Error upgrading from 1.6.1 to 1.7.2
Getting error upgrading from 1.6.1 to 1.7.2 with error "ImportError: cannot import name NullHandler". This is NOT due to PrintTimeGenius (as current Octoprint install help documentation recommends) as I have uninstalled that plugin. I also tried installing in Safe mode, but got the same error. Here's the full error message:
ERROR: Command errored out with exit status 1:
command: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-Bs2JzX/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython
cwd: None
Complete output (24 lines):
File "/usr/lib/python2.7/runpy.py", line 174, in _run_module_as_main
"__main__", fname, loader, pkg_name)
File "/usr/lib/python2.7/runpy.py", line 72, in _run_code
exec code in run_globals
File "/home/pi/oprint/lib/python2.7/site-packages/pip/__main__.py", line 16, in <module>
from pip._internal.main import main as _main  # isort:skip # noqa
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/main.py", line 13, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/autocompletion.py", line 11, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/cli/cmdoptions.py", line 25, in <module>
from pip._internal.locations import USER_CACHE_DIR, get_src_prefix
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/locations.py", line 18, in <module>
from pip._internal.utils import appdirs
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/appdirs.py", line 16, in <module>
from pip._internal.utils.compat import WINDOWS, expanduser
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_internal/utils/compat.py", line 17, in <module>
from pip._vendor.urllib3.util import IS_PYOPENSSL
File "/home/pi/oprint/lib/python2.7/site-packages/pip/_vendor/urllib3/__init__.py", line 21, in <module>
from logging import NullHandler
Uninstalled PrintTimeGenius
Yes
OctoPrint version 1.6.1, OctoPi version 0.17, Prusa MK3S
You probably need to read the guide again - just uninstalling the plugin is not enough to fix the issue.
Thanks. Running that cleanup plugin did the trick. (Although I didn't see the log message it was supposed to generate). Somehow I missed the fact that I actually need to install special plugin the first time I read the instructions.
