Error updating fresh install from 1.3.10 to 1.3.12
OctoPi is unable to update OctoPrint from 1.3.10 to 1.3.12
  • Toggling plugin blacklist processing on startup
  • Using a Samsung microSHDC 32GB card
  • Using a Kingston microSHDC 8GB card
  • Restarting OctoPrint in safe mode
  • Re-downloading octopi-stretch-lite-0.16.0 image and re-etching with balenaEtcher
What hardware are you using?
Raspberry Pi 3B (a22082 1.2 1GB Embest)
Steps to reproduce
  1. Download octopi-stretch-lite-0.16.0 from OctoPrint.org - Download & Setup OctoPrint
  2. Extract and etch image to micro SD card using balenaEtcher
  3. Startup Raspberry Pi
  4. Browse to UI using Chrome
  5. Attempt to update
  6. Observe error
Error
Exception:
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
status = self.run(options, args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
session=session, autobuilding=True
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 886, in build
assert have_directory_for_build
AssertionError
Logs
octoprint.log
2019-11-06 06:07:28,054 - octoprint.startup - INFO - ******************************************************************************
2019-11-06 06:07:28,057 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-11-06 06:07:28,057 - octoprint.startup - INFO - ******************************************************************************
2019-11-06 06:07:29,357 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-11-06 06:07:32,045 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-11-06 06:07:32,181 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-11-06 06:07:32,666 - octoprint.server - INFO - Intermediary server started
2019-11-06 06:07:32,668 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-11-06 06:07:33,266 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-11-06 06:07:33,268 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
2019-11-06 06:07:33,414 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-11-06 06:07:33,416 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-11-06 06:07:41,795 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-11-06 06:07:43,364 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-11-06 06:07:43,366 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-11-06 06:07:43,367 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-11-06 06:07:43,372 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-11-06 06:07:43,875 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
|  CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
|  Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
|  Force Login (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/forcelogin
|  Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
|  Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
|  Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
|  Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2019-11-06 06:07:44,291 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|    cores: 4
|    freq: 1200.0
|    ram: 918188032
|  os:
|    platform: linux2
|  plugins:
|    pi_support:
|      model: Raspberry Pi 3 Model B Rev 1.2
|      octopi_version: 0.16.0
|  python:
|    pip: 19.0.1
|    version: 2.7.13
|    virtualenv: /home/pi/oprint
2019-11-06 06:07:44,299 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-11-06 06:07:44,301 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-11-06 06:07:44,727 - octoprint.server - INFO - Shutting down intermediary server...
2019-11-06 06:07:45,023 - octoprint.server - INFO - Intermediary server shut down
2019-11-06 06:07:45,026 - octoprint.events - INFO - Processing startup event, this is our first event
2019-11-06 06:07:45,028 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-11-06 06:07:45,030 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-11-06 06:07:45,035 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-11-06 06:07:45,053 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-11-06 06:07:45,067 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-11-06 06:07:45,078 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-11-06 06:07:45,145 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-11-06 06:07:45,591 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020464909 (::ffff:192.168.1.23) 424.12ms
2019-11-06 06:07:46,374 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.77s
2019-11-06 06:07:46,648 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020466473 (::ffff:192.168.1.23) 9.74ms
2019-11-06 06:07:46,722 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2019-11-06 06:07:47,368 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-11-06 06:07:47,370 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-11-06 06:07:47,371 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-11-06 06:07:47,673 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020467529 (::ffff:192.168.1.23) 8.33ms
2019-11-06 06:07:47,781 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.1s
2019-11-06 06:07:48,602 - octoprint.server.views - INFO - Preemptive cache not active for path /, ui _default and data {'query_string': 'l10n=en', 'path': u'/', 'base_url': 'http://192.168.1.125/'}, signaling as cached
2019-11-06 06:07:48,782 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2019-11-06 06:07:49,377 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.78s
2019-11-06 06:07:50,198 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.74s
2019-11-06 06:07:50,331 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-11-06 06:07:51,061 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.74s
2019-11-06 06:07:53,861 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'query_string': 'l10n=en', 'path': u'/', '_count': 1, '_timestamp': 1573020473.86114, 'base_url': 'http://192.168.1.125/'}
2019-11-06 06:08:01,836 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-11-06 06:08:01,837 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-11-06 06:08:01,881 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2019-11-06 06:08:01,947 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://192.168.1.125/'}
2019-11-06 06:08:16,718 - octoprint.server.preemptive_cache - INFO - ... done in 14.77s
2019-11-06 06:08:16,735 - tornado.access - WARNING - 404 GET /intermediary.gif?_=1573020468551 (::ffff:192.168.1.23) 10.78ms
2019-11-06 06:08:18,507 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.23
2019-11-06 06:08:35,081 - octoprint.server.api - INFO - Actively logging in user octoprint from ::ffff:192.168.1.23
2019-11-06 06:08:37,739 - octoprint.server.util.sockjs - INFO - User octoprint logged in on the socket from client ::ffff:192.168.1.23
2019-11-06 06:09:23,762 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.3.12...
