I use one of my Octoprint's with a Laser CNC and it works great however it works best with v1.7.3. I can't seem to find it and when i use the pi imager it only lets me select V1.9.3 I am setting up a 2nd machine and would prefer to sty with the version I know works. I also need to be able to replaced the SD card if needed with the same version as well.
Thanks so much.
Here you go ![]()
Thank you so much, I will give that a try.
Thank you so much, that worked perfectly.
Now I'm having a problem with the relay icons on the top row. They are too large and bunched together. Can I roll back Octorelay?
