When I want to download the plugin from Octolapse, the system says to reinstall, the system does and then gives an error.
I dont no what to try.
Yes, it does the same.
No.
octoprint-systeminfo-20220818093021.zip (204.8 KB)
Error code.zip (12.7 KB)
This is the info that shows up when i want to download the plugin.
Samuel_Kats:
You really should fill in this part with the information about what device you have it installed on and how. We aren't mind readers. To help, you have to know what to help with.
As it stands, I think I can figure out from studying the log this looks like an Octo4a install?
hello Charlie,
Sorry, you're right.
As a printer I have the Ender 5 pro. I have the samsung galaxy 9 with octoprint on it which i use as a server.
Yes i use octo4a
@Charlie_Powell refers to this:
Hi! Recently I've released an early version of my app that allows for easy installation of OctoPrint on Android devices. It's a great way to make use of an old phone or tablet. It doesn't require root access and the entire installation process is one click of a button. No need for a raspberry pi
Features:
Quick and easy installation.
Printer connection via USB OTG. Thanks to the custom USB driver you can use OctoPrint even on phones without root access.
Built-in camera support.…
Go to the Octo4a app (NOT OctoPrint's UI), and install the 'Plugin extras' option, then you will be able to install OctoLapse.
Have anyone tried it with an android PC?
system
closed
January 23, 2023, 10:17am
#8