2019-11-06 06:11:00,316 - octoprint.plugins.softwareupdate - ERROR - Update of octoprint can not be performed, please also check plugin_softwareupdate_console.log for possible causes of this
  File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 969, in _perform_update
    update_result = updater.perform_update(target, populated_check, target_version, log_cb=self._log, online=online)
  File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/updaters/pip.py", line 116, in perform_update
    raise exceptions.UpdateError("Error while executing pip install", (stdout, stderr))
UpdateError
2019-11-06 06:09:23,773   /home/pi/oprint/bin/python2 -m pip install https://github.com/foosel/OctoPrint/archive/1.3.12.zip --no-cache-dir
2019-11-06 06:09:26,316 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
2019-11-06 06:09:26,318 > Collecting https://github.com/foosel/OctoPrint/archive/1.3.12.zip
2019-11-06 06:09:26,821 ! DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
2019-11-06 06:09:27,324 > Downloading https://github.com/foosel/OctoPrint/archive/1.3.12.zip (5.4MB)
2019-11-06 06:09:33,569 > Requirement already satisfied: flask<0.11,>=0.10.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.10.1)
2019-11-06 06:09:33,570 > Requirement already satisfied: Jinja2<2.9,>=2.8.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (2.8.1)
2019-11-06 06:09:33,571 > Requirement already satisfied: tornado==4.5.3 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (4.5.3)
2019-11-06 06:09:33,572 > Requirement already satisfied: Flask-Login<0.3,>=0.2.11 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.2.11)
2019-11-06 06:09:33,572 > Requirement already satisfied: regex!=2018.11.6 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (2019.1.24)
2019-11-06 06:09:33,573 > Collecting Flask-Principal<0.5,>=0.4 (from OctoPrint==1.3.12)
2019-11-06 06:09:35,575 > Downloading https://files.pythonhosted.org/packages/14/c7/2531aca6ab7baa3774fde2dfc9c9dd6d5a42576a1013a93701bfdc402fdd/Flask-Principal-0.4.0.tar.gz
2019-11-06 06:09:37,579 > Collecting Flask-Babel<0.13,>=0.12 (from OctoPrint==1.3.12)
2019-11-06 06:09:38,696 > Downloading https://files.pythonhosted.org/packages/82/b0/986b29938d4e8be7deb552ebfd1ef16c311276a59bcae10dec567a5b3d20/Flask-Babel-0.12.2.tar.gz (44kB)
2019-11-06 06:09:40,730 > Collecting Flask-Assets<0.13,>=0.12 (from OctoPrint==1.3.12)
2019-11-06 06:09:41,897 > Downloading https://files.pythonhosted.org/packages/86/ff/6000451570745d7a90847f6528d96d6b24c800eaaf9f26cf398accd8cee5/Flask-Assets-0.12.tar.gz
2019-11-06 06:09:43,900 > Collecting werkzeug<0.16,>=0.15.1 (from OctoPrint==1.3.12)
2019-11-06 06:09:45,946 > Downloading https://files.pythonhosted.org/packages/b7/61/c0a1adf9ad80db012ed7191af98fa05faa95fa09eceb71bb6fa8b66e6a43/Werkzeug-0.15.6-py2.py3-none-any.whl (328kB)
2019-11-06 06:09:46,825 > Collecting cachelib<0.2,>=0.1 (from OctoPrint==1.3.12)
2019-11-06 06:09:46,826 > Downloading https://files.pythonhosted.org/packages/e6/5b/39d1f9071e95123a4ae6d8bdeb53416d1af601f662641eac9b0d7c844dba/cachelib-0.1.tar.gz
2019-11-06 06:09:49,093 > Collecting PyYAML<6,>=5.1 (from OctoPrint==1.3.12)
2019-11-06 06:09:50,595 > Downloading https://files.pythonhosted.org/packages/e3/e8/b3212641ee2718d556df0f23f78de8303f068fe29cdaa7a91018849582fe/PyYAML-5.1.2.tar.gz (265kB)
2019-11-06 06:09:53,914 > Collecting markdown<3.1,>=3.0 (from OctoPrint==1.3.12)
