It connected once after I preheated the bed then connected the octoprint via usb cable unfortunately I had to cancel the print and when I tried again it threw another error at me.
2020-06-05 00:18:44,902 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-06-05 00:18:44,920 - Serial port list: [u'/dev/ttyUSB0']
2020-06-05 00:18:44,923 - Connecting to: /dev/ttyUSB0
2020-06-05 00:18:44,948 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-06-05 00:18:44,954 - Connected to: Serial<id=0xb0d5ca10, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-06-05 00:18:44,956 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-06-05 00:18:44,971 - Send: N0 M110 N0*125
2020-06-05 00:18:44,980 - Send: N0 M110 N0*125
2020-06-05 00:18:45,911 - Recv: start
2020-06-05 00:18:45,960 - Recv: echo: External Reset
2020-06-05 00:18:45,962 - Recv: Marlin Ver 1.70.1 BL
2020-06-05 00:18:45,963 - Send: N0 M110 N0*125
2020-06-05 00:18:45,964 - Recv:
2020-06-05 00:18:45,981 - Recv: echo: Last Updated: 2019-09-04 | Author: Ender-5 Plus
2020-06-05 00:18:46,000 - Recv: echo:Compiled: Sep 4 2019
2020-06-05 00:18:46,001 - Recv: echo: Free Memory: 1460 PlannerBufferBytes: 1232
2020-06-05 00:18:46,004 - Recv: echo:V41 stored settings retrieved (526 bytes; crc 8033)
2020-06-05 00:18:46,006 - Recv: echo: G21 ; Units in mm
2020-06-05 00:18:46,007 - Recv: echo: M149 C ; Units in Celsius
2020-06-05 00:18:46,016 - Recv:
2020-06-05 00:18:46,085 - Recv: echo:Filament settings: Disabled
2020-06-05 00:18:46,088 - Recv: echo: M200 D1.75
2020-06-05 00:18:46,090 - Recv: echo: M200 D0
2020-06-05 00:18:46,136 - Recv: echo:Steps per unit:
2020-06-05 00:18:46,139 - Recv: echo: M92 X80.00 Y80.00 Z800.00 E93.00
2020-06-05 00:18:46,140 - Recv: echo:Maximum feedrates (units/s):
2020-06-05 00:18:46,142 - Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00
2020-06-05 00:18:46,144 - Recv: echo:Maximum Acceleration (units/s2):
2020-06-05 00:18:46,145 - Recv: echo: M201 X500 Y500 Z100 E1000
2020-06-05 00:18:46,148 - Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
2020-06-05 00:18:46,159 - Recv: echo: M204 P500.00 R500.00 T1000.00
2020-06-05 00:18:46,161 - Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
2020-06-05 00:18:46,162 - Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.40 E5.00
2020-06-05 00:18:46,163 - Recv: echo:Home offset:
2020-06-05 00:18:46,165 - Recv: echo: M206 X0.00 Y0.00 Z0.00
2020-06-05 00:18:46,166 - Recv: echo:Auto Bed Leveling:
2020-06-05 00:18:46,168 - Recv: echo: M420 S0 Z0.00
2020-06-05 00:18:46,169 - Recv: echo:PID settings:
2020-06-05 00:18:46,170 - Recv: echo: M301 P14.72 I0.89 D61.22
2020-06-05 00:18:46,171 - Recv: echo:Z-Probe Offset (mm):
2020-06-05 00:18:46,174 - Recv: echo: M851 Z-1.60
2020-06-05 00:18:47,639 - Recv: echo:SD card ok
2020-06-05 00:18:47,641 - Recv: Init power off infomation.
