Hi all,
I realized that the GCode Viewer is not working properly in my Raspberry, it show the gcode not centered, but the printer print it in the center. Is only a view issue.
How can I fix it?
Im using a Longer LK4 printer.
Hi all,
How can I fix it?
In your printer profile settings, you need to change where the origin is. Looks like from your one that your printer's origin is at the center. Switch it from whatever it is now.
Ok thanks, I will try this!
PrettyGCode also shows my print in the corner. The origin setting in my printer profile is set to center.
Switch it then, most printer's don't have center origin.
I figured that would be your response 60 seconds after I posted that. Thank you.
Thanks, this worked perfectly!