2019-11-06 06:09:55,724 > Downloading https://files.pythonhosted.org/packages/7a/6b/5600647404ba15545ec37d2f7f58844d690baf2f81f3a60b862e48f29287/Markdown-3.0.1-py2.py3-none-any.whl (89kB)
2019-11-06 06:09:56,498 > Requirement already satisfied: pyserial<3.5,>=3.4 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (3.4)
2019-11-06 06:09:56,499 > Requirement already satisfied: netaddr<0.8,>=0.7.19 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.7.19)
2019-11-06 06:09:56,499 > Collecting watchdog<0.10,>=0.9.0 (from OctoPrint==1.3.12)
2019-11-06 06:09:56,500 > Downloading https://files.pythonhosted.org/packages/bb/e3/5a55d48a29300160779f0a0d2776d17c1b762a2039b36de528b093b87d5b/watchdog-0.9.0.tar.gz (85kB)
2019-11-06 06:09:58,263 > Requirement already satisfied: sarge==0.1.5post0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.1.5.post0)
2019-11-06 06:09:58,264 > Requirement already satisfied: netifaces<0.11,>=0.10.9 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (0.10.9)
2019-11-06 06:09:58,265 > Collecting pylru<1.3,>=1.2 (from OctoPrint==1.3.12)
2019-11-06 06:09:59,583 > Downloading https://files.pythonhosted.org/packages/9c/88/30972cd0518452563221c80bffc2a5832499d736648ef8fe492affae15c5/pylru-1.2.0.tar.gz
2019-11-06 06:10:03,588 > Collecting rsa<5,>=4.0 (from OctoPrint==1.3.12)
2019-11-06 06:10:05,875 > Downloading https://files.pythonhosted.org/packages/02/e5/38518af393f7c214357079ce67a317307936896e961e35450b70fad2a9cf/rsa-4.0-py2.py3-none-any.whl
2019-11-06 06:10:05,876 > Collecting pkginfo<1.6,>=1.5.0.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:05,876 > Downloading https://files.pythonhosted.org/packages/e6/d5/451b913307b478c49eb29084916639dc53a88489b993530fed0a66bab8b9/pkginfo-1.5.0.1-py2.py3-none-any.whl
2019-11-06 06:10:05,877 > Requirement already satisfied: requests<3,>=2.21.0 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (2.21.0)
2019-11-06 06:10:05,878 > Collecting semantic_version<2.7,>=2.6 (from OctoPrint==1.3.12)
2019-11-06 06:10:05,878 > Downloading https://files.pythonhosted.org/packages/72/83/f76958017f3094b072d8e3a72d25c3ed65f754cc607fdb6a7b33d84ab1d5/semantic_version-2.6.0.tar.gz
2019-11-06 06:10:07,881 > Collecting psutil<5.7,>=5.6.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:11,885 > Downloading https://files.pythonhosted.org/packages/47/ea/d3b6d6fd0b4a6c12984df652525f394e68c8678d2b05075219144eb3a1cf/psutil-5.6.4.tar.gz (447kB)
2019-11-06 06:10:11,886 > Installing build dependencies: started
2019-11-06 06:10:23,895 > Installing build dependencies: finished with status 'done'
2019-11-06 06:10:23,896 > Getting requirements to build wheel: started
2019-11-06 06:10:31,903 > Getting requirements to build wheel: finished with status 'done'
2019-11-06 06:10:31,904 > Preparing wheel metadata: started
2019-11-06 06:10:33,908 > Preparing wheel metadata: finished with status 'done'
2019-11-06 06:10:33,909 > Collecting Click<8,>=7 (from OctoPrint==1.3.12)
2019-11-06 06:10:35,322 > Downloading https://files.pythonhosted.org/packages/fa/37/45185cb5abbc30d7257104c434fe0b07e5a195a6847506c074527aa599ec/Click-7.0-py2.py3-none-any.whl (81kB)
2019-11-06 06:10:35,323 > Requirement already satisfied: awesome-slugify<1.7,>=1.6.5 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (1.6.5)
2019-11-06 06:10:35,324 > Requirement already satisfied: feedparser<5.3,>=5.2.1 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (5.2.1)
