Filament runout notice?
is it posible to be notified when filament has runout , i have a filament sensor conected to the printer board which works great except for the fact it just beeps twice and pauses when the filament runs out ,
is there a way to have octoptint notify me via mqtt so i can get my google mini to say filament has run out or something like that ,
any ideas would be great
thank you
martin
looked through forum
googled
n/a
n/a
octoprint deploy , ender 3 , marlin ,ender runout switch ,
If the printer firmware is not set to pass on those events to OctoPrint, there is no chance.
HOST_ACTION_COMMANDS:
hi the marlin eprom plugin says i have host action comands ,
not sure how it works though .
martin
Sounds like Octoprint knows it was paused right.. If that is the case, you can install the MQTT plugIn
Then just set up you Google mini to pick up the event alert from Octoprint when the printer Pauses.
thanks
martin
