Error: Heating failed, system stopped!
Hello @subashchandraboseanu!
You may check your power supply:
2020-11-12 17:45:51,355 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power.
!!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi.
And there is this:
2020-11-12 17:55:33,495 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!
| Last lines in terminal:
| Recv:  T:28.64 /0.00 B:28.22 /40.00 @:0 B@:127 W:?
| Recv:  T:28.61 /0.00 B:28.28 /40.00 @:0 B@:127
| Recv:  T:28.55 /0.00 B:28.28 /40.00 @:0 B@:127 W:?
| Recv:  T:28.49 /0.00 B:28.12 /40.00 @:0 B@:127
| Recv:  T:28.72 /0.00 B:28.37 /40.00 @:0 B@:127 W:?
| Recv:  T:28.64 /0.00 B:28.25 /40.00 @:0 B@:127 W:?
| Recv:  T:28.52 /0.00 B:28.25 /40.00 @:0 B@:127
| Recv:  T:28.44 /0.00 B:28.25 /40.00 @:0 B@:127 W:?
| Recv:  T:28.75 /0.00 B:28.31 /40.00 @:0 B@:127 W:?
| Recv:  T:28.52 /0.00 B:28.16 /40.00 @:0 B@:127
| Recv:  T:28.66 /0.00 B:28.31 /40.00 @:0 B@:127 W:?
| Recv:  T:28.72 /0.00 B:28.25 /40.00 @:0 B@:127 W:?
| Recv:  T:28.58 /0.00 B:28.25 /40.00 @:0 B@:127
| Recv:  T:28.47 /0.00 B:28.16 /40.00 @:0 B@:127 W:?
| Recv:  T:28.52 /0.00 B:28.31 /40.00 @:0 B@:127 W:?
| Recv:  T:28.61 /0.00 B:28.19 /40.00 @:0 B@:127
| Recv:  T:28.49 /0.00 B:28.19 /40.00 @:0 B@:127 W:?
| Recv: Error:Heating failed, system stopped! Heater_ID: bed
| Recv: Error:Printer halted. kill() called!
You have a thermal runaway issue. You set the bed to 40Β°C, but it does not heat up.
Check the cables of the bed.
Check if the bed thermistor is detached from the bed.
Check if the printer is powered on. -> The display may be lit, but than can be by an issue of the board the the processor and display is powered by the Pi.
it is working for cura
Maybe, but that log does not lie:
The bed temp is set to 40Β°C but it stays at 28.xx and does not heat up. This is a hardware issue.
it was working fine for 3 prints
I believe you - but the firmware is reporting that error.
When you heat up the bed, does it get warm (Holding the hand above the bed)?
And before heating, can you home the printer?
Are you sure the heat bed connection is ok.
Is the printer really switched on: The printer controller may can work by powering from the USB port, but not the rest. You can check by pulling the USB from the printer.
I have seen these as well and creating a lot of headaches.
When I set the Temperature interval (autoreport) to 0, shutdown the pi and the printer, brought the printer online and then the pi it started to behave without having to removing the SD card. If the problem returns, I will remove the SD card. Thank you!.
The temperature of nozzle cannot reach above 260 degree celsius! The system get shut down
2020-12-25 17:54:13,086 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-25 17:54:13,114 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-12-25 17:54:13,115 - octoprint.server - INFO - OctoPrint 1.5.2
2020-12-25 17:54:13,117 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
|  Action Command Notification Support (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_notification
|  Action Command Prompt Support (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/backup
|  Bed Leveling Wizard (0.2.4) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_bedlevelingwizard
|  Core Wizard (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/corewizard
|  Discovery (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/discovery
|  Enclosure Plugin (4.13.1) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_enclosure
|  Error Tracking (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/errortracking
|  File Check (2020.8.7) (bundled) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_file_check
|  Firmware Check (2020.9.23) (bundled) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_firmware_check
|  Firmware Updater (1.7.6) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_firmwareupdater
| !GCode Viewer (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/gcodeviewer
|  Logging (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging
|  Pi Support Plugin (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pi_support
|  Plugin Manager (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
|  Software Update (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
|  Themeify (1.2.2) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_themeify
|  TouchUI (0.3.17) = /home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_touchui
|  Virtual Printer (bundled) = /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2020-12-25 17:54:13,137 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
|  hardware:
|      cores: 4
|      freq: 1400.0
|      ram: 917012480
|  os:
|      bits: 32
|      platform: linux2
|  plugins:
|      pi_support:
|          model: Raspberry Pi 3 Model B Plus Rev 1.3
|          throttle_state: '0x0'
|  python:
|      pip: 19.2.2
|      version: 2.7.16
|      virtualenv: /home/pi/OctoPrint/venv
2020-12-25 17:54:13,138 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-12-25 17:54:14,208 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.88s
2020-12-25 17:54:15,294 - octoprint.util.pip - INFO - Using "/home/pi/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2020-12-25 17:54:15,295 - octoprint.util.pip - INFO - pip installs to /home/pi/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-25 17:54:15,296 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-25 17:54:15,445 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 7.6GB. That is considered sufficient for updating.