2019-11-06 06:10:35,324 > Collecting chainmap<1.1,>=1.0.3 (from OctoPrint==1.3.12)
2019-11-06 06:10:35,325 > Downloading https://files.pythonhosted.org/packages/c7/ab/268a15383b75ca3e58ce344bce165b79768e516f8e79c87cbdaba30c38e9/chainmap-1.0.3.tar.gz
2019-11-06 06:10:37,328 > Collecting future<0.18,>=0.17.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:38,645 > Downloading https://files.pythonhosted.org/packages/90/52/e20466b85000a181e1e144fd8305caf2cf475e2f9674e797b222f8105f5f/future-0.17.1.tar.gz (829kB)
2019-11-06 06:10:41,763 > Collecting scandir<1.11,>=1.10 (from OctoPrint==1.3.12)
2019-11-06 06:10:43,766 > Downloading https://files.pythonhosted.org/packages/df/f5/9c052db7bd54d0cbf1bc0bb6554362bba1012d03e5888950a4f5c5dadc4e/scandir-1.10.0.tar.gz
2019-11-06 06:10:45,770 > Collecting websocket-client<0.57,>=0.56 (from OctoPrint==1.3.12)
2019-11-06 06:10:47,101 > Downloading https://files.pythonhosted.org/packages/29/19/44753eab1fdb50770ac69605527e8859468f3c0fd7dc5a76dd9c4dbd7906/websocket_client-0.56.0-py2.py3-none-any.whl (200kB)
2019-11-06 06:10:47,102 > Collecting wrapt<1.12,>=1.11.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:48,104 > Downloading https://files.pythonhosted.org/packages/23/84/323c2415280bc4fc880ac5050dddfb3c8062c2552b34c2e512eb4aa68f79/wrapt-1.11.2.tar.gz
2019-11-06 06:10:50,108 > Collecting futures<3.3,>=3.2 (from OctoPrint==1.3.12)
2019-11-06 06:10:51,426 > Downloading https://files.pythonhosted.org/packages/2d/99/b2c4e9d5a30f6471e410a146232b4118e697fa3ffc06d6a65efde84debd0/futures-3.2.0-py2-none-any.whl
2019-11-06 06:10:51,427 > Collecting emoji<0.6,>=0.5.1 (from OctoPrint==1.3.12)
2019-11-06 06:10:51,428 > Downloading https://files.pythonhosted.org/packages/40/8d/521be7f0091fe0f2ae690cc044faf43e3445e0ff33c574eae752dd7e39fa/emoji-0.5.4.tar.gz (43kB)
2019-11-06 06:10:53,545 > Collecting monotonic<1.6,>=1.5 (from OctoPrint==1.3.12)
2019-11-06 06:10:54,925 > Downloading https://files.pythonhosted.org/packages/ac/aa/063eca6a416f397bd99552c534c6d11d57f58f2e94c14780f3bbf818c4cf/monotonic-1.5-py2.py3-none-any.whl
2019-11-06 06:10:54,926 > Requirement already satisfied: frozendict<1.3,>=1.2 in /home/pi/oprint/lib/python2.7/site-packages (from OctoPrint==1.3.12) (1.2)
2019-11-06 06:10:54,926 > Collecting sentry-sdk==0.7.7 (from OctoPrint==1.3.12)
2019-11-06 06:10:56,293 > Downloading https://files.pythonhosted.org/packages/cb/61/709cf211413ed28c0606fe135cd41b7d94ffdc49d874aeba37b6e0d20000/sentry_sdk-0.7.7-py2.py3-none-any.whl (60kB)
2019-11-06 06:10:56,602 > Collecting typing<4,>=3.6.6 (from OctoPrint==1.3.12)
2019-11-06 06:10:58,294 > Downloading https://files.pythonhosted.org/packages/22/30/64ca29543375759dc589ade14a6cd36382abf2bec17d67de8481bc9814d7/typing-3.7.4.1-py2-none-any.whl
2019-11-06 06:10:58,295 > Collecting filetype<2,>=1.0.5 (from OctoPrint==1.3.12)
2019-11-06 06:10:58,296 > Downloading https://files.pythonhosted.org/packages/1c/78/047cf0f371f8faafab05b5062f902d4bedd945d436544b30db692622ab84/filetype-1.0.5-py2.py3-none-any.whl
2019-11-06 06:10:58,297 > Requirement already satisfied: itsdangerous>=0.21 in /home/pi/oprint/lib/python2.7/site-packages (from flask<0.11,>=0.10.1->OctoPrint==1.3.12) (1.1.0)
2019-11-06 06:10:58,297 > Requirement already satisfied: MarkupSafe in /home/pi/oprint/lib/python2.7/site-packages (from Jinja2<2.9,>=2.8.1->OctoPrint==1.3.12) (1.1.0)
