I am not able to upgrade Octoprint, may someone help me ? This is the log:
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-vyeaqF/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i Simple index --extra-index-url piwheels - Simple index -- setuptools wheel Cython Check the logs for full command output.
Open OctoPrint's logging section, and download the plugin_softwareupdate_console.log file, then upload the whole file to the post. You don't need to copy and past it, hit the upload button or drag and drop the file
I have the same or similar problem, but I not see PrintTimeGenius plugin installed, how can I solve the problem? plugin_softwareupdate_console.log (1.7 MB)
