GCode viewer is running behind the actual situation
I've noticed that when the print is progressing the Gcode viewer is not showing the actual situation.
For instance:
Gcode viewer is repoorting layer #24 and the printer and the Display layer info plugin reports layer #37.
Screendump from Octopi
Has anyone a solution?
Long discussion about this behavior:
And the solution:
Thanks for your response, will install the plugin and I'm pretty sure it will solve this issue.
