While printing it seems to stop go to top left corner deposits spare filament then comes back to the print
looked at all settings cant see anything
Complete Logs
octoprint.log (173.4 KB) octoprint.log (173.4 KB)
Version 1.4.1rc4 ender 3 pro stock
That sounds like you activated something like nozzle cleaning in your slicer
Thing is there isn’t that in Cura anywhere wonder if it was in the Gcode that’s the only other thing I can think of
Thanks for replying
I think, the serial.log could be quite helpful here.
2020-08-03 11:20:36,298 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
Please enable the serial log first.
Could it be that octolapse or something similar is activated?
2020-08-03 19:11:32,030 - Send: N6460 G1 F9000 X0 Y190*122
2020-08-03 19:11:32,056 - Recv: ok
2020-08-03 19:11:32,063 - Send: N6461 M400*18
2020-08-03 19:11:32,944 - Recv: T:200.00 /200.00 B:60.32 /60.00 @:78 B@:0
2020-08-03 19:11:33,540 - Recv: ok
2020-08-03 19:11:33,559 - Send: N6462 M240*19
2020-08-03 19:11:33,568 - Recv: ok
i've deinstalled octolapse that before i ran that log as i said can't remember it happening before
Reffering to the octoprint.log, its still active:
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| Octolapse (0.4.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| OctoPrint Ikea Tradfri (1.3.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ikea_tradfri
Also, The Spaghetti Detective could be the culprit.
ok thanks i'll go through and check