2020-06-05 00:18:47,643 - Recv: size:
2020-06-05 00:18:47,644 - Recv: 585
2020-06-05 00:18:47,645 - Recv: init valid:
2020-06-05 00:18:47,646 - Recv: 0
2020-06-05 00:18:47,647 - Recv: 0
2020-06-05 00:18:47,648 - Recv: echo:V41 stored settings retrieved (526 bytes; crc 8033)
2020-06-05 00:18:47,650 - Recv: echo: G21 ; Units in mm
2020-06-05 00:18:47,651 - Recv: echo: M149 C ; Units in Celsius
2020-06-05 00:18:47,652 - Recv:
2020-06-05 00:18:47,653 - Recv: echo:Filament settings: Disabled
2020-06-05 00:18:47,654 - Recv: echo: M200 D1.75
2020-06-05 00:18:47,655 - Recv: echo: M200 D0
2020-06-05 00:18:47,656 - Recv: echo:Steps per unit:
2020-06-05 00:18:47,658 - Recv: echo: M92 X80.00 Y80.00 Z800.00 E93.00
2020-06-05 00:18:47,659 - Recv: echo:Maximum feedrates (units/s):
2020-06-05 00:18:47,660 - Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00
2020-06-05 00:18:47,661 - Recv: echo:Maximum Acceleration (units/s2):
2020-06-05 00:18:47,662 - Recv: echo: M201 X500 Y500 Z100 E1000
2020-06-05 00:18:47,691 - Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
2020-06-05 00:18:47,692 - Recv: echo: M204 P500.00 R500.00 T1000.00
2020-06-05 00:18:47,694 - Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
2020-06-05 00:18:47,695 - Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.40 E5.00
2020-06-05 00:18:47,696 - Recv: echo:Home offset:
2020-06-05 00:18:47,697 - Recv: echo: M206 X0.00 Y0.00 Z0.00
2020-06-05 00:18:47,698 - Recv: echo:Auto Bed Leveling:
2020-06-05 00:18:47,700 - Recv: echo: M420 S0 Z0.00
2020-06-05 00:18:47,701 - Recv: echo:PID settings:
2020-06-05 00:18:47,702 - Recv: echo: M301 P14.72 I0.89 D61.22
2020-06-05 00:18:47,703 - Recv: echo:Z-Probe Offset (mm):
2020-06-05 00:18:47,705 - Recv: echo: M851 Z-1.60
2020-06-05 00:18:47,706 - Recv: echo:enqueueing "M420 S1"
2020-06-05 00:18:47,707 - Recv: ***Initing card is OK***
2020-06-05 00:18:47,739 - Recv: echo:SD card ok
2020-06-05 00:18:47,986 - Recv: ===Initing RTS has finished===
2020-06-05 00:18:47,987 - Recv: echo:Bed Leveling On
2020-06-05 00:18:47,989 - Recv: echo:Fade Height Off
2020-06-05 00:18:48,018 - Recv: ok
2020-06-05 00:18:48,020 - Changing monitoring state from "Connecting" to "Operational"
2020-06-05 00:18:48,027 - Send: N0 M110 N0*125
2020-06-05 00:18:48,034 - Recv: ok
2020-06-05 00:18:48,036 - Send: N1 M115*39
2020-06-05 00:18:48,113 - Recv: FIRMWARE_NAME:Marlin Ver 1.70.1 BL (Creality3D) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-5 Plus EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-06-05 00:18:48,116 - Recv: Cap:EEPROM:1
2020-06-05 00:18:48,117 - Recv: Cap:AUTOREPORT_TEMP:1
2020-06-05 00:18:48,119 - Recv: Cap:PROGRESS:0
2020-06-05 00:18:48,120 - Recv: Cap:PRINT_JOB:1
2020-06-05 00:18:48,122 - Recv: Cap:AUTOLEVEL:1
2020-06-05 00:18:48,123 - Recv: Cap:Z_PROBE:1
2020-06-05 00:18:48,124 - Recv: Cap:LEVELING_DATA:1
2020-06-05 00:18:48,125 - Recv: Cap:SOFTWARE_POWER:0
2020-06-05 00:18:48,126 - Recv: Cap:TOGGLE_LIGHTS:0
2020-06-05 00:18:48,127 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2020-06-05 00:18:48,128 - Recv: Cap:EMERGENCY_PARSER:0
2020-06-05 00:18:48,129 - Recv: ok
2020-06-05 00:18:48,131 - Send: M20
2020-06-05 00:18:48,177 - Recv: Begin file list
2020-06-05 00:18:48,761 - Recv: TUZI~1.GCO 4712377
2020-06-05 00:18:48,977 - Recv: /TRASHE~1/501/SOAP_D~1.GCO 13452712
2020-06-05 00:18:49,042 - Recv: /TRASHE~1/501/BASE_V~1.GCO 2967705
2020-06-05 00:18:49,043 - Recv: /TRASHE~1/501/ENDER_~1.GCO 1476627
2020-06-05 00:18:49,044 - Recv: /TRASHE~1/501/3DBENC~1.GCO 6141906
