My octoprint instance has stopped accepting connections on port 5000 yet is successfully sending gcode to my printer. I've checked that the python3 process is running (it is) and is listening on TCP port 5000 (it is). The haproxy process gives the "The OctoPrint server is currently not running" message that it displays when it gets a 503 service unavailable from trying to connect.
Due to the fact that my printer is actively printing, I know that octoprint is functional. But octoprint is also not accepting connections on port 5000 to allow me to check status, see progress, etc.
I found that I could successfully connect to port 80.
% nc -v 127.0.0.1 80
Connection 127.0.0.1 80 port [tcp/http] succeeded!
I found that I could not successfully connect to port 5000:
% nc -v 127.0.0.1 5000
[ just sits there, doing nothing ]
I've looked in the octoprint.log for clues. Nothing unusual jumps out at me.
With strace, I've explored the activities of the python3 process and its threads. I can see the actions of the thread that's writing gcode to the USB bus:
[pid 7542] clock_gettime(CLOCK_MONOTONIC, {tv_sec=243218, tv_nsec=773710006}) = 0
[pid 7542] futex(0x433a9c, FUTEX_WAKE_PRIVATE, 1) = 1
[pid 7542] write(17, "N355900 G1 F900 X178.529 Y169.19"..., 49 <unfinished ...>
[pid 7542] <... write resumed> ) = 49
[pid 7542] gettimeofday({tv_sec=1615066509, tv_usec=414354}, NULL) = 0
[pid 7542] futex(0x433a98, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 0, {tv_sec=1615066509, tv_nsec=419354000}, FUTEX_BITSET_MATCH_ANY <unfinished ...>
[pid 7542] <... futex resumed> ) = 0
[pid 7542] futex(0x433aa0, FUTEX_WAIT_PRIVATE, 2, NULL <unfinished ...>
But this doesn't help me figure out why another thread isn't responding on port 5000.
I've explored the logs to see if I can determine the root cause of the problem. I don't want to restart the octoprint python3 process because I'm concerned it will stop sending gcode to my printer during my current (32-hour) print. I'm hesitant to restart haproxy for the same reason, though that will likely be my next step. I thought I'd reach out to the community before I take steps that could potentially kill my print mid-stream.
Output of ps:
% ps -efl | egrep 'haproxy|python'
4 S pi 426 1 1 80 0 - 225973 futex_ Mar03 ? 01:09:11 /home/pi/oprint/bin/python3 /home/pi/oprint/bin/octoprint serve --host=127.0.0.1 --port=5000
4 S root 530 1 0 80 0 - 3741 - Mar03 ? 00:00:00 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid
5 S haproxy 539 530 0 80 0 - 4075 - Mar03 ? 00:01:30 /usr/sbin/haproxy -Ws -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid
Output of netstat:
% sudo netstat -tulpen | grep LISTEN
tcp 129 0 127.0.0.1:5000 0.0.0.0:* LISTEN 1000 20034 426/python3
tcp 0 0 192.168.4.40:8080 0.0.0.0:* LISTEN 0 442570 9988/./mjpg_streame
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 17422 525/sshd
tcp6 0 0 :::80 :::* LISTEN 0 15220 539/haproxy
tcp6 0 0 :::22 :::* LISTEN 0 17424 525/sshd
tcp6 0 0 :::443 :::* LISTEN 0 15221 539/haproxy
I can get any strace log needed, but several seconds gave me over 10,000 lines. I don't want to include that here.
The end of octoprint.log:
% tail .octoprint/logs/octoprint.log
2021-03-06 16:29:04,661 - octoprint.plugins.tplinksmartplug - INFO - Object
2021-03-06 16:29:04,662 - octoprint.plugins.tplinksmartplug - INFO - MoeSizzlac_-_Mandalorian_Chest_Armor_2.stl
2021-03-06 16:31:35,136 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-03-06 16:31:42,447 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 242994}
2021-03-06 16:37:51,636 - octoprint.plugins.tplinksmartplug - INFO - Object
2021-03-06 16:37:51,637 - octoprint.plugins.tplinksmartplug - INFO - NONMESH
2021-03-06 16:43:01,694 - octoprint.plugins.tplinksmartplug - INFO - Object
2021-03-06 16:43:01,696 - octoprint.plugins.tplinksmartplug - INFO - MoeSizzlac_-_Mandalorian_Chest_Armor_2.stl
2021-03-06 16:46:35,138 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-03-06 16:46:42,323 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 243894}
Everything about the node otherwise is fine. I can ssh to the raspberry pi, which is 192.168.4.40 on my local network. I can connect to haproxy.
