core.py", line 534, in invoke
return callback(*args, **kwargs)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/click-6.2-py2.7.egg/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/cli/__init__.py", line 175, in octo
ctx.invoke(serve_command, **kwargs)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/cli/server.py", line 187, in serve_command
ignore_blacklist)
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/cli/server.py", line 108, in run_server
octoprint_server.run()
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/server/__init__.py", line 258, in run
self._start_intermediary_server()
File "/home/pi/Octoprint/venv/local/lib/python2.7/site-packages/OctoPrint-0+unknown-py2.7.egg/octoprint/server/__init__.py", line 1645, in _start_intermediary_server
self._intermediary_server.server_bind()
File "/usr/lib/python2.7/BaseHTTPServer.py", line 108, in server_bind
SocketServer.TCPServer.server_bind(self)
File "/usr/lib/python2.7/SocketServer.py", line 431, in server_bind
self.socket.bind(self.server_address)
File "/usr/lib/python2.7/socket.py", line 228, in meth
return getattr(self._sock,name)(*args)
error: [Errno 98] Address already in use
Exception in thread Thread-4 (most likely raised during interpreter shutdown):
I tried to run some commands to see why the 5000 port might be used and make sure octoprint is running.
(stable) pi@shedpi:~/Octoprint $ netstat -a | grep 5000
tcp 0 0 0.0.0.0:5000 0.0.0.0:* LISTEN
tcp 0 0 localhost:59696 localhost:5000 ESTABLISHED
tcp 0 0 localhost:5000 localhost:59696 ESTABLISHED
tcp6 0 0 [::]:5000 [::]:* LISTEN
(stable) pi@shedpi:~/Octoprint $ ps -ax|grep octoprint
4508 pts/0 S+ 0:00 grep --color=auto octoprint
I am using a Raspberry Pi 3b+
Thank you
