Extruder temperature Wrong vs Cura GCODE
Hello,
I have an Ender Pro Direct BLTOUCH drive with SKR 2 Mini card latest Bigtreetech firmware
I have a problem since the last update, I have the temperature of the extruder which is not correct.
For example I set it to 210 in CURA and when I run the print it is at 260 in Octoprint
Thanks for your help
Upade Firmware SKR et TFT35 E3 v3.0
Yes
Yes
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.69 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3971153920
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.4
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: true
octoprint.version: 1.7.0
printer.firmware: Marlin bugfix-2.0.x (Jun 9 2021 15:03:14)
Firmware SKR 2 Mini : firmware-bltouch-for-z-homing.bin
update Marlin to 2.0.8.2.x
Hello @rodolphe_tordo !
Have you seen this:
Also see this:
@Ewald_Ikemann
here is
octoprint-systeminfo-20211101191126.zip (119.6 KB)
I haven't seen the post OctoPrint sets my nozzle temperature/nozzle offset too high
I finish my print and do a test.
thank you so much
I try this OctoPrint sets my nozzle temperature/nozzle offset too high
But the problem persists
Can you please share a tiny mode gcode file.
Also please enable the serial.log (OctoPrint Settings -> Serial Communication -> Serial Logging) and after a print (attempt) please share that log too.
Since running in safe mode solved the problem, what you now need to do is disable or re-enable the plugins a few at a time and testing to see when the problem re-occurs, then you know which plugin is causing the issue.
Good evening,
I did a fresh install on a new RPI 4, my old RPI 2 was suffering :face_with_head_bandage:
I followed your recommendations. :innocent:
I installed the plugins one by one and indeed it is the Filament Manager plugin that had the problem, so I reset it and everything is ok for the moment
Thank you very much for your help and this great software that is Octoprint :slight_smile: :partying_face: :sunglasses: :cowboy_hat_face:
