Get rid of mjpg_streamer
I come from astroprint, and I know that my setup can deliver an appreciable stream without lags and good resolution.
After installing octoprint I've tried with raspicam (the original one, latest version) and with a webcam.
With raspicam the stream is very slow.
With webcam is a little bit faster, but always slow, and for this setup sometimes mjpg_streamer stucks and no image comes from webcam.
Iìve tried killing mjpg_streamer, sometimes it comes back without any command and re-start streaming till the next time it freezes.
I want to stream in an alternative way, do you have any suggestion? The only requirement is that the stream can be accessibile from octoprint web interface in a reliable way.
Thank you
A bit more information would be helpful.
What pi are you using and is it on wifi or lan?
I'm using a 3b+ with wifi (5ghz), but as I said with the same hardware and the same wan connection on astroprint the video was very fluid (but I think they encode using h264, I'm not a video expert though)
If I'm not mistaken astroprint uses raspivid piped to gstreamer.
there are several similar approaches but I haven't testet one myself
Here is the astroprint camera part on github
and here two things I found while I googled the topic
https://www.raspberrypi.org/forums/viewtopic.php?t=186271
Maybe another user got more ideas :slight_smile:
Looks like astroprint also uses webrtc in the backend. There was a discussion at the link below to get that to work.Not sure if it progressed any further though.