2020-12-25 17:54:15,459 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2020-12-25 17:54:15,569 - octoprint.plugins.action_command_notification - INFO - Got a notification: 3D Printer Ready.
2020-12-25 17:54:15,604 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-12-25 17:54:15,617 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-25 17:54:15,652 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2020-12-25 17:54:15,653 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2020-12-25 17:54:15,715 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.x (GitHub)"
2020-12-25 17:54:15,733 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-12-25 17:54:15,895 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-12-25 17:54:16,215 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.67s
2020-12-25 17:54:19,710 - octoprint.util.pip - INFO - Using "/home/pi/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2020-12-25 17:54:19,722 - octoprint.util.pip - INFO - pip installs to /home/pi/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-25 17:54:19,724 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-25 17:54:19,790 - octoprint.server.util.sockjs - INFO - New connection from client: 127.0.0.1
2020-12-25 17:54:20,402 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-12-25 17:54:20,408 - octoprint.plugins.enclosure - INFO - Setting GPIO mode to BCM
2020-12-25 17:54:20,411 - octoprint.plugins.enclosure - INFO - Setting GPIO pin 0 as OUTPUT with initial value: 1
2020-12-25 17:54:20,412 - octoprint.plugins.enclosure - INFO - Adding GPIO event detect on pin 0 with edge: 33
2020-12-25 17:54:20,434 - octoprint.plugins.enclosure - INFO - Adding GPIO event detect on pin 0 with edge: 33
2020-12-25 17:54:20,462 - octoprint.plugins.themeify - INFO - Themeify initialized.
2020-12-25 17:54:20,886 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://bohr.local/'}
2020-12-25 17:54:31,983 - octoprint.server.preemptive_cache - INFO - ... done in 11.10s
2020-12-25 17:59:48,674 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 17:59:48,680 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 17:59:49,806 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 17:59:49,809 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 17:59:52,924 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.103
2020-12-25 17:59:53,136 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 17:59:53,137 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 17:59:55,967 - octoprint.timelapse - INFO - Deleted old unrendered timelapse AXIAL_meter_1_11_2020_vertical_20201218161639
2020-12-25 17:59:57,003 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.72s
2020-12-25 17:59:57,892 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.6s
2020-12-25 17:59:58,633 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.58s
2020-12-25 18:00:00,547 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-12-25 18:00:02,829 - octoprint.server.util.sockjs - INFO - User tejeshw logged in on the socket from client ::ffff:192.168.0.103
2020-12-25 18:09:13,089 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-25 18:17:11,667 - octoprint.startup - INFO - ******************************************************************************
2020-12-25 18:17:11,669 - octoprint.startup - INFO - Starting OctoPrint 1.5.2
2020-12-25 18:17:11,670 - octoprint.startup - INFO - ******************************************************************************
2020-12-25 18:17:18,769 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2020-12-25 18:17:18,772 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2020-12-25 18:17:18,775 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 8.8.8.8:53 is working
2020-12-25 18:17:18,777 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2020-12-25 18:17:19,637 - octoprint.startup - INFO - Blacklist processing done, adding 12 blacklisted plugin versions: roomtemp (any), GcodeEditor (0.1.1), GcodeEditor (0.2.0), GcodeEditor (0.2.1), GcodeEditor (0.2.2), GcodeEditor (0.2.3), GcodeEditor (0.2.4), GcodeEditor (0.2.5), GcodeEditor (0.2.6), GcodeEditor (0.2.8), gcodeleveling (0.1.0), gcodeleveling (0.1.1)
2020-12-25 18:17:19,856 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-12-25 18:17:20,895 - octoprint.plugin.core - INFO - Plugin GCode Viewer is disabled.
