the problem is that when i try to restore the backup
It's very frustrating, I don't remember commands and actions, I tried to run multiple instances, but what I got was to ruin mine, when it restarted it went from version 173++ to version 1.4 and I lost part of the network configuration "fixed ip" plugins and it was clean
functional but 1.4,
Error while running restore
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/plugins/backup/__init__.py", line 1260, in _restore_backup
on_install_plugins(known_plugins)
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/plugins/backup/__init__.py", line 292, in on_install_plugins
self.__class__._install_plugin(
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/plugins/backup/__init__.py", line 914, in _install_plugin
cls._pip_caller.execute(*pip)
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/pip.py", line 208, in execute
return self.call(command, **kwargs)
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/commandline.py", line 244, in call
all_stdout += process_stdout(p.stdout.readlines(timeout=0.5))
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/commandline.py", line 236, in process_stdout
return process_lines(lines, self._log_stdout)
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/commandline.py", line 229, in process_lines
processed = self._preprocess_lines(
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/pip.py", line 498, in _preprocess_lines
return list(map(self._preprocess, lines))
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/pip.py", line 517, in _preprocess
return to_unicode(clean_ansi(text))
File "/home/pi/oprint/lib/python3.9/site-packages/octoprint/util/commandline.py", line 57, in clean_ansi
return _ANSI_REGEX.sub(b"", line.encode("latin1")).decode("latin1")
UnicodeEncodeError: 'latin-1' codec can't encode characters in position 5-43: ordinal not in range(256)
Restore failed! Check the above output and octoprint.log for reasons as to why.
Removing temporary zip
I spent the night before trying to restore but...
I tried a new installation, my ouio 32/64 gb cards didn't work and the time it took to find out that the cards were faulty, I was confused because octopi 1.0** didn't install and repeated camera configuration commands, I saw this, hare the when it was difficult for me to put the camera to work and with this new version just in the camera that was missing the installation did not proceed... of course the defect was the memory card. I currently believe with the latest version octopi and octoprint 1.0 and 1.73 it does not restore backup, sorry for so many unnecessary words, it is part of everyday life to admire the printed pieces and the history of printing the photos. and may other things
i see octoprint in my tv, i love it.
so i would like some tips to try to repair the old installation or put the history in this new installation
running for almost 2 years, that's what helped me to print something, so many gcodes and adjustments, even to align the bed, octoprint
thank you so much...
run wonderfully, and frighteningly very well, when I saw what I had done I thought it wouldn't run anymore, but it doesn't restore backup 1.4 to 1.73
no problem
octoprint-systeminfo-20220505020554.zip (12.4 KB)
new
browser.user_agent : Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.41 Safari/537.36
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1200
env.hardware.ram : 913608704
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version : 1.0.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 22.0.3
env.python.version : 3.9.2
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.7.3
systeminfo.generator : systemapi
I think maybe. this new one is better. this card is already a little faster and it won't be as complicated as before.
the problem is not that big, writing this and reviewing the files, what I really want now is to thank everyone, for making everything easier and more beautiful.
thanks everyone. for everything
But tips are welcome...