2019-11-06 06:10:58,298 > Requirement already satisfied: singledispatch in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint==1.3.12) (3.4.0.3)
2019-11-06 06:10:58,298 > Requirement already satisfied: certifi in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint==1.3.12) (2018.11.29)
2019-11-06 06:10:58,298 > Requirement already satisfied: backports-abc>=0.4 in /home/pi/oprint/lib/python2.7/site-packages (from tornado==4.5.3->OctoPrint==1.3.12) (0.5)
2019-11-06 06:10:58,299 > Requirement already satisfied: blinker in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Principal<0.5,>=0.4->OctoPrint==1.3.12) (1.4)
2019-11-06 06:10:58,299 > Requirement already satisfied: Babel>=2.3 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Babel<0.13,>=0.12->OctoPrint==1.3.12) (2.6.0)
2019-11-06 06:10:58,300 > Requirement already satisfied: webassets>=0.11.1 in /home/pi/oprint/lib/python2.7/site-packages (from Flask-Assets<0.13,>=0.12->OctoPrint==1.3.12) (0.12.1)
2019-11-06 06:10:58,300 > Requirement already satisfied: argh>=0.24.1 in /home/pi/oprint/lib/python2.7/site-packages (from watchdog<0.10,>=0.9.0->OctoPrint==1.3.12) (0.26.2)
2019-11-06 06:10:58,301 > Requirement already satisfied: pathtools>=0.1.1 in /home/pi/oprint/lib/python2.7/site-packages (from watchdog<0.10,>=0.9.0->OctoPrint==1.3.12) (0.1.2)
2019-11-06 06:10:58,301 > Requirement already satisfied: pyasn1>=0.1.3 in /home/pi/oprint/lib/python2.7/site-packages (from rsa<5,>=4.0->OctoPrint==1.3.12) (0.4.5)
2019-11-06 06:10:58,302 > Requirement already satisfied: urllib3<1.25,>=1.21.1 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.21.0->OctoPrint==1.3.12) (1.24.1)
2019-11-06 06:10:58,302 > Requirement already satisfied: idna<2.9,>=2.5 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.21.0->OctoPrint==1.3.12) (2.8)
2019-11-06 06:10:58,303 > Requirement already satisfied: chardet<3.1.0,>=3.0.2 in /home/pi/oprint/lib/python2.7/site-packages (from requests<3,>=2.21.0->OctoPrint==1.3.12) (3.0.4)
2019-11-06 06:10:58,303 > Requirement already satisfied: Unidecode<0.05,>=0.04.14 in /home/pi/oprint/lib/python2.7/site-packages (from awesome-slugify<1.7,>=1.6.5->OctoPrint==1.3.12) (0.4.21)
2019-11-06 06:10:58,304 > Requirement already satisfied: six in /home/pi/oprint/lib/python2.7/site-packages (from websocket-client<0.57,>=0.56->OctoPrint==1.3.12) (1.12.0)
2019-11-06 06:10:58,304 > Requirement already satisfied: pytz>=0a in /home/pi/oprint/lib/python2.7/site-packages (from Babel>=2.3->Flask-Babel<0.13,>=0.12->OctoPrint==1.3.12) (2018.9)
2019-11-06 06:10:58,806 ! Exception:
2019-11-06 06:10:58,807 ! Traceback (most recent call last):
2019-11-06 06:10:58,808 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/cli/base_command.py", line 176, in main
2019-11-06 06:10:58,809 ! status = self.run(options, args)
2019-11-06 06:10:58,809 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/commands/install.py", line 346, in run
2019-11-06 06:10:58,810 ! session=session, autobuilding=True
2019-11-06 06:10:58,810 ! File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_internal/wheel.py", line 886, in build
2019-11-06 06:10:58,811 ! assert have_directory_for_build
2019-11-06 06:10:58,811 ! AssertionError
2019-11-06 06:11:00,314 ! You are using pip version 19.0.1, however version 19.3.1 is available.
2019-11-06 06:11:00,314 ! You should consider upgrading via the 'pip install --upgrade pip' command.
2 posts were merged into an existing topic: Updating OctoPi / not a directory