2020-12-25 18:17:22,355 - octoprint.plugin.core - ERROR - Error loading plugin polarcloud
  File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 1298, in _import_plugin
    module = _load_module(module_name, spec)
  File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 69, in _load_module
    return imp.load_module(name, f, filename, details)
  File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint_polarcloud/__init__.py", line 47, in <module>
    from flask.ext.babel import gettext, _
ImportError: No module named ext.babel
2020-12-25 18:17:22,835 - octoprint.plugin.core - INFO - Found 22 plugin(s) providing 21 mixin implementations, 42 hook handlers
2020-12-25 18:17:23,351 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-12-25 18:17:23,401 - octoprint.server - INFO - Intermediary server started
2020-12-25 18:17:23,440 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-12-25 18:17:23,991 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-12-25 18:17:23,995 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: u"Need(method='role', value=u'plugin_action_command_notification_show')")
2020-12-25 18:17:23,996 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: u"Need(method='role', value=u'plugin_action_command_notification_clear')")
2020-12-25 18:17:23,998 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-12-25 18:17:23,999 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-12-25 18:17:24,001 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-12-25 18:17:24,003 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-12-25 18:17:24,006 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-12-25 18:17:24,007 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_firmware_check_display')")
2020-12-25 18:17:24,010 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-12-25 18:17:24,011 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-12-25 18:17:24,013 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-25 18:17:24,014 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-12-25 18:17:24,015 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-12-25 18:17:24,017 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-12-25 18:17:24,020 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: u"Need(method='role', value=u'plugin_softwareupdate_configure')")
2020-12-25 18:17:24,339 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-12-25 18:17:27,269 - octoprint.util.pip - INFO - Using "/home/pi/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2020-12-25 18:17:29,489 - octoprint.util.pip - INFO - Version of pip is 19.2.2
2020-12-25 18:17:29,490 - octoprint.util.pip - INFO - pip installs to /home/pi/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-25 18:17:29,491 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-25 18:17:29,515 - octoprint.plugin.core - INFO - Initialized 21 plugin implementation(s)
2020-12-25 18:17:29,544 - octoprint.plugin.core - INFO - 22 plugin(s) registered with the system:
2020-12-25 18:17:29,581 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
|  hardware:
|      cores: 4
|      freq: 1400.0
|      ram: 917012480
|  os:
|      bits: 32
|      platform: linux2
|  plugins:
|      pi_support:
|  python:
|      pip: 19.2.2
|      version: 2.7.16
2020-12-25 18:17:29,596 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-12-25 18:17:29,617 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-12-25 18:17:31,229 - octoprint.server - INFO - Shutting down intermediary server...
2020-12-25 18:17:31,604 - octoprint.server - INFO - Intermediary server shut down
2020-12-25 18:17:31,607 - octoprint.events - INFO - Processing startup event, this is our first event
2020-12-25 18:17:31,608 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2020-12-25 18:17:31,615 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-12-25 18:17:31,616 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-12-25 18:17:31,644 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2020-12-25 18:17:31,690 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-12-25 18:17:31,804 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-12-25 18:17:33,947 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-12-25 18:17:33,989 - octoprint.server - INFO - Trying to connect to configured serial port /dev/ttyUSB0
2020-12-25 18:17:34,062 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial connection"
2020-12-25 18:17:34,066 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 250000
2020-12-25 18:17:34,076 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-12-25 18:17:34,078 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-12-25 18:17:34,101 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial connection" to "Connecting"
2020-12-25 18:17:34,110 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-25 18:17:34,907 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Bohr"._http._tcp.local.' for _http._tcp.local.
2020-12-25 18:17:35,051 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-25 18:33:56,479 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-12-25 18:33:56,975 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Bohr"._octoprint._tcp.local.' for _octoprint._tcp.local.
2020-12-25 18:33:56,991 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Bohr" for SSDP
2020-12-25 18:33:57,056 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-12-25 18:33:57,254 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-12-25 18:33:59,714 - octoprint.util.pip - INFO - Using "/home/pi/OctoPrint/venv/bin/python2 -m pip" as command to invoke pip
2020-12-25 18:33:59,744 - octoprint.util.pip - INFO - pip installs to /home/pi/OctoPrint/venv/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-12-25 18:33:59,796 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-12-25 18:33:59,814 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-12-25 18:33:59,830 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 7.6GB. That is considered sufficient for updating.
