I still have access to the SSH login and have tried to reset my password with this The problem being that I don't know the username that I set it up with.
I wasn't sure if there was some way that I can look at the usernames that are in octoprint and then reset the password from there. I'm still really new to this so any help would be awesome.
I have tried this, the problemis that I don't know what the username is so whenever I what i thought it was I get "User does not exist" where is what I thought the username was.
As @andy-b said: it's from the backend via SSH, you don't need your OctoPrint username.
For SSH it is pi and raspberry (if you haven't changed them)
then do as described:
If you only have a single user set up
If you only have a single user setup in OctoPrint for which you forgot the password, the easiest way is simply resetting OctoPrint's user database and run the access control wizard again. The steps involved boil down to this:
remove ~/.octoprint/users.yaml
in ~/.octoprint/config.yaml replace firstRun: false with firstRun: true
restart the OctoPrint server and reload, you should be prompted to run the first time setup wizard again
If you are running OctoPi , you can use these commands to do all that:
rm ~/.octoprint/users.yaml
sed -i -e 's/firstRun: false/firstRun: true/g' ~/.octoprint/config.yaml
Note :
If you have the OctoPrint server installed on Windows, the location of the files will be %APPDATA%\OctoPrint\users.yaml and %APPDATA%\OctoPrint\config.yaml . If you have it installed on MacOS, the locations will be ~/Library/Application\ Support/OctoPrint/users.yaml and ~/Library/Application\ Support/OctoPrint/config.yaml .
