When I slice a dual extrusion print and send it to Octoprint it only uses one of the tools instead of both of them. It varies which tool is used. When the same gcode is printed from the SD card it runs successfully.
Tried making sure the gcode was generated correctly.
Confirmed with a fellow octoprint user that he could print my gcode with a fresh install of octoprint with no plugins.
Successfully printed my Gcode one time in safe mode. After this I turned off all 3rd party plugins and it printed the part with one extruder as it had done before. put octoprint back in safe mode and it only used one extruder again.
Verified gcode was set to use 2 tools in octoprint
Printed Gcode from SD card with printer screen sans octoprint successfully.
Latest version of octopi/octoprint set up less than a month ago
This entire print printed with T1, even thought it was supposed to start with T0
Print was done in safe mode.
Attached logs, terminal output and gcode.Logs.zip (37.0 KB)
