On longer prints (more than 4 or 5 hours), it will randomly drop serial connection with the line (from octoprint.log)
2020-01-08 04:17:57,906 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2793, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4932, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2020-01-08 04:17:57,954 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2020-01-08 04:17:57,978 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
and from serial.log:
2020-01-08 04:17:57,952 - Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793
2020-01-08 04:17:57,955 - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2020-01-08 04:17:57,977 - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
2020-01-08 04:17:58,021 - Connection closed, closing down monitor
The pi itself never dies or reboots, just goes silent, printing-wise, for about 5 minutes before it restarts octopi and returns to waiting to print.
Put peripherals (a usb light and a logitech cam) on a powered usb hub listed in the wiki as working. Disabled plugins (only one I was using was discordremote) Lowered webcam resolution to 640x480x15, changed timelapse interval to 25s. The timelapse and resolution seemed to fix it, but it happened again overnight on a beautiful silk gold vase print and now i'm sad.
Logs (octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support!)
serial_cropped.log (69.8 KB) octo_cropped.log (73.1 KB)
(the logs have been cropped, and while discordremote was active for this one, i still was getting the same error without it active, so not the problem)
Octoprint 1.3.12
Octopi 0.17
Ender 3 pro (stock except for a couple printed additions, nothing mechanical or hardware)
Firmware: Th3d U1.R2.21a
RPI 3B with the 8gb card that was originally included in the printer.
Logitech C920
Browser: doesn't matter, all
OS: Windows
Power Supply: 99% sure it's a 3A power brick. Can triple check