2020-12-25 18:33:59,896 - octoprint.plugins.action_command_notification - INFO - Got a notification: 3D Printer Ready.
2020-12-25 18:33:59,912 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-25 18:33:59,918 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2020-12-25 18:33:59,932 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2020-12-25 18:33:59,935 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2020-12-25 18:33:59,997 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-12-25 18:34:00,037 - octoprint.plugins.enclosure - INFO - Setting GPIO mode to BCM
2020-12-25 18:34:00,040 - octoprint.plugins.enclosure - INFO - Setting GPIO pin 0 as OUTPUT with initial value: 1
2020-12-25 18:34:00,041 - octoprint.plugins.enclosure - INFO - Adding GPIO event detect on pin 0 with edge: 33
2020-12-25 18:34:00,064 - octoprint.plugins.enclosure - INFO - Adding GPIO event detect on pin 0 with edge: 33
2020-12-25 18:34:00,072 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.0.x (GitHub)"
2020-12-25 18:34:00,098 - octoprint.plugins.themeify - INFO - Themeify initialized.
2020-12-25 18:34:00,127 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2020-12-25 18:34:00,702 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://bohr.local/'}
2020-12-25 18:34:04,323 - octoprint.server.util.sockjs - INFO - New connection from client: 127.0.0.1
2020-12-25 18:34:13,817 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.103
2020-12-25 18:34:13,910 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 18:34:13,925 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 18:34:15,850 - octoprint.server.util.sockjs - INFO - User tejeshw logged in on the socket from client ::ffff:192.168.0.103
2020-12-25 18:34:16,061 - octoprint.server.preemptive_cache - INFO - ... done in 15.36s
2020-12-25 18:34:44,933 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 18:34:44,936 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 18:34:46,249 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 18:34:46,250 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 18:34:47,778 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.0.103
2020-12-25 18:34:47,850 - octoprint.server.util.flask - INFO - Passively logging in user tejeshw from ::ffff:192.168.0.103
2020-12-25 18:34:47,851 - octoprint.access.users - INFO - Logged in user: tejeshw
2020-12-25 18:34:51,139 - octoprint.server.util.sockjs - INFO - User tejeshw logged in on the socket from client ::ffff:192.168.0.103
2020-12-25 18:34:59,722 - octoprint.plugins.enclosure - INFO - Setting auto startup for output 1 to : False
2020-12-25 18:37:31,007 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2020-12-25 18:46:36,150 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!
| Recv:  T:228.94 /260.00 B:27.41 /0.00 T0:228.94 /260.00 T1:-15.00 /0.00 @:127 B@:0 @0:127 @1:0
| Recv:  T:232.31 /260.00 B:27.67 /0.00 T0:232.31 /260.00 T1:-15.00 /0.00 @:127 B@:0 @0:127 @1:0
| Recv:  T:235.00 /260.00 B:27.02 /0.00 T0:235.00 /260.00 T1:-15.00 /0.00 @:127 B@:0 @0:127 @1:0
| Recv:  T:238.75 /260.00 B:27.47 /0.00 T0:238.75 /260.00 T1:-15.00 /0.00 @:127 B@:0 @0:127 @1:0
| Recv:  T:244.45 /260.00 B:27.76 /0.00 T0:244.45 /260.00 T1:-15.00 /0.00 @:127 B@:0 @0:127 @1:0
| Recv:  T:247.50 /260.00 B:27.84 /0.00 T0:247.50 /260.00 T1:-15.00 /0.00 @:127 B@:0 @0:127 @1:0
| Recv:  T:250.70 /260.00 B:27.22 /0.00 T0:250.70 /260.00 T1:-15.00 /0.00 @:58 B@:0 @0:58 @1:0
| Recv:  T:250.70 /260.00 B:27.24 /0.00 T0:250.70 /260.00 T1:-15.00 /0.00 @:69 B@:0 @0:69 @1:0
| Recv:  T:256.56 /260.00 B:26.76 /0.00 T0:256.56 /260.00 T1:-15.00 /0.00 @:0 B@:0 @0:0 @1:0
| Recv:  T:260.10 /260.00 B:27.76 /0.00 T0:260.10 /260.00 T1:-15.00 /0.00 @:0 B@:0 @0:0 @1:0
| Recv:  T:260.73 /260.00 B:27.22 /0.00 T0:260.73 /260.00 T1:-14.53 /0.00 @:0 B@:0 @0:0 @1:0
