I just upgraded from 1.7.1 to 1.7.2. After it said it was successfully updated, it tried to reload the web interface and gave me an internal server error. I rebooted the raspberry pi and tried again and got the " The OctoPrint server is currently not running" message. I followed the instructions on that screen, but there was no python process running.
I rebooted the raspberry pi. Then I ran ps -ef | grep -i octoprint | grep -i python to check for the process. That returned nothing. I tried running sudo service octoprint restart, but that didn't seem to do anything. Running service octoprint status returned the following:
pi@octopi:~/oprint/bin $ service octoprint status
β octoprint.service - The snappy web interface for your 3D printer
Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2021-11-03 17:11:35 GMT; 7s ago
Process: 1033 ExecStart=/home/pi/oprint/bin/octoprint serve --host=${HOST} --port=${PORT} (code=exited, status=203/EXEC)
Main PID: 1033 (code=exited, status=203/EXEC)
Nov 03 17:11:35 octopi systemd[1]: Started The snappy web interface for your 3D printer.
Nov 03 17:11:35 octopi systemd[1033]: octoprint.service: Failed to execute command: Exec format error
Nov 03 17:11:35 octopi systemd[1033]: octoprint.service: Failed at step EXEC spawning /home/pi/oprint/bin/octoprint: Exec format error
Nov 03 17:11:35 octopi systemd[1]: octoprint.service: Main process exited, code=exited, status=203/EXEC
Nov 03 17:11:35 octopi systemd[1]: octoprint.service: Failed with result 'exit-code'.
Looking at the ~/oprint/bin/octoprint executable, it is 0b in size.
The octoprint command doesn't work.
N/A
OctoPrint won't run, so I can't access it from the System Information dialog. Trying to run it from the command line doesn't return anything. Looking at the executable, ~/oprint/bin/octoprint the file is 0b in size.
Here is the hardware section from the log file:
2021-11-03 00:04:21,750 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1500.0
| ram: 3959304192
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi 4 Model B Rev 1.2
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
OctoPrint: v1.7.2 (upgraded from 1.7.1.)
OctoPi: Linux octopi 5.10.63-v7l+ #1457 SMP Tue Sep 28 11:26:14 BST 2021 armv7l
Thanks for the reply. I followed the instructions to force a reinstall, running ~/oprint/bin/pip install --force-reinstall OctoPrint==1.7.2 --no-cache-dir, but I received an error when it got to the OctoPrint portion:
Attempting uninstall: OctoPrint
Found existing installation: OctoPrint 1.7.2
ERROR: Exception:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2857, in get_entry_map
ep_map = self._ep_map
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2815, in __getattr__
raise AttributeError(attr)
AttributeError: _ep_map
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/base_command.py", line 164, in exc_logging_wrapper
status = run_func(*args)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/cli/req_command.py", line 205, in wrapper
return func(self, options, args)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/commands/install.py", line 413, in run
pycompile=options.compile,
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/req/__init__.py", line 68, in install_given_reqs
uninstalled_pathset = requirement.uninstall(auto_confirm=True)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/req/req_install.py", line 670, in uninstall
uninstalled_pathset = UninstallPathSet.from_dist(dist)
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_internal/req/req_uninstall.py", line 564, in from_dist
console_scripts = dist.get_entry_map(group="console_scripts")
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2860, in get_entry_map
self._get_metadata('entry_points.txt'), self
File "/home/pi/oprint/lib/python3.7/site-packages/pip/_vendor/pkg_resources/__init__.py", line 2531, in parse_map
raise ValueError("Entry points must be listed in groups")
ValueError: Entry points must be listed in groups