2020-06-05 00:18:49,046 - Recv: /TRASHE~1/501/BENC~1.GCO 4664763
2020-06-05 00:18:49,046 - Recv: /TRASHE~1/501/BDTS3~1.GCO 3727967
2020-06-05 00:18:49,048 - Recv: /TRASHE~1/501/BDRWS3~1.GCO 7690168
2020-06-05 00:18:49,049 - Recv: /TRASHE~1/501/BDRIGH~1.GCO 9983667
2020-06-05 00:18:49,050 - Recv: /TRASHE~1/501/BDNFUS~1.GCO 1676537
2020-06-05 00:18:49,051 - Recv: /TRASHE~1/501/BDNFS3~1.GCO 674478
2020-06-05 00:18:49,053 - Recv: /TRASHE~1/501/BDLEFT~1.GCO 9245341
2020-06-05 00:18:49,054 - Recv: /TRASHE~1/501/BDHEAD~1.GCO 2105313
2020-06-05 00:18:49,071 - Recv: /TRASHE~1/501/BDHEAD~2.GCO 2114490
2020-06-05 00:18:49,072 - Recv: /TRASHE~1/501/BASE_V~2.GCO 3310292
2020-06-05 00:18:49,073 - Recv: /TRASHE~1/501/XYZCAL~1.GCO 561863
2020-06-05 00:18:49,079 - Recv: /TRASHE~1/501/BLUE_D~1.GCO 2105313
2020-06-05 00:18:49,080 - Recv: /TRASHE~1/501/CABLES~1.GCO 7211676
2020-06-05 00:18:49,082 - Recv: /TRASHE~1/501/CARTER~1.GCO 23696525
2020-06-05 00:18:49,083 - Recv: /TRASHE~1/501/CE5P_B~1.GCO 2597796
2020-06-05 00:18:49,083 - Recv: /TRASHE~1/501/CI~1.GCO 185114
2020-06-05 00:18:49,084 - Recv: /TRASHE~1/501/CLIPFO~1.GCO 185114
2020-06-05 00:18:49,085 - Recv: /TRASHE~1/501/CLIPFO~2.GCO 324445
2020-06-05 00:18:49,086 - Recv: /TRASHE~1/501/CUB~1.GCO 357817
2020-06-05 00:18:49,087 - Recv: /TRASHE~1/501/DRAG_B~1.GCO 7779314
2020-06-05 00:18:49,088 - Recv: /TRASHE~1/501/DRA~1.GCO 7779314
2020-06-05 00:18:49,089 - Recv: /TRASHE~1/501/DRAGON~1.GCO 9557884
2020-06-05 00:18:49,090 - Recv: /TRASHE~1/501/FANTAS~1.GCO 284160
2020-06-05 00:18:49,091 - Recv: /TRASHE~1/501/FILAME~1.GCO 15105434
2020-06-05 00:18:49,092 - Recv: /TRASHE~1/501/IPHON~1.GCO 3940243
2020-06-05 00:18:49,094 - Recv: /TRASHE~1/501/JAWS_V~1.GCO 4087414
2020-06-05 00:18:49,141 - Recv: /TRASHE~1/501/LATEST~1.GCO 284868
2020-06-05 00:18:49,142 - Recv: /TRASHE~1/501/NEWPAR~1.GCO 1476627
2020-06-05 00:18:49,144 - Recv: /TRASHE~1/501/PART~1.GCO 2265834
2020-06-05 00:18:49,145 - Recv: /TRASHE~1/501/PRINTH~1.GCO 1299635
2020-06-05 00:18:49,146 - Recv: /TRASHE~1/501/PRINTH~2.GCO 1299635
2020-06-05 00:18:49,146 - Recv: /TRASHE~1/501/PRUSAR~1.GCO 9749342
2020-06-05 00:18:49,147 - Recv: /TRASHE~1/501/RBENCH~1.GCO 4456691
2020-06-05 00:18:49,148 - Recv: /TRASHE~1/501/SOAP_D~2.GCO 13470570
2020-06-05 00:18:49,149 - Recv: /TRASHE~1/501/SOAP_D~3.GCO 7101427
2020-06-05 00:18:49,150 - Recv: /TRASHE~1/501/SPRING~1.GCO 3954906
2020-06-05 00:18:49,151 - Recv: /TRASHE~1/501/TEMPTO~1.GCO 874029
2020-06-05 00:18:49,152 - Recv: /TRASHE~1/501/TIMTEM~1.GCO 1567635
2020-06-05 00:18:49,153 - Recv: /TRASHE~1/501/TPCABL~1.GCO 1116616
2020-06-05 00:18:49,154 - Recv: /TRASHE~1/501/TTOWE~1.GCO 613685
2020-06-05 00:18:49,155 - Recv: RIGHTW~1.GCO 7911468
2020-06-05 00:18:49,181 - Recv: End file list
2020-06-05 00:18:49,183 - Recv: ok
2020-06-05 00:18:49,184 - Send: M155 S2
2020-06-05 00:18:49,413 - Recv: Error:Heating failed, system stopped! Heater_ID: bed
2020-06-05 00:18:49,426 - Recv: Error:Printer halted. kill() called!
2020-06-05 00:18:49,498 - Changing monitoring state from "Operational" to "Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!"
2020-06-05 00:18:49,510 - Send: M112
2020-06-05 00:18:49,521 - Send: N2 M112*35
2020-06-05 00:18:49,522 - Send: N3 M104 T0 S0*34
2020-06-05 00:18:49,524 - Send: N4 M140 S0*97
2020-06-05 00:18:49,533 - Changing monitoring state from "Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!" to "Offline (Error: Heating failed, system stopped! Heater_ID: bed - Printer halted. kill() called!)"
2020-06-05 00:18:49,542 - Connection closed, closing down monitor