| Recv:  T:264.06 /260.00 B:27.36 /0.00 T0:264.06 /260.00 T1:-15.00 /0.00 @:0 B@:0 @0:0 @1:0
| Recv:  T:262.81 /260.00 B:27.53 /0.00 T0:262.81 /260.00 T1:-15.00 /0.00 @:0 B@:0 @0:0 @1:0
| Recv:  T:262.29 /260.00 B:27.90 /0.00 T0:262.29 /260.00 T1:-14.77 /0.00 @:0 B@:0 @0:0 @1:0
| Recv:  T:258.54 /260.00 B:27.70 /0.00 T0:258.54 /260.00 T1:-15.00 /0.00 @:40 B@:0 @0:40 @1:0
| Recv:  T:256.98 /260.00 B:27.87 /0.00 T0:256.98 /260.00 T1:-15.00 /0.00 @:58 B@:0 @0:58 @1:0
| Recv:  T:253.98 /260.00 B:27.70 /0.00 T0:253.98 /260.00 T1:-15.00 /0.00 @:95 B@:0 @0:95 @1:0
| Recv:  T:252.11 /260.00 B:27.30 /0.00 T0:252.11 /260.00 T1:-15.00 /0.00 @:108 B@:0 @0:108 @1:0
| Recv: Error:Heating failed, system stopped! Heater_ID: 0
2020-12-25 18:46:36,156 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!"
2020-12-25 18:46:36,184 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2020-12-25 18:46:36,232 - octoprint.util.comm - INFO - Changing monitoring state from "Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!" to "Offline (Error: Heating failed, system stopped! Heater_ID: 0 - Printer halted. kill() called!)"
2020-12-25 18:46:36,264 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
The thermistor of T1 seems to be not connected or shorted.
If you look at that log, you can see the temperature start to fall (it hits 264, then starts going down) and this is likely thermal runaway issue, your heater doesn't seem powerful enough to go above that.
@Poleman make my day!
fixed my issue also ... after long time!
This also solved my Octopi issues on an Ender 5 plus. It feels like madness that the solution to fixing the bed temp issue involves jamming electrical tape in a USB port and removing the SD card, both of which feel completely unrelated, but thanks!! You saved me many hours of tinkering!!
I'm also using Ender 5 plus, and I can confirm Poleman's experience. Removing the SD card eliminated the Heating Failed error for me.
WOOOOWWWWW THIS IS CRAZY!! It worked for me too! Ugh, wasted 2h looking for this answer. Thank you @Poleman !!!
I just experienced similar symptoms on an Ender 5 Plus.
It would heat the bed fine via LCD, but if octoprint was connected (running on a Raspberry Pi 4) the bed would no longer heat up.
A Multimeter connected to the heater plug was used to see that correct power was being applied to the bed heater at the correct time.
Changing the temperature interval (autoreport) to 0 did not seem to rectify the issue.
Removal of the SD card did.
I just formatted the SD card and re-inserted it into the printer, and now octoprint is able to heat up the bed, and I can save machine settings to the SD card.
I have 2 identical setups (Ender 5 Plus's controlled via Octoprint on Raspberry Pi 4's) and only one has exhibited the issue- the other has no issues with the SD card installed.
I am curious if the creality firmware is somehow corrupting the machine settings file on the Micro SD card and in turn causing errors in operation.
I also had this issue. I have a Lulzbot Taz 5. I tried changing the temperature interval (autoreport) to 0 , disabling recently installed plugins, removing the SD card, and I re-sliced the file and re-uploded the gcode. but same thing each time. It would print the first 5 layers or so and then I would get the heating failed error.
I had recently updated the firmware because I have to do that when I switch between the felxystruder head and the single extruder head. And I noticed that the baud rate changed from what I was used to. the new firmware was marlin 1.1.
so I have an earlier version of the lulzbot firmware that I just uploaded, marlin 1.0.0.1 and I'll update my results shortly.
gonna doublecheck my gcode and also try a different slicer if the firmware change doesn't do it
Which heater gives you the error? the hotend heater?
And wow marlin 1.0.0.1 is ancient :smiley:
